Throttle Surging with V5
01-19-2011, 08:07 PM | #1 |
Rep 284
I know Vishnu is working hard on the new updates that will probably address the throttle adaptation issues causing the surging of the throttle while driving (the car acts as though I'm pushing the gas and letting off about once every second even though I have my foot steady - really annoying)...
I was just wondering in the mean time if anyone has had any success with getting it to smooth out? I've reset all adaptations and the ECU and let the car sit for a couple of hours. After about 60 miles of driving on map 1, it almost seems like it's getting worse. Any suggestions?
01-19-2011, 08:10 PM | #2 |
Rep 3,460
Yea, I had the same issue only after using NA mode. I actually ended up resetting everything including firmware/maps/ecu/adaptations. It was REAL annoying, but it went away
01-19-2011, 08:15 PM | #3 |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
+1, for the time being we recommend only using the NA mode for valet purposes. Doing a long highway drive may induce throttle adaptations that show up when running the regular performance maps. It will go away after you reset adaptations and drive for a bit. How long depends on how you drive. If you want to speed things up, just reset all adaptations (followed by an ECU Reset command) and then just drive in Map0 for a bit. It will work itself out.
On a side note, we worked out a different method to induce NA operation that shouldn't contribute to adaptation values. It's probably a couple updates away. But it's coming... |
01-19-2011, 08:19 PM | #4 |
Rep 494
That's cool I've had the same exact feeling after the NA mode wish I've never touched it , I'm going to try driving in map 0 after adaptation reset
01-19-2011, 08:20 PM | #5 |
Rep 284
Shiv, I thought you recommended driving in a regular performance map (map 1) to smooth things out. You're saying I should keep it in valet mode?
Any idea why it's not improving after over 60 miles of driving following resetting everything?
01-19-2011, 08:23 PM | #6 |
1740
Rep 17,960
Drives: A Lot
It really doesn't matter what map you run. I'm only suggestion Map0 since those would induce the most standard adaptation values. You just have to drive normally (ie, not just cruising at one engine speed) and it will re-adapt. There are BMW recommended drive cycles that speed thing along but normal driving will do the same.
01-19-2011, 08:30 PM | #7 |
Rep 978
Have you tried to follow BMW's adaptation procedures post ECU reset, as documented in my thread here?
http://www.e90post.com/forums/showthread.php?t=429881 |
01-19-2011, 08:34 PM | #8 | |
Rep 494
01-19-2011, 08:36 PM | #9 | |
Rep 284
Is there another solution? Maybe just reloading the firmware as someone suggested?
01-19-2011, 08:44 PM | #10 |
1740
Rep 17,960
Drives: A Lot
That test cycle probably wont get what you want to re-adapt to re-adapt. Try this: Do a Throttle Adaptation Reset followed by an ECU Reset (all through command center). Turn off ignition power for 1 minute. Then drive in Map0/stock mode to see if it's sorted out.
Reloading firmware or maps wont do anything as they have no effect when running in Map0. What you are experiencing is DME adaptation, not Procede learning. |
01-19-2011, 09:03 PM | #11 | |
Rep 284
01-19-2011, 09:03 PM | #12 |
1740
Rep 17,960
Drives: A Lot
