335 sedan jb3
07-30-2010, 05:25 PM | #1 |
Rep 32
335 sedan jb3
does anyone here have a jb3 on a 335 sedan? how does it run?? any problems... please post your ecperience. I have a lease and heard it can set codes off.. any one have this problem..Im new to this forum so any help would b appreciated
07-30-2010, 06:38 PM | #3 |
Rep 4,732
Why would it be any different that on a coupe?
07-30-2010, 06:43 PM | #5 |
Meat Puppet
66
Rep 1,127
Drives: '11 e90 M3 Competition
07-30-2010, 06:44 PM | #6 |
Rep 4,732
07-30-2010, 09:45 PM | #7 |
Rep 4,936
it seems like you drive a 328........I think it would be a good idea to search, you could get a powerbox.
[SIGPIC][/SIGPIC]
07-30-2010, 09:55 PM | #9 |
Jerry's Fault...
175
Rep 9,258
Boopie*Motorwerks Martino*Auto*Concepts |
07-30-2010, 10:46 PM | #11 |
Boozila
17
Rep 264
The bad thing about the JB4 is that it's 4 times more expensive than a JB3. Not sure if it's worth the money yet
2007 BMW 335i, Black Sapphire, with some goodies.
I have OEM E90 tail lights for sale! |
07-31-2010, 10:59 PM | #13 |
Rep 14
i have jb3 in a 335xi sedan. i don't have access to a dyno. how do i tell if it's working? the car stock is quick already. so when i switch to map 3, i can't really tell if there's a big difference from stock. is the performance gain 0-60? top end speed?
not trying to hijack thread. i'm sure op would want to know too. thanks in advance. |
08-01-2010, 05:37 AM | #14 | |
Rep 445
08-01-2010, 10:01 PM | #15 |
Rep 227
I have a 335xi sedan and have a jb3 installed. I began running map 3 and could tell a significant difference right from the start. The car just pulled so much harder. Then I started to get 93 octane and bumped it up to map 5 and its runs even better. Maybe try reseting it to map 0 and then putting it back in map 3? Or if you have access to 93 octane give map 5 a try.
08-02-2010, 10:05 AM | #16 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
08-03-2010, 04:07 PM | #17 |
Rep 61
Drives: 2007 BMW 335i Sedan
It is Noticeable
Well, While I had my JB3 PnP, you could easily tell the difference.
2007 BMW 335i Sedan - Titanium Silver - BMS DUal Cone Intake - JB4 PnP Map 7 - ETS Intercooler = BSH Competition Oil Catch Can - STETT CP w/ DV - Macht Schnell 3" Stainless Catless Track Downpipes - BMS Downpipe Fix v3 - V1 Hardwired - SWS Subs w/Alpine Amp
//Coming Soon: Borla Aggressive Cat Back Exhaust - - FULL VC-2 Meth Injec Kit - AR Design Stage 1 Oil Cooler |
08-04-2010, 03:33 PM | #18 |
Rep 13,583
Drives: JB E92 335i
If you drive a 328 the product that you want to look at is the BMS Powerbox rather than the JB3 as they're intended for different engines. The performance gains will be the same between a coupe or sedan for either product.
If you're worried about hidden codes I would suggest that you also pick up the BT Tool Scanner which will allow for you to scan your vehicle for these codes and delete them prior to bribing the car into the dealership. Feel free to contact me if you have any questions at all! Alan************.com ************** x 8006 |
08-05-2010, 12:12 AM | #19 |
813
Rep 3,978
Make sure you depress the throttle for a good 9 seconds or so to put it in the "listen mode". And right after you get to the map you want, start the car right away to set it.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
