E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Are your engine temps this low?
      12-13-2010, 06:55 PM   #1
saifsiddiqui
Drives: 2008 E92Xi
So I was driving for like 4-5 hours and the engine wouldn't get warmer than this. It was only 9 degrees outside but it my other cars, even when it is this cold the engine temp would usually get to were it normally is supposed to be. Is this normal? I just have a DCI in right now.
      12-13-2010, 06:56 PM   #2
chancejat
chancejat's Avatar
Drives: bmw
thats where my 135i stays around unless i start getting on it......
      12-13-2010, 07:48 PM   #3
saifsiddiqui
Drives: 2008 E92Xi
hmm really? mine usually goes to a couple ticks before the halfway mark.
      12-13-2010, 07:54 PM   #4
Constant.S
Resistance is futile...
Constant.S's Avatar
54
Drives: BMW Z4 E89(N54)
Does that car stay at that temperature if you step on it (get the turbo spooled up) too?
An ounce of performance is worth pounds of promises.
      12-13-2010, 08:00 PM   #5
saifsiddiqui
Drives: 2008 E92Xi
it was snowing so i didnt really try to get the turbos spooled up or anything..
      12-13-2010, 08:01 PM   #6
2kaccordocoupe
2kaccordocoupe's Avatar
Drives: Former ///M Driver
Same here, with sub freezing temps lately my car runs about the same temp.
      12-14-2010, 07:03 AM   #7
subieworx
Drives: 07 335
Nothing wrong with that. I would rather run 195* oil temp as indicated by your gauge than 250* temps.
      12-14-2010, 08:51 AM   #8
e93WhiteonRed
e93WhiteonRed's Avatar
Drives: 2007 E93 Alpine white with Red
2007 335I E93  [0.00]
I bet a lot of people wish they were running at those temps. You'll see that rise as you put a tune on it.
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
      12-14-2010, 09:07 AM   #9
MusclezMarinara
Drives: VALNCYA
Depends on outside air OP....mine runs 200 range well see what it does today its 20 degrees out here.
      12-14-2010, 09:09 AM   #10
Dr. G
Dr. G's Avatar
278
Drives: Black e92 335i
e92 BMW 335i  [8.84]
Saif bro whatup... mine usually runs around that temp too, unless i go WOT a couple times then it heats up.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
      12-14-2010, 09:27 AM   #11
mycoupe
Drives: 07 335i coupe 6spd
It was 7 degrees F here this morning and mine was sitting right around 210 after an hour of driving.
      12-14-2010, 09:32 AM   #12
jeveryday
jeveryday's Avatar
Drives: 2012 535i xDrive
Maybe because ur temp outside is 9 degrees... idk
      12-14-2010, 10:03 AM   #13
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
Normal for Chicago in the winter. This will be my second winter here with this car and its absolutely normal. My 10 year old AUDI A4 1.8T also runs about the same oil temp range during the winter.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      12-14-2010, 11:53 AM   #14
Constant.S
Constant.S's Avatar
54
Then its an absolutely normal temperature to run considering the outside temperature.
      12-14-2010, 12:58 PM   #15
saifsiddiqui
Drives: 2008 E92Xi
Thanks for the responses guys.. I guess I'm just trippin lol
      12-14-2010, 01:07 PM   #16
Atomicteal_M3
Atomicteal_M3's Avatar
Drives: E90 M3 AW
2007 335i  [9.00]
Mine constantly stays at that temperature. Prolly because of my UR CAI and the 25 degree weather.
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
      01-18-2011, 10:45 AM   #17
Jred22
Meat Puppet
Jred22's Avatar
Drives: '11 e90 M3 Competition
My 08 e90 335i runs around 190-200, while my 07 e92 335i sits around 250. What gives?
EDIT: just realized my e90 and e92 gauges aren't identical, and are both at the same temp.
      01-18-2011, 11:12 AM   #18
pimple
Drives: 335i N54
I see in the picture that the OP is running top-most gear at a low rpm. I'd suggest selecting a lower gear to increase the engine rpm in hopes of raising the oil temp. I'd suggest an oil temp target greater than 212 degrees F to allow moisture in the oil to evaporate.
e90post
