Is this caused by the JB3???
12-04-2010, 12:16 PM | #1 |
Rep 78
1. Driving around 65-70 mph on the highway if I pressed the pedal to the floor the power from the jb3 was there but around 100mph the car would go into limp mode and the "engine malfunction reduced power" > light comes on I pull over turn off the car for 5 min and turn it on the > warning isn't there and the car seems to be running fine....2 weeks go by and > everything seems ok then it happens again n continues to happen every time I press the pedal to the floor. 2. I decide to recheck all the wires from the jb3 > everything is ok and all wires are connected by the tape, i keep the jb3 installed but set it at map 0 and hope for the best...later that week I'm at a stop light and the car begins car begins to shake n the revs are dropping and rising on there own so I pull in and I restart the car and it's still > shaking but now coming from the engine bay is a knocking sound and I get the following malfunctions Malfunction in transmission> > >> >> > Engine malfunction reduced power> > >> >> > At this point my only choice is to disconnect the jb3 and > reset the ecu, after returning the car back to stock the same codes are still there and the car has even less power than it did when the "Engine malfunction reduced power" light was on.... I only have 1 month of bmw warrantee left but I'm scared to take it in and even more scared to drive the car...i emailed terry the codes and he was as helpful as he possibly could be but i am afraid during the "un-install" i messed up one of the wires that have the same colors....
does anyone have close up pictures of the original bmw ecu before installing the JB3 or can tell me exactly what is written on the following wires i know its in the DYI section at n54techs but i need to kno exactly how to tell the difference between the colors for example JB3 orange: slot 6 (oxygen sensor 1, yellow/white wire with 525 stamped on insulation) so i need help with these wires..... Large black subconnector: JB3 yellow: slot 10 (boost, yellow wire) JB3 white: slot 29 (crank position, yellow wire) White subconnector: JB3 gray: slot 9 (fuel pressure, yellow/red wire, connect on all models) Small black subconnector: JB3 blue: slot 7 (oxygen sensor 2, yellow/white wire) Grey subconnector: JB3 dark red: slot 7 (throttle position, yellow/white wire. May be blue/white on 535) |
12-04-2010, 12:20 PM | #2 |
Rep 4,732
What octane gas are you using? What was your oil temp? What map were you running? Are you having long starts?
These are things we need to know. |
12-04-2010, 01:44 PM | #3 |
Custom Powder Coater
147
Rep 2,784
I'm gonna bet it's your HPFP
12-04-2010, 01:52 PM | #4 |
Rep 627
do you have an 2011 n55 stage 1. Similar problem that i just had with the jb3! I was driving home from AC half cel engine malfunction power reduced. pulled over got gas it went away. next day same thing. Went to Helix to get the codes read came up with 7 codes! 2 were tune related 5 weren't. so we took the jb3 off and i have been driving without it for a week. Going to see if there were any codes tomorrow with the car being stock. if not we will update the firmware and try again with the jb3! i'll let you know tomorrow how it goes
12-04-2010, 02:11 PM | #5 | |
Rep 78
oil temp was normal map 3 the jb3 is off...i tried retracing the steps using the JB3 pin out installation video but it is difficult because they dont say the differences between wire colors by what is printed on there.... but i need help with the wires that i mentioned before....thank you |
12-04-2010, 03:23 PM | #6 | |
Rep 4,784
ERnie
2016 BSM/f80/ZCP |
12-04-2010, 05:42 PM | #7 |
Rep 78
yes i installed the tune right and it was running perfectly for the first 3k miles after i took it off all these problems began to happen...i just finished rechecking all the wires and everything seems to fine i cleared all the codes started the car...drove about 10 min with no problems and boom the "engine malfunction reduced power" came back but the rest of the codes are gone...im taking it in to the dealer on monday morning....any suggestions of what to do between now and monday also what should i tell them happened??? I dont want to get voided....thanx guys....
12-04-2010, 05:56 PM | #9 |
The Boss
110
Rep 4,948
Drives: %E2%80%9816 F15 X6
That is what happened to mine. Didn't have JB3 but car was flashed. HPFP failure for me
12-04-2010, 06:30 PM | #10 | |
Rep 4,732
12-04-2010, 06:52 PM | #11 |
Rep 1,054
sounds like vanos to me.... any camshaft codes?? Then HPFP is the next guess...
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
12-04-2010, 10:36 PM | #12 |
Rep 1,922
Drives: E90 335i, E70 X5
my guess, bad injectors?
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
12-05-2010, 06:10 AM | #13 |
Rep 78
i got a crankshaft code...i cleared all codes again and car starts up fine and drives fine untill i enter the on ramp of the freeway and the engine malfunction reduced power comes on but that was the only one that came back...when i turn off the car the warning goes away only when i actually press down on thr gas this warning comes on....
12-05-2010, 09:09 AM | #14 |
Rep 1,565
I'm going to go with the same response when this has been brought up in 100 different threads....
HPFP, injectors, spark plugs or coil packs... This of course after you have done the typical troubleshooting steps for a piggyback.
2020 M340i: Dravit Grey Mettalic. Loaded.
12-05-2010, 09:09 AM | #15 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
12-05-2010, 09:15 AM | #16 | |||
Member
36
Rep 727
I'm going to guess the same
12-05-2010, 09:36 AM | #17 |
Rep 4,784
ERnie
2016 BSM/f80/ZCP |
12-05-2010, 11:42 AM | #18 |
Rep 83
had the same problem, took me a lot of time and money (changed hpfp for no reason, knock sensors, sparks, coils, aso ) and it was for DPFix v3, if you are using it, just give a try without it, leave alone the SES light that might come up
Procede V5, AMS FMIC, AR c-less DPs & Borla exhaust, DCI, CDV, STETT Charge Pipe+BOV, KW CoilOvers, CMGS Meth kit CM10, AR additional oil cooler, Quaife LSD, TD stage 1 turbo upgrade, RIX Gauge, ACT street clutch
12-14-2010, 06:46 PM | #21 |
Rep 1,054
HMMM what about that crank shaft code... that has vanos written all over it still. Glad to hear the car is running strong again. Keep an eye on it, don't be surprise if it pops up.
