2010 2011 BMW 5 Series Forum F10 Heated Rear Window Problem |
11-28-2010, 04:55 AM | #1 |
Rep 150
Now that the cold weather is upon us here in the UK, it`s time to start using the heated rear window. However, as you can see from the picture, there is clearly a problem with the elements in my rear window.
My local dealer has offered to replace the window, but suggest you also check out yours, apparantly this problem is not isloated. |
11-28-2010, 08:28 AM | #3 |
Rep 295
Thanks for the pics.
My E60 was the same from when I bought it (18 months old), had it 'seen to' once under warranty but it was still the same. I thought it was just poor design
E60 M5
11-28-2010, 11:39 AM | #4 | |
Rep 351
11-28-2010, 11:57 AM | #5 |
Rep 150
I totally agree. Before I had my F10, I had a 6 month old 330D convertible. I owned it for 65 days, of which over 30 of them was spent at the dealer trying to fix a water leak in the roof.....which only got worse every time I got it back! To be fair to BMW, I did manage to obtain a full refund. The thought of going through the whole episode again is something I would rather avoid.
11-29-2010, 05:45 AM | #7 |
Rep 150
I think it is correct. If you look at the pictures I posted, the top 3-4 lines are also not working.
I have checked them and I can not find the same problem as shown on the lower section. I guess a quick call to another dealer to confirm what the first said could be an option? |
11-30-2010, 12:40 AM | #8 |
Rep 7
I was supprised by this as well. I have the exact issue on my F10. I first thought that the rearwindow heating was broken. But that this is the antenna for the remote key, sounds very plausible for me.
It did not bother me a lot. At first it appeared that the heating is broken and that the factory did not check it thorougly. |
