New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      08-24-2010, 03:08 PM   #1
Mr. ///M3 RD
Happy Camper
Mr. ///M3 RD's Avatar
Drives: C63 AMG & 280 SL on Weekends :
N54 Tune Comparison Chart includes Z435i (Detailed)
I found this in the 3 Series Forum here, it also applies to the Z4 35i ... I thought it might be of interest to some of the Z4 35i members here ....
Thanks to AltecBX Member of this Forum for posting the original Chart.
Disclaimer:
Anything aftermarket can void your warranty. Read your new vehicle warranty carefully before deciding to start upgrading your vehicle.
You are protected under the Magnusson Moss Warranty act which states that a dealer must prove that a specific modification is causing an issue before refusing warranty service. This means that they cannot outright void the warranty because you have an aftermarket mod but must prove that for instance a blow off valve is causing engine problems.
N54 Tune Comparison Chart (Detailed) Click here
To view the entire chart you need to go here ........
Here is the 3 Series Original Post
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too
---> Click here for some good stuff I found
      08-24-2010, 03:43 PM   #2
ttuner
ttuner's Avatar
67
Drives: z4
thanks for sharing. awesome info.
      08-24-2010, 05:04 PM   #3
mcbeee
mcbeee's Avatar
Drives: '09 Z4 s35i & '03 Z4 3.0i
2003 Z4 3.0i  [5.00]
2001 Z3 3.0i  [0.00]
2009 Z4 s35i  [7.00]
It only shows Dinan Stage I, Stage II requires the oil cooler and gives 78 HP and 125 ftlb's of torque. The Dinan also has "Warranty" equal to BMW, free updates and it doesn't matter if BMW finds it because they install it.
Note: All the e89's with a sport package should have the oil cooler already installed.
Member ZSCCA 2009 Z4 s35i with Dinan Stage II software, Sport and Exec packages, 19" 296 rims , a stubby and mud flaps
'03 Z4 3.0i Sterling Grey (Hers)
'01 Z3 3.0i Sapphire Black, M sport package (Mine)
      08-24-2010, 06:11 PM   #4
Memphis1
Memphis1's Avatar
Drives: Z4 SDrive 35i
Disclaimer:
that's correct info.
      09-01-2010, 07:43 PM   #5
AltecBX
AltecBX's Avatar
Drives: BMW 335xi Sedan; BMW M3 ZCP
2018 BMW M3 ZCP  [0.00]
2007 BMW 335Xi  [0.00]
Here it is guys. LINK
      09-01-2010, 08:31 PM   #6
teagueAMX
teagueAMX's Avatar
Drives: Some are road worthy
+1
I always wonder about those charts. One issue Dinan has with typical dyno testing is a lack of air movement through the front end. Most dyno shops have a small fan that cannot approximate the air movement at 70+ mph, and therefore the engine cuts horsepower.
"Political correctness is a doctrine fostered by a delusional liberal minority and rabidly promoted by an unscrupulous mainstream media which holds forth the proposition that it is entirely possible to pick up a turd by the clean end".-- Unknown
zpost
