Coolingmist and procede question
10-11-2010, 03:19 PM | #2 |
442
Rep 18,331
10-11-2010, 03:25 PM | #3 |
Rep 7,377
so if you see 11-12 you need to set the progressive to what? what does it mean 11-12 is it 1100 ml/min-1200ml/min? sorry for the hijack
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
10-11-2010, 03:32 PM | #4 |
442
Rep 18,331
11-12 is basically the max flow of debug byte 7 on the procede reader. It's the number that you plug into injection mode of the user adjustables and when this value is reached you will toggle to the progressive meth mapping system. As for the progressive spray of the meth, Shiv recommends it starting at 6-7psi and full spray at 11-12 psi.
