Comment from 335i's Powertrain Project Manager about tuning 335i
01-05-2007, 11:55 AM | #1 |
Rep 30
Udo Lindner states:
"It's easy to get more boost but for a tuner it's not always simple to do it under all conditions - at cold start, when hot and at altitude, for example. And there's a problem with the exhaust downpipe. With more power it gets very hot and will break." Any comment from Shiv on the danger of the exhaust downpipe overheating and failing? |
01-05-2007, 01:08 PM | #3 | |
dat boost doe
238
Rep 1,823
01-05-2007, 04:40 PM | #4 | |
Expert Road Racer
59
Rep 1,329
PS and side note: Evo/Sti haters note the make of the turbos |
01-05-2007, 04:56 PM | #6 |
Rep 35
Downpipes are made of similar quality materials for many aftermakets. Upgrading the downpipe is usually done out of packaging necessity (for different turbine placement) rather than for reliability concerns. Putting it in a different light, likely the OP was stating the downpipe could be a problem with more power due to increased EGT. In that case, the turbo and even the engine would also be at risk. And this would be true only if the increased power threw engine parameters out of spec. With proper tuning and hardware, however, the EGTs should always be kept in spec. This is why added cooling, close monitoring of EGT, timing and A/F under varying conditions is important. You wouldnt want to mask high EGT problems with adding a larger dp IMO but would want to just make sure the timing and EGT is staying in spec.
cheers! Mike |
01-05-2007, 05:01 PM | #7 | |
Rep 30
But the Xede mode is a plug in module only ...
Hopefully, Shiv has considered this in his program, and compensates where necessary to protect sensitive parts. I'd like to hear his take on this issue. |
01-05-2007, 05:09 PM | #8 | |
Rep 35
cheers! Mike |
01-05-2007, 05:52 PM | #9 | |
Rep 4,033
On the subject, no doubt keeping EGT's in check are a must. Look what happened with the A4 BT kits and the ATP manifolds, and Hi Flow Cats. Those guys are on the edge with EGT's. But that's quite a jump from the Xede, Shiv only increased the boost by 2 psi and still got all that power!!!
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
01-05-2007, 06:13 PM | #10 | |
Rep 35
cheers! mike |
01-07-2007, 11:31 PM | #11 |
Rep 6,775
Drives: TiAg E92 335
I wouldn't stress over it too much. If you are looking to put an XEDE on your car, then installing some new downpipes (preferably catless) shouldn't be much of a problem.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
01-08-2007, 11:10 AM | #13 | |
Rep 30
Actually, I think it needs some 'stress'-ing
My understanding is the Xede unit is quickly plugged in/unplugged, and all this from the passenger's side floorboard. New hardware under the hood makes it a whole new ballgame. Also, the don't ask, don't tell dealership scenario with the warranty changes if they open up the hood and see hefty new downpipes. New downpipes on an unmodified car is not something that is done, it's done because new downpipes are needed. This is a primary issue for those considering purchasing an Xede with a car under warranty. Frankly, I'd not purchase one if it requires new downpipes, or any new hardware under the hood. |
01-08-2007, 12:46 PM | #14 |
Rep 6,775
^ Ok, I see where you are coming from, but if I was that stressed about keeping my warranty then I wouldn't modify the car in the first place no matter how much you think the dealership won't pick up on new electronics. Maybe I have this kind of attitude towards modding since I have been screwed by service departments in the past and I now do all my own work/maitenance under the hood, but if I wanted everything warrantied then I wouldn't touch it. : I guess only time will tell if the downpipes will be a potential problem, but I can't see Shiv raising the boost only 2psi and having the EGT's go out of control to the point where DP's will start cracking. I'm sure he can chime in and shine some light on the topic.
-Michael.
01-08-2007, 07:51 PM | #15 | |
technician
Rep 64
01-09-2007, 12:09 AM | #17 | |
Rep 645
01-09-2007, 11:33 AM | #19 | |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Just my 2c shiv |
01-09-2007, 11:34 AM | #20 | |
Expert Road Racer
59
Rep 1,329
Now, perhaps you could just trick the altitude sensor and have the rest automagically occur... |
01-09-2007, 02:23 PM | #21 | |
Rep 1,575
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
