ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      10-19-2010, 07:13 PM   #1
sunealio
Drives: Z4 M Roadster
brake cooling / ducting
Has anyone been using a brake cooling kit on Z4M? Or fabricated one with ducts, hose and backing plates?
Stock brakes are overheating with PFC-01 pads and Motul 600 fluid. A friend used brake ducts on his E46 M3 to good results, and I was looking to try the same before a big brake kit.
      10-20-2010, 03:05 PM   #2
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Yes, I have a custom designed set of duct work on mine with a BBK already installed. It really is a great improvement.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      10-20-2010, 03:27 PM   #3
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
If you can't make one, try enlarging the two inlets on the front bumper (on top of the fangs). That should let more air into the wheel well.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      10-20-2010, 09:01 PM   #4
mhrir
Drives: Very fast
The ducts are easy to open, but lets be honest... The air ducts point at the tread of the tire. It is not doing much.
I would be really interested to see some pictures to get some ideas for custom ducting. I have just purchased some parts and will be posting my ideas soon.
      10-21-2010, 02:56 AM   #5
jmillet
jmillet's Avatar
63
Drives: 2023 Hyundai IONIQ 6 SEL AWD
I run PF-01 pads and Ate TYP200 brake fluid and have never experienced any brake overheating or fade. Do a cool-down prior to bringing the car back to the paddock and things are OK. Your Florida heat and humidity may be an extenuating factor.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      10-21-2010, 07:39 AM   #6
jragan
Imola Lover
jragan's Avatar
Drives: 2007 Imola Red M Coupe
+1 WHS but I'm in 100+ degree with Texas heat and haven't had a problem.
If you had DSC on, then it's not the stock brake setup that was your problem with the brakes over heating.
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
      10-21-2010, 11:33 AM   #7
DerekSelmanRacing
DerekSelmanRacing's Avatar
Drives: 05 Z4 3.0 SMG, 01 530
You may find this helpful in addition to the cool down lap, I always pop the hood entering the pits and open it fully immediately after stopping. Engine bay heat tends to heat sink the master cylinder and abs box.
      10-22-2010, 10:35 AM   #8
3002 tii
3002 tii's Avatar
2280
Drives: Z4 M, X5, GX460
Doesn't TMS offer a brake duct kit?
Follow for latest mods
      10-22-2010, 10:50 AM   #9
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
I couldnt find any for the Z4 M on their website. There are a few for E46 M3's and for other models but i'm guessing they wouldnt fit.
      10-22-2010, 05:23 PM   #10
lucid
lucid's Avatar
Drives: E30 M3; Expedition
A difference of 10C-20C in ambient temprature will not change much. Heat transfer to the environment is proportional to t_rotor-t_ambient. t_rotor will be >> t_ambient, so driving when it's 10C or 30C isn't going to make a major difference when it comes to brake cooling/overheat, etc...
zpost
