What'll I be running with......?
05-28-2010, 10:25 PM | #1 |
Rep 424
I'm just waiting for my mechanic to let me know when he's got time to install my latest parts.. When all is said and done, I'll have the following:
1. JB3 1.4 on Map 7 or 9 (not sure yet) 2. Dual Cone Intake 3. Front Mount Intercooler 4. 3" Catless DPs 5. Methanol Injection* * With the methanol injection, I'm not too sure where I'll have it set to "turn on" - so recommendations will be appreciated. In any event, with just 1 and 2, I ran a 12.99 and I'm sure I could do a little better (it was my first drag strip run ever). I'm REALLY curious about what type of numbers I could get with 1 through 5 installed... Would anyone mind giving me an estimate of what 0-60 and 1/4 times may be with my future setup? Just ball park figures... Thanks in advance...
Sal Collaziano
Stinger Forum |
05-28-2010, 11:06 PM | #3 |
Rep 424
I figured I'd just keep my 1.4 because I'm satisfied with it. If I were to upgrade, however, is there a specific ohm I should ask for? I haven't done any research on ohms..
Sal Collaziano
Stinger Forum |
05-28-2010, 11:50 PM | #4 |
Rep 6,631
You will have to DIY the 18ohm resistors yourself, or buy another box from BMS. They will not do the modification for you. It's critical to have the board upgrade if you plan on realizing the full potential of meth+race gas.
You need to upgrade to 2.0. You will be giving up a lot of potential and customization without it. If you have drag radials, you should easily get into the 11's with those mods, regardless of transmission choice.
E90 LCI N54 6AT
05-29-2010, 02:29 PM | #5 |
Rep 424
Okay, I'll upgrade to 2.0... But I'll just stick with the regular ohm and hope for the best. I read a little bit about it and my gut tells me there's significantly more risk of breaking something with the 18ohm resistors..
I'll have the JB3 2.0 running on either map 7 or 9, a dual cone intake, a front mount intercooler, catless DPs, oil cooler (my sport model didn't come with one stock) and methanol injection. I have sticky tires but I probably won't see those 11s until I get an LSD... When all is said and done, I REALLY don't care about having a car that's fast off the line. I prefer hitting the gas when I'm already in motion... But, I'm sure it'll be very impressive once I get the LSD installed... Some time later this year...
Sal Collaziano
Stinger Forum |
05-29-2010, 02:37 PM | #6 | |
Rep 6,631
E90 LCI N54 6AT
05-29-2010, 02:59 PM | #7 | |
813
Rep 3,978
http://www.e90post.com/forums/showth...ight=hotrod182 Interestingly enough, my Blk Sedan is almost identical, maybe a little quicker at 118mph with just Tune+DCI+100 octane. Full weight.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
05-29-2010, 05:41 PM | #8 | ||
Rep 424
Sal Collaziano
Stinger Forum |
05-29-2010, 07:34 PM | #9 | |
Rep 6,631
E90 LCI N54 6AT
05-29-2010, 07:51 PM | #10 |
Rep 424
I know that people typically advise against running two piggy back tunes simultaneously. So you're saying that on map 7 or 9, I'll get more boost by updating the ohms? Any thoughts on my "second" thoughts on DPs?
Sal Collaziano
Stinger Forum |
05-29-2010, 08:50 PM | #11 | |
813
Rep 3,978
Meth+DCI+Tune will give you awesome results. Everything else will give you incremental gains. The downpipes are not the biggest gains for ease of install/removal. But they will give you better throttle response and louder exhaust note. And all the little things add up if you are trying to be the fastest at the track. Otherwise 80% of your HP gains are easy, and the last 20% (besides nitrous) is much more difficult.
05-30-2010, 08:54 PM | #12 | |
Rep 424
Thank you, HotRod.. Maybe I should just make things really easy on myself and have my local BMW dealer install the Dinan FMIC so that's one thing I don't have to worry about dealing with for service visits.. Then install Methanol Injection and run Map 7 or 9 and see where that gets me. If I need more, I can always cross that bridge and look into Catless DPs...
I'm under the impression now that the DPs would only net me a tenth of a second in the quarter mile - and maybe that's just not worth the trouble. I cannot install/uninstall DPs myself - so if I don't deal with them, I'll be able to handle everything else in my garage for service visits. I was under the impression that the DPs would make a major difference in responsiveness.. If it's only a very slight change and only worth a tenth of a second, they're probably not worth it for me... Quote:
Sal Collaziano
Stinger Forum |
05-30-2010, 09:07 PM | #13 |
ElevenPointFive
326
Rep 2,450
Catless DPs relieve back pressure on the turbos which is important when you are pushing more boost. They certainly become a solid enabler of more power by supporting more load on the turbos.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
