Battery Adaption Reset same as Registering?
12-07-2010, 07:55 AM | #1 |
Rep 98
When it comes time to replace the battery in the 335, is the Proceed Battery Adaption Reset feature the same thing as registering the new battery? If not, what is the differrence?
12-07-2010, 09:06 AM | #2 |
Rep 2,320
are u AT?
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
12-07-2010, 09:27 AM | #4 |
Rep 2,320
what do u mean procede battery adaptation? if u change old battery and install new one? if u talking about adaptations reset u no need to do that cos u are MT (if u talking about procede command center) if i am wrong somebody please correct me
12-07-2010, 10:17 AM | #5 |
Rep 272
Drives: 335i 6MT & X5D 6AT
I have the same question as OP.
**335i** The procedetuning chip comes with a feature called "battery adapation" |
12-07-2010, 11:51 AM | #6 |
Rep 1,035
The adaptations are different from registering. You need a bmw scan tool to register a new battery when replacing. Im not to familiar with the procede stuff, but im assuming that adaptation reset is just to reset the learned adaptations of the vehicle. That has nothing to do with registering a battery.
12-07-2010, 09:18 PM | #7 | |
Rep 272
12-08-2010, 04:28 PM | #8 | |
Rep 1,035
A battery register is completely different. When replacing the battery in a BMW with an IBS cable (which yours has) You need to register the new battery, to tell the DME that it now has a fresh battery with full capacity. Basically what happens is. The IBS cable monitors the battery, voltage, capacity, temp etc. Over time the battery will discharge ( it may still output correct voltage) but its capacity drains. When this happens the IBS cable tells the DME to tell the Alternator to slowly bump itself up do the battery is getting weaker, so it will charge it more so it can keep up. Now when you replace the battery, the new battery obviously has a full capacity. The IBS cable will not know right away that you have a new battery in it. So it can potentially OVERCHARGE the new battery for a brief period of time until it relearns which can potentially shorten the life of the new batt. The reason for registering is basically to tell the system it has a new battery, with full capacity and it doesnt need to be charged at a higher rate. I dont believe the Procede can do this. Hopefully I explained this clear enough. |
