New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      02-03-2011, 11:50 PM   #1
ttuner
ttuner's Avatar
67
Drives: z4
Supersprint x-pipe + Remus axelback?
will this:
[IMG]http://www.**********s.com/zoom_img/_1272387065.jpg[/IMG]
work with this:
[IMG]http://www.**********s.com/zoom_img/_1289307390.jpg[/IMG]
seems to me that the x-pipe should work with any axel back, but anyone know for sure?
2011 BMW Z4 35i | FBO | VTT Stg 2+ (EK, 20T clipped)| Motiv PI| Motiv Tuned | Fuel-IT Stg 2 + inline fuel pump | Spec Stg 3+ clutch | MFactory flywheel | 606whp 575Lbs |
      02-04-2011, 12:55 AM   #2
taYab
taYab's Avatar
Drives: '06 E60 '09 E89 '14 F25
Why not just get the Eisenmann full exhaust?
2006 E60 Gone!
2009 E89 Gone!
2014 F25 !!
      02-04-2011, 02:33 AM   #3
jannisa
jannisa's Avatar
54
Drives: Z4 Sdrive35i
Most probably not. BTW you won't gain anything by changing the x-pipe, keep your original (and your money) and you can decide whether to delete the center catalysts or not, in which case you will change only the sound to more aggressive and maybe a few hp on high rpm but hardly noticeable. The main restriction is in the downpipes.
      02-04-2011, 08:49 AM   #4
Land_Shark
In The Flesh
Hong Kong
23
Drives: Z4 sDrive 35i
Did you chip your ECU? If you are using a mod upgrade to your ECU ( JB3, Dina, ESS, etc...) the X pipe will increase you hp an noticeably..
If you have done nothing to you ECU and just want to change your x pipes for hp gain, this won't add any hp not torque...
Now back to your question, would the supersprint x pipes fit with the Remus? You need to provide us with more details about the supersprint you are intending to install...
This sport Remus tail pipe Ø is 2.99″
You will need to see what is the Ø of the x pipes...
      02-04-2011, 11:13 AM   #5
Constant.S
Resistance is futile...
Constant.S's Avatar
54
Drives: BMW Z4 E89(N54)
Everything fits with the right ammount of labor + time + skilled mechanic. Will it be bolt on? No.
An ounce of performance is worth pounds of promises.
      02-04-2011, 11:16 AM   #6
ttuner
ttuner's Avatar
67
Drives: z4
thanks. i cant find the diameter of the x-pipe anywhere.
i will get a tune at the same time as well. i dont want the eiessman cause it would be double the cost of this setup, and i dont want to cut up my bumper.
      02-23-2011, 12:32 PM   #7
Chuck93442
Drives: 2009 E89 3.0
Just spent the weekend installing the Remus on my 2009 3.0. The angles of the pipes did not match the angles of the original system and required a trip to a muffler shop where the technician spent considerable time cutting and welding to line things up. Also the bends in the area of the center mount were incorrect and rubbed the underbody. I've installed other systems, namely Supersprint, without any problems. Remus has a problem with this system and they need to correct it.
      02-23-2011, 01:04 PM   #8
taYab
taYab's Avatar
That may be due to 30i.
2006 E60 Gone!
2009 E89 Gone!
2014 F25 !!
      02-23-2011, 01:19 PM   #9
entrepreneur177
из Кремля
entrepreneur177's Avatar
Russian Federation
15
Drives: Z4 35s, CLS63 AMG
You are so right!
Yesterday I installed Remus exhaust and everything was simple, straight forward and plug n play! Later this week I'm going to post photos and videos of it. Sounds really nice. Next step is going to be the AR Downpipe
      03-04-2011, 11:21 AM   #10
ModBargains.com
Drives: JB E92 335i
Both the Eisenmann E89 Z4 Performance Exhaust System or the Remus Z4 E89 Axle Back Exhaust System look great and offer impressive Horsepower and torque gains. I'll PM you with more details!
      03-05-2011, 12:01 AM   #11
zzz36
Drives: lexus
Hi ********** can you PM me
The answer about Remus and supersprint mid pipe thanks
      03-05-2011, 02:13 AM   #12
ModBargains.com
Drives: JB E92 335i
You should be able to get the Remus Exhaust to work in conjunction with the Supersprint midpipe. However, this is something that I would recommend that you simply take to an exhaust shop to take care of as you may have to weld the two systems together. We do have these Remus exhaust systems in-stock for you guys as well so don't hesitate to shoot me over a PM if you guys have any questions at all!
zpost
