BMW X3 Forum
BMW X3 Forum
Welcome to the ultimate BMW X3 community.
      02-27-2011, 10:06 PM   #1
ajbmw311
e92 Driver
ajbmw311's Avatar
Colombia
Drives: 2008 335i e92
2006 X3 3.0 Engine noise at idle
I've veen having an issue with my 2006 X3 3.0 for about 3 weeks now, where the engine makes this high-pitch squealing noise at idle. It sounds like it could be something belts related but when I get real close it almost sounds like it's coming from the valvetrain area.
check out these
http://www.youtube.com/watch?v=ZOqOHIM22eU
http://www.youtube.com/watch?v=gx3Emd660eQ
http://www.youtube.com/watch?v=7YszOa16Vc0
Anybody had anything like this happen before? I changed the oil today and checked the air filter and looked around some more but I still can't figure it out.
Any clues any one?
Thanks,
AJ
2008 335i cp Montego Blue
      02-28-2011, 08:13 AM   #2
rs6655
rs6655's Avatar
18
Drives: 2009 X3 (MT)
The video doesn't help that much but from what you decribe my bet would be the belt or the idler pulley bearings.
      02-28-2011, 09:22 AM   #3
ajbmw311
e92 Driver
ajbmw311's Avatar
Colombia
Thanks!!
hmm yeah After listening to your video, it sounds similar... I didn't know whether to call it a "Squealing" noise or a "chirping" noise, but it definitely happens at idle speeds and is more pronounced when engine is cold.
if it turns out to be the idler pulley bearings, might as well replace belts and idler pulley while I'm at it right. I'm right at 65k. has anyone done this on their own? is it very difficult to do?
      02-28-2011, 01:31 PM   #4
rs6655
rs6655's Avatar
18
Originally Posted by ajbmw311 View Post
Thanks!!
It's a fairly straightforward job for the mechanically inclined.
If that's what it is I'd add water pump to that while you're in there. They have been known to fail catastrophically.
http://www.youtube.com/view_play_lis...DA1A1C4A3A199B
You could also pay for a day's access and get what you need from BMW directly if you can't find what you need elsewhere.
http://www.bmwtis.com/
      02-28-2011, 04:56 PM   #5
ajbmw311
e92 Driver
ajbmw311's Avatar
Colombia
Do you mean a water pump pulley or the whole water pump?
Thanks
AJ
      02-28-2011, 06:09 PM   #6
oldman67
Drives: 2005 x3
sounds familar to me check the water pump bearing by graping the fan blades and see if the wopple
      03-01-2011, 07:56 AM   #7
rs6655
rs6655's Avatar
18
Thanks
AJ
The whole pump.
http://blog.bavauto.com/bmw-e46/bmw-...mp-replacement
xbimmers
