Best Exhaust Tip Cleaner?
08-19-2010, 02:17 PM | #1 |
Rep 85
So I bought my car about a month ago and overall she's pretty clean. I wash her probably twice a week but one thing that has been bothering me are the exhaust tips.
There's just a buildup of exhaust muck on the tips that I'd like to get off. I've tried a couple of different products but nothing is cleaning them like I hoped for. Any suggestions from anybody?
AW '08 BMW E90 335i - 14% Tint | Matte Black Grilles | Red Scoops | Black Finishing Rods | L.E.D. Blacklines | DCI | CF Wrap/PlastiDip Interior
08-19-2010, 02:30 PM | #2 |
Rep 194
Eagle One Never Dull does a pretty good job for me. If it is really bad you might need some 0000 steel wool and an all purpose cleaner.
08-19-2010, 05:35 PM | #4 |
Rep 85
The steel wool won't scratch the tips at all?
08-19-2010, 08:01 PM | #5 |
Rep 6,594
I use Never Dull or P21S Metal Polishing Soap. Both work well, but the latter is really good for any metal surface (along with lots of other surfaces around the house/cars). And that $10 container will last you a lifetime.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
08-19-2010, 08:12 PM | #6 | |
Rep 635
Here's a shot of one of my tips when I was finished: I used #0000 steel wool and some P21S wheel cleaner (all I had at the time) to kind of 'wet sand' the grime out of the insides. No noticeable scratching, but I wouldn't steel wool the outside of the tips. It shouldn't be necessary to get that aggressive on the outside. I followed up the inside and outside of the tips with Nevr Dull polish. I have heard some people recommend sealing them once they are clean, but I assumed the sealant would burn off from the heat of the exhaust. Might be worth a shot, though I'm not sure. After you've got them perfect, make it a part of your wash routine to clean the tips inside and out. Should be fairly easy maintenance from there on depending on how much you drive of course. |
08-20-2010, 10:12 AM | #7 |
Photographer
40
Rep 313
I use chemical guys grime reaper and it work extremely well.
08-20-2010, 11:03 AM | #9 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
I put a tiny bit of Simple Green on a paper towel and clean my tips every day after work.
Takes 20 seconds and keeps them looking amazing. I never have to scrub or even get a sponge - just wipes right off |
08-31-2010, 08:52 PM | #10 |
Rep 1,452
Don't use 0000 steel wool on the outside of your exhaust tip. Even if you use it lightly, wet, it will eventually wear down the matte silver finish. I know this from experience...
**Added the part in red
11-15-2010, 06:02 PM | #12 |
Rep 1,423
Drives: '07 N54 e90, '10 N54 e93, TBSS
solution: get the bmw perf exhaust?
E90 - H&R Touring - M3 Front Arms - Work Genosis GS-1 19x9+30 x10+26 225f 265r stretch - AA FMIC - AR DP - Cobb E30 Map +160rwhp/+200rwtq
E93 - Style 95 - RB Turbo - AR DP - Evolution RW FMIC - PTF E50 +242rwhp/+234rwtq |
11-15-2010, 09:45 PM | #13 |
Back in a BMW
205
Rep 5,208
is it due to the exhaust fumes or the never dull
Ian
11-15-2010, 09:46 PM | #14 |
Back in a BMW
205
Rep 5,208
Ditto. Minus the first time you clean them..... mine were pretty bad and took a bunch of passes to get clean, but since then its been a 20 min job to look like new.
Ian
11-17-2010, 08:01 PM | #15 |
Rep 60
I wouldnt use the Steel wool on the OUTSIDE of the tips.. Maybe inside at most.
You would need a product to bring the shine back most likely. Its a little more aggressive strategy and should really be used after more conservative approaches have failed. |
11-17-2010, 08:47 PM | #16 |
Rep 4,494
I'm a fan of optimum metal polish. I haven't used any other metal polish ever since. It's very strong stuff!
http://www.detailedimage.com/Optimum...-P291/8-oz-S1/ make sure you put some elbow grease into it... here's a pic of some exhaust tips I did for a mercedes ML. You may be surprised to hear that all I used was an MF towel and mother's mag/alum polish. http://www.e90post.com/forums/showthread.php?t=292677
11-18-2010, 09:26 AM | #17 |
Rep 141
I use one of those green kitchen brilo pad sponge combos with car soap to clean the black gunk in the inner rim. It works great. I use the soft side of the sponge to clean the outside of the pipe.
12-04-2010, 07:33 AM | #18 | |
Rep 799
Drives: 08 335 silverback
12-04-2010, 11:52 AM | #19 |
Rep 253
This is the stuff to get....
http://www.detailedimage.com/P21S-M1...P84/105-oz-S1/ Works very nicely for me. |
12-06-2010, 11:19 AM | #20 |
Ikea enthusiast
334
Rep 8,140
Drives: '07 E92 335i
I spray a little brake cleaner on a kitchen sponge to clean the inside, and finish with an aluminum polish on a terry cloth for the outside. Works great.
12-06-2010, 05:09 PM | #21 |
Rep 175
Same experience. The matte silver finish started to get very thin in spots.
