New ACT clutch going in on Friday - what to replace? Anyone had flywheel damage?
11-30-2010, 08:54 AM | #1 |
Rep 267
Drives: 2007 E93 Alpine white with Red
So yeah - yet another problem with my E93. I think Shiv owes me a clutch because this didn't happen with the JB3... ha
Had it slip about 4-5 times in 3rd gear at around 3k rpm's. I dont want to take any chances with the flywheel so I'm throwing in an ACT street clutch on Friday. The shop quoted me $649 for labor on the job - what are your thoughts? Is that too high? Also - they dont work on a lot of BMW's, but I know they have a ton of experience, have seen their customers cars, did my buddies clutch in an S2000 and I've watched their 7 second truck race. That being said, I want to make sure everything is covered. What needs to be replaced? Throwout bearing? Bolts for pressure plate? clutch fork? Please let me know if there is anything I need to let them know is typically replaced when the clutch is swapped. Has anyone had any issues with a slipping clutch and needing a flywheel? what are the chances I'll have hotspots and will need to replace the flywheel? MR5 and matt@cambertoe - any suggestions? Thanks!
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
11-30-2010, 10:23 AM | #2 |
Rep 5,876
More than a few people have already changed out their stock clutches including myself...i put in a clutchmasters ceramic which went after 4500km only (most likely a defective part, will find out today) but now I'm running the ACT street with my stock dual mass flywheel and so far so good...ACT street is an organic full face clutch and when mated to the stock dual mass flywheel it feels butter smooth just like stock, perfect for daily driving and plenty holding power for up to 500whp on this car...the clutchmasters fx400 was 6 puck ceramic and requires their aluminum flywheel...it holds more torque on paper and performed great for a 6 puck ceramic on this car (given how other puck ceramic clutches with lightweight flywheels perform) but its definitely way less smooth engagement wise and has chatter due to the lightweight single mass flywheel which is natural....
in terms of labour, if you get a shop that's done a clutch on N54 before it shouldn't take them more than 3.5-4 hours to do...for a shop that hasn't done it before it'll take them twice as long as they'll struggle getting the tranny down...tricky part is the 2 housing bolts at the top of the housing...basically you can barely see one of them and the other you can't at all...what we learned when I did it with a friend of mine is you kind of have to work from the top of the engine bay to get the socket on them and have a very long extension piece long enough to reach all the way down the tranny housing to the front where these two are.. best price was 350 for this but 550-600 isn't expensive if they haven't done it before...over 600 is probably a bit much to charge (not sure what they charge per hour) but if they can guarantee the install in some way then I guess its ok... |
11-30-2010, 10:27 AM | #3 |
Rep 6,473
Always replace the throwout bearing and pilot bearing. Since your in there, why not be in the market for a lightweight fly wheel. It's like killing 2 birds with one stone.
11-30-2010, 10:30 AM | #4 | |
Rep 5,876
Definitely get the throwout bearing + fork and pilot bearing replaced when you do it... |
11-30-2010, 10:31 AM | #5 |
Former N54 Fanatic
84
Rep 1,927
Drives: Slow
This. LTWFW was one of the best things I did for my E46 and would do it again in my E92. Chatter wasn't horrible... but a downside for sure. I'm happy with the stock clutch for the power I'm putting out and happy for a free replacement while I still could. Certainly a nice chunk of change that could be good towards the LSD fund.
11-30-2010, 10:35 AM | #6 |
Rep 6,473
I've actually done a couple of them with minor chatter. You'd bearly notice it chattering.
11-30-2010, 10:40 AM | #7 |
Rep 5,876
What clutch/flywheel and on what car? I can tell you that the Spec 14lb N54 alum. flywheel will chatter like a diesel truck ... the CM 16lb is MUCH better and chatters only if you go WOT under 2k rpm and obviously when idling and getting going in 1st...all I'm saying is if its your daily driver and you see a ton of stop/go traffic you may not like it, but if you don't they you'll LOVE it...enjoyment of the lightweight flywheel 100% depends on this...if the car isn't your daily driver and it won't see tons of stop/go traffic every day then its great!
11-30-2010, 10:45 AM | #8 | |
Rep 1,661
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
11-30-2010, 10:53 AM | #10 |
Rep 5,876
They work out better/worse on some cars vs. others...on this car I've run the stock clutch + 36lb stock dual mass fw (OEM), 6 puck ceramic + 16lb single mass aluminum fw, and now the ACT street organic full face clutch and the stock dual mass fw (resurfaced)...for me and this car being a daily driver seeing tons of stop/go traffic and the power the car is making today the ACT with the dual mass flywheel is the ultimate combo...when I upgrade the turbos that may no longer be the case and I may need to upgrade back to a solid flywheel...
11-30-2010, 11:09 AM | #11 | |
Rep 1,661
11-30-2010, 11:15 AM | #12 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Lightweight flywheels are good for improving the engine response. Your engine will rev quicker but it will also loose revs quicker.
You will also loose some (little bit) torque with a lightweight flywheel because you are reducing rotational mass...
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
11-30-2010, 11:17 AM | #13 |
Rep 5,876
..but it will accelerate faster (only noticeable 1st and 2nd gear)...this car has a tremendous amount of torque off the line and lightweight flywheel really has more disadvantages on the N54 than advantages...one things I did like is it made the car feel more "raw" when WOT...its like a feeling of putting on a louder exhaust...just a feeling...mostly due to more vibration through the shifter I think
11-30-2010, 12:31 PM | #14 |
Rep 2,559
Does anyone have part numbers of these two?
I'll be in the same situation within short, i.e. installation of a Clutch Masters clutch (FX300) and a shop that is good but with little BMW experience. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
11-30-2010, 12:35 PM | #15 |
Rep 5,876
Alpine, fx300 with a stock dual mass flywheel or their single mass alum?
Pilot bearing (they call it cylindrical roller bearing, goes into your tranny input shaft, inside) part num: 21207536792 You can see it here: http://realoem.com/bmw/showparts.do?...87&hg=11&fg=20 Throwout bearing and fork you don't need to worry about as you'll get them from CM... |
11-30-2010, 01:03 PM | #16 |
Rep 267
What about issues with the stock flywheel. If I was already slipping, how worried should I be about hotsopots or glazing... Also, does the act come with a fork and throwout bearing as well?
11-30-2010, 01:47 PM | #17 |
Rep 5,876
You'll only know how bad it is once you get the flywheel out...unless its really badly damaged it can be resurfaced...make sure the shop has done resurfacing of dual mass flywheels before...i've resurfaced mine but they didn't turn it...they used a grinder and clamped the top piece affixing it in place and then used the grinder to resurface it...mine was "pretty" bad when it was taken off and they had to take off .044''...working just fine...
11-30-2010, 02:38 PM | #18 |
Rep 267
That's crazy that you had it resurfaced.. Everyone I've talked to said they haven't found anyone that is willing to try it.
11-30-2010, 02:51 PM | #20 | |
Rep 5,876
i got mine done at a transmission shop chain called Mr. Transmission...only one of their locations was up for doing it... If you google around a bit you'll see that a lot of people say don't do it as its not "recommended" while those that have actually gone through with it and had it done didn't have any problems... |
11-30-2010, 04:26 PM | #21 | |
Rep 838
Some points: City driving
Drag
Drift
Race
Here's some good reading> http://www.metricmechanic.com/catalo...tion-tests.php |
11-30-2010, 04:38 PM | #22 |
310
Rep 15,745
you also have to replace the 4 transmission bolts..the m12 ones I think...they are stretched to yield and have to be replaced everytime the trans comes down.
The rest can be reused. I always replaced the throwout bearing (comes with a lever, be sure to have it on correctly if its not put together from the start), the throwout bearing lever that is in the trans bellhousing, and the pressure plate to flywheel bolts...if you are changing the flywheel then you need new bolts for the flywheel too. |
