E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Automatic headlamp control does not work
      02-12-2007, 06:11 AM   #1
Beefy
Beefy's Avatar
Drives: E91 330d Trotter
I realised that the headlight seems to be on all the time regardless of the ambient condition when it is in auto mode (position 1). Does any experience or notice the same?
      02-12-2007, 06:19 AM   #2
Rochester BMW
Drives: 335i M Sport. On order E92 M3
Check your Daytime Running Lights are not on... (DRL's)
      02-12-2007, 06:28 AM   #3
vivekk
THE Viv
vivekk's Avatar
England
184
Drives: 330i SE
The DRLs are off by default, unless you or your dealer has been playing with your car's settings!
The automatic headlamp control seems to turn the dipped beams on quite a lot, although I do actually enjoy that fact!
If you want to adjust the sensitivity (with idrive) click the Menu button -> Push for the imenu -> Vehicle settings -> Lighting -> Auto headlamps -> change the sensitivity to suit you
All the best.
Viv
[TiAg ▪ Dakota Black ▪ Active steering ▪ Sports suspension ▪ 162s ▪ Sports seats ▪ Al trim ▪ Bi-Xenons ▪ F&R PDC NavPro ▪ Voice control ▪ Bluetooth ▪ 6CD Logic7]
      02-12-2007, 10:17 AM   #4
red-max
red-max's Avatar
England
42
Drives: 520d M Sport
Just out of interest, where's the sensor for automatic headlamps? Does it use the windscreen wiper sensor at top of the windscreen, or is it somewhere else?
2018 G30 520d M Sport with M Sport Plus - Mediterranean Blue
Previously: 2015 F32 430d M Sport, 2012 F10 520d M Sport, 2009 E92 320d M Sport, 2006 E92 335d, 2004 E60 530d, 2000 E39 525d, 1997 E39 523i
      02-12-2007, 11:37 AM   #5
vivekk
THE Viv
vivekk's Avatar
England
184
Drives: 330i SE
I'm pretty sure the ambient light sensor is part of the rain sensor, at the top of the windscreen.
Have a play with it- cover it up / shine a bright light on it & see what happens!
Viv
      02-12-2007, 11:39 AM   #6
Z4 Beemer
Z4 Beemer's Avatar
Scotland
83
Drives: 2009 Z4 sDrive 23i
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Viv
Yeah, I did that with mine to confirm!
E89 Z4 sDrive 23i... for the more discerning driver
      02-12-2007, 11:49 AM   #7
yellowg555
Drives: 2006 325i
Also if you have adaptive lights, they will only "adapt" when in Auto mode. Try the other mode and you will notice that the lights do not swivel when you turn.
2006 Jet Black 325i, ZPP, ZSP, Steptronic Auto, Navi, Xenon
      02-12-2007, 11:52 AM   #8
KL2DC
KL2DC's Avatar
Drives: F36 428i,E90 328i, E85 Z4 3.0i
2015 F36 428i  [0.00]
2011 E90 328i  [0.00]
2006 E85 Z4 3.0i  [0.00]
Either:
1) Your sensors need recalibrating. The sensitivity of the sensors can be adjusted by the techs.
2) Your sensors are blocked/dirty. Try cleaning your car/windshield and see if the problem is still there.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call!
      02-12-2007, 02:48 PM   #9
red355
red355's Avatar
England
32
Drives: RS4 Avant V8
never knew that....I will check it out tomorrow morning
RS4 Avant V8 Misano Red ¦ ¦
Golf GTI ¦ leather ¦
Past¦E92 335D Evolved (but still dull) ¦ Boxster S ¦ E46 328!SE ¦ E36 325! coupe ¦ E30 325! sport ¦ MINI Cooper S
      02-13-2007, 04:02 AM   #10
Beefy
Beefy's Avatar
I’ve checked the idrive setting just now, the daytime running light option is unchecked, and the lights are still on even on a bright day like today.
Changing the sensitivity setting didn’t make any difference.
      02-13-2007, 04:09 AM   #11
Z4 Beemer
Z4 Beemer's Avatar
Scotland
83
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Is there any way to change the sensitivity on non-idrive cars?
      02-13-2007, 07:19 AM   #12
booforty
booforty's Avatar
Drives: E92 M3
2008 E92 M3  [0.00]
Only the dealer can do it for you
      02-13-2007, 07:21 AM   #13
booforty
booforty's Avatar
Drives: E92 M3
2008 E92 M3  [0.00]
Ask your dealer. Maybe the light sensor is faulty? Mine are ok on the least sensitive setting.
      02-21-2007, 08:32 AM   #14
Beefy
Beefy's Avatar
I’ve contacted the dealer and here is what they explained:-
To ensure that the dipped headlights are switched on reliably at the onset of twilight, the sensitivity rating of the low beam has been carefully selected by the factory. The vehicle standard phototransistors, which are used in the rain/light sensor (RLS), are mainly sensitive to light in the infrared range, which acts with a higher intensity on the light sensor in very cloudy conditions. In contrast to this, human eyes are more sensitive to the blue light range. These different sensitivities mean that sensor receives a much lower proportion of infrared light when there is light cloud cover or clear blue skies – particularly in the winter and the RLS switches the lights on earlier or leaves them switched on for longer than the driver would.
…..sounds like the automatic headlamp feature appears to switch on too early or too late is part of the characteristic of the car, it can’t be changed/adjusted.
Case closed!
      02-21-2007, 10:38 AM   #15
red355
red355's Avatar
England
32
Case closed!
Sounds very familiar to my car...so far even on the brightest of winter days the lights seem to remain on.
BMW E92 the new Volvo 240
      01-04-2009, 12:30 PM   #16
alcook
alcook's Avatar
Drives: M4 CP Convertible
Auto headlights not 'autoing'
Have selected the left hand position with the A..
Have tried changing the sensitivity..
But they simply do not turn off when in daylight.
Today was fairly bright, but even on 'Sensitive', they stayed on. Not sure where it's located, but has the light sensor gone? Is there a setting on the iDrive that's overridden it?
      01-04-2009, 12:35 PM   #17
Carrera RSR
England
75
I have found mine to stay on recently even on blue sky but very low sun days. I think it's just the current Winter low light levels.
Where is the 'sensitive' setting located you mentioned?
There is a 'Daytime Running Light' setting which can over ride the Auto setting
      01-04-2009, 12:37 PM   #18
willhollin
willhollin's Avatar
England
268
Drives: VW T5
Sensor is up on top of windscreen isn't it? Look where the rear view mirror is, maybe some shite on it.
      01-04-2009, 02:30 PM   #19
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
945
Drives: 997.2 GT3
Mine are always on at the moment when in auto. But it is rather dull in the winter aint it.
997.2 GT3
      04-05-2009, 03:17 PM   #20
Crudeman
Drives: 07 E92 320d M Sport
Im having similar problem as Beefy, think its too sensitive. Previous 320d didnt have this feature but my new 330d has it.
Tried shining a torchlight into the sensor and after a while the dipped lights turns off. When the torchlight removed away, the light went on immediately.
I still feel mine is overly sensitive, today while driving around 5/6 pm and the sun was still out albeit some clouds, its relatively a bright day most car have their headlights off.. and mine was on most of the time.
      04-02-2010, 03:21 PM   #21
Marconi
Drives: E90 lci
I have the same problem with my 3 months old car. I turn the switch to position 3 (automatic headlamp control) hoping that the light would be off during the day. Today was a quite sunny spring day. I was driving for about 5 hours (from 10am to 3pm) on the interstate and the light never went off. Felt like a fool.
How can I check if the sensor is faulty? Can I do it with a flashlight placed right on the windshield glass (over the sensor)?
e90post
