GIAC Stage 2 and Turbo Actuators
12-07-2010, 02:10 AM | #1 |
Rep 541
So I am still only boosting max 11psi and the shop which installed the software said that my actuators could not handle the added boost. I told them it was built for the fully bolted on car.
I check all the boost lines and intakes yesterday and they look fine however the lines are not tightened with zip ties. The clamps are all tight are the DV's and intakes. They are running logs at the shop now to check the boost levels. I have asked them to do a full system pressure test. If my actuators were faulty or not holding boost wouldnt they make a rattling noise ??? Do I need to upgrade my actuators? What else can I check? Or get them to check for me since I dont have the time to do it all myself like in college. The car is idling fine and runs ok but alittle down on power ... seems the same as stage 1 - but they said they downloaded the new stage 2. This is annoying the hell out of me ... oh I have 18000 miles on the motor. Thanks |
12-10-2010, 02:40 PM | #2 | |
Rep 372
12-11-2010, 06:12 AM | #3 | |
Rep 541
What logs do you want to log? I can do it and send it to you. Just send me a message on how to do it - since I have only logged on my Vagcom software for my VW. I have the hardware / software from Bavarian to do it however have no run any yet. Just let me know. I thought I was supposed to peak more than 11psi with stage 1 even with full bolt ons. Thanks |
12-14-2010, 02:27 AM | #5 |
Rep 480
12-14-2010, 06:57 AM | #6 |
Rep 541
The shop installed the DV for me ... I will have to get the springs off them. Do the springs install the same way as the Forge DV for the VW ...? As in do the tops just twist off and then I can pull the springs out ... ?
What color should I use? Can I just reinstall my stock DV in the same location? Thanks |
12-14-2010, 07:56 AM | #7 | |
Rep 1,809
12-14-2010, 07:36 PM | #8 | |
Rep 480
you should got all the things in the pic! Last edited by RR80; 12-14-2010 at 07:44 PM.. |
12-14-2010, 08:10 PM | #9 |
Rep 541
I think I will change my old diverter valves back in first ... Can I just take the Forge ones out and replace with the stock ones while using all the forge piping which came with the kit?
Thanks for the help. |
