E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Procede and SES light
      12-02-2010, 08:38 PM   #1
Castr_85M
Castr_85M's Avatar
55
Drives: AW/Fox 6MT E90 M3
I figured i'll get a faster response on here. Thanks guys
I just got a procede from you guys last monday rev 2 with v4, i'm very
happy with everything. Its far superior to my old jb3 tune in almost
every aspect. Only issue i'm having is that my SES light keeps coming
on and when i check the code with my BT tool its giving me the no cat
codes. I'm running DCI and catless downpipes. I have cleared the code
with my BT tool and with the procede and it keeps coming up. The
canclear function is on and 02 setting is at 50%. I keep getting the
code for some reason when the canclear is sopose to not even let it
show up. Please let me know what direction to take with this.
      12-02-2010, 08:47 PM   #2
OpenFlash
Drives: A Lot
Sounds like you have a very old DME software version (circa 2007/2008?). My suggestion is to get updated software so that the cat codes go pending before the SES light comes on. This gives the procede the time it needs to automatically clear the code without it every being visible. In this respect, he CANclear feature is only compatible with software versions from late 2008 and up.
If you don't want to update your DME software, you will just have to dial in that o2 modifier value. Which takes time to get it right. Start off at 50% and drop it in 5% increments if the code comes back. Don't go too low or else you will trip various o2 sensor codes.
Personally, i don't like tinkering with o2 sensor signals if i can get away with it. Doing so usually has other side-effects such as reduced fuel economy due to wacky fuel trims. Misfire is also more likely when running such a device. Because of this, I recommend the DME software update solution.
Glad you are enjoying the new tune
Shiv
      12-02-2010, 09:29 PM   #3
Castr_85M
Castr_85M's Avatar
55
Actually its a 2010 135i with the latest software put in september when i went in for a HPFP replacement. I posted on e90 because i mainly see the visnu guys on here rather then 1addicts. Maybe i have to let it adapt more? Log a couple hundred miles, this is what happend when i had my bms o2 fix, had to give it time and it just went away.
      12-02-2010, 09:36 PM   #4
OpenFlash
Drives: A Lot
Hmmm.... What is the exact code? Are you sure they are cat conversion codes (29F4 and 29F5) and not something else? CANclear should work on your car. Which means you shouldn't use the o2 modifier feature at all (leave it at 100%).
      12-05-2010, 02:03 PM   #5
Castr_85M
Castr_85M's Avatar
55
These are the codes bt tool is giving me. Car runs sound though, not stuttering or hesitation running better then ever. I dont know what these codes are or why can clear wouldnt clear them before they come up.
2C77:
2C77 Lambda probe behind catalytic converter, signal
Error will cause a warning light
Error is currently present
Test conditions have been completed
Timeout
Freeze Frame Information
Event 1Odometer 14936kms 9280miles
exhaust fume temperature behind catalytic converter bank 1 368.00 °C
resistor Lambda probe behind catalytic converter bank 1 65,280.00 ohm
voltage Lambda probe behind catalytic converter bank 1 0.41 V
time since start end 76.80 s
Event 2Odometer 14936kms 9280miles
exhaust fume temperature behind catalytic converter bank 1 400.00 °C
time since start end 102.40 s
Event 3Odometer 14968kms 9300miles
exhaust fume temperature behind catalytic converter bank 1 288.00 °C
2C78:
2C78 Lambda probe behind catalytic converter 2, signal
Timeout
exhaust fume temperature behind catalytic converter bank 2 352.00 °C
resistor Lambda probe behind catalytic converter bank 2 65,280.00 ohm
voltage Lambda probe behind catalytic converter bank 2 0.41 V
exhaust fume temperature behind catalytic converter bank 2 384.00 °C
exhaust fume temperature behind catalytic converter bank 2 272.00 °C
2FCA:
Error will not cause a warning light
Error is not currently present
Short circuit or signal interruption
2FDB:
2FDA:
2C77:
Timeout
2C78:
Timeout
      12-05-2010, 02:09 PM   #6
OpenFlash
Drives: A Lot
Solution: don't run the o2 modifier. Hardware based downpipe fixes are outdated and finicky when used with newer DME versions. Also, update your pnp harness. And leave CANclear on. That will keep your SES light from coming on from running without kitties. As suspected, the codes you were getting weren't from running without kitties. But rather from improper settings on your o2 modifier which is no longer needed.
      12-05-2010, 02:31 PM   #7
Castr_85M
Castr_85M's Avatar
55
I just got the procede on Thanksgiving week i think day before thanksgiving so it was your lastest batch. I dont know if the harness is the latest one or i have to change it.
      12-05-2010, 02:40 PM   #8
OpenFlash
Drives: A Lot
Just take a look at it. It may or may not be updates.
      12-05-2010, 10:56 PM   #9
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
I upgraded to autotune a couple months ago and just yesterday got an SES light...noticed my o2 modifier was set at 50. Interesting that it took 2 months for the SES light to come on. I just changed the value to 100 and no SES light for now...and hopefully never.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      12-05-2010, 11:35 PM   #10
Calvin@Vishnu
Calvin@Vishnu's Avatar
52
Drives: 2010 335i
o2 sensor related faults are funny like that. Which is why I don't recommend using that feature any more. Relying on CANclear as a DP fix is a much better solution. Update your harness!
      12-06-2010, 10:41 AM   #11
Castr_85M
Castr_85M's Avatar
55
Well i just checked my harness and apparently it did not have the jumper cables on the empty pins (6,7) but it did have the 2 yellow wires removed and taped. The stock harness actually does have a pin going in to the PNP harness which their was nothing there before. I'll take the car out in a lil while after i clear all codes and see if it comes back.
      12-06-2010, 03:51 PM   #12
Castr_85M
Castr_85M's Avatar
55
It worked updated my harness as per the thread. No more ses light (knock on wood) 50 miles in. Thanks shiv for the prompt responses
E90 M3 AW/Extended FR•Ohlins•Borla•ACM•K&N•IND•BBS•Vredestein•Velos Designworks•Vorsteiner•BMW Performance•Lux AE•Arkym
      12-06-2010, 05:39 PM   #13
OpenFlash
Drives: A Lot
No problem!
      12-06-2010, 11:43 PM   #14
Thumperx
Drives: 335I coupe
Shiv,
Currently I have the V3 in my 07 335i, and I'm ready to step up to the V5. But I'm concern if I have my DME updated (solving the turbo rattle), the new software will introduce throttle lag.
What are your thoughts about this new software throttle lag issue? Does the V5 compensate for the loss of power? (I'm familiar that your product has turbo rattle adjustments)
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
      12-07-2010, 12:05 AM   #15
OpenFlash
Drives: A Lot
Originally Posted by Thumperx View Post
Shiv,
One of the unique things about the Procede is that it has absolute control over the boost control solenoids and throttle valve. So it doesn't matter what BMW does to the DME to introduce lag. The Procede will over-ride it. Go ahead and get the updated. Or don't. Doesn't matter once the Procede is installed
Shiv
      12-07-2010, 08:35 AM   #16
Castr_85M
Castr_85M's Avatar
55
Shiv
So go ahead and drop that V5 like its hot!
      12-07-2010, 11:08 AM   #17
Thumperx
Drives: 335I coupe
Thanks Shiv for the advice. I will go in and update the DME.
e90post
