Detailing again - stripping old wax?
05-26-2010, 07:58 AM | #1 |
LCI'd
257
Rep 819
Hi guys,
I last detailed my car before winter... that was my first detail... I would like to do the whole thing again, I will be using: Meg's Deep Crystal Paint Cleaner Sonus Clay Megs QD Poorboys EX w Carnauba Sonax Extreme Wax or Poorboys Nattys White My question is... do I need to strip the Nattys in any way before I use the Sonax? Can I use one over the other (say one layer of Sonax and a layer of PB ontop)? If I don't have to strip the wax in any way, can I use another layer of sealant ontop? Also, how do I go about using the paint cleaner and clay? Do I first clean the paint with paint cleaner and then clay, or vice versa? Thanks. |
05-26-2010, 10:25 AM | #2 |
18027
Rep 9,378
I'm not familiar with the products you mentioned, but:
wash clay polish alcohol wipe seal wax (if you want) wash/clay/alcohol should remove waxes so that the sealant can adhere to the clear coat. You always want the sealant on the paint, then if you are going to top with a wax do it after the sealant has bonded. |
05-26-2010, 05:43 PM | #3 |
Rep 859
If you last waxed your car before winter, there is likely no wax left on the paint at this point. Both the paint cleaner and the clay will remove any wax if there is any.
05-26-2010, 07:15 PM | #4 |
Rep 6,594
You should be good to go with that Megs stuff for removing any old wax. Does water bead on your car right now? That's the sure-fire way to tell how your coat of protection is doing - if water's not beading, there's no protection on there.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
05-27-2010, 06:33 AM | #6 |
Special Forces - Discretion is superior
31
Rep 1,011
Drives: 335i Coupe Sapphire Black
I'll throw in with the others. 1.) there probably isn't much wax left and 2.) the clay will remove whatever's left.
I wouldn't worry about trying to remove any previous wax and adding a step that isn't necessary. Enjoy the results when you're done!
M3 + trailer hitch = oxymoron
05-27-2010, 12:11 PM | #8 |
31
Rep 1,011
What wax/sealant is it that's lasting this long? Sounds pretty good to me.
05-27-2010, 04:42 PM | #9 |
Rep 36
05-27-2010, 06:21 PM | #10 |
Rep 1,168
beading isnt the only way to tell if protection is on, and it doesnt prove there is any.
I have done the tests time and time again. I have taken the nozzle off the hose and created an arch to make it HIT the hood, I've let it SHEET and RUN the water off, and I've used the hose fun with a light spray.... when letting it HIT, there was both sheeting and beading when doing the sheeting, there was only sheeting and almost no beading when using the light spray, beading was unbelieveable some sealant have a sheeting characteristic while others bead. almost all carnubas bead from my experience. if you can throw a towel on a freshly washed car and it slides across to the other side, there is a layer of protection on the paint, if it stops, there is none. Again, there are too many variables as there could be embedded junk in the towel, or the towel has a lot of nap to it causing it to stop on the paint.... I would just get into a routine to wash, clay, polish, seal 3 times a year...ALWAYS DRIVE A CLEAN CAR |
05-27-2010, 09:15 PM | #11 | |
Rep 36
05-28-2010, 10:07 AM | #12 |
18027
Rep 9,378
Eric, after the towel slides across the hood and lands on the ground, do you pick it up and finish wiping the trunk?
05-28-2010, 03:05 PM | #13 |
LCI'd
257
Rep 819
I was using PB EX and Natty's White (applied a liberal amount, had some difficulties getting it off). I don't wash my car often (once a month, maybe, due to time reasons), I am using Meg's Gold Class Shampoo (not too much of it at once), and Meg's QD. The car was not driven during winter.
On a side note, I tried the Sonax Xtreme wax on my dad's car today. It was 1000x easier to get off and on than the Nattys, and I could do the whole trunk with just a little dab, wheras the PB took two... I will be determining properties over the next weeks... At first appearance, both seem to be beading about the same, but sheeting seems to be better on the Nattys. |
07-06-2010, 07:40 AM | #14 |
LCI'd
257
Rep 819
Guys, has anyone tried letting sealant cure for 1 day, and during the day hosing it down with QD? Not wiping down, just spraying the car with the sealant on it, then leaving it to dry... it has been recommended to me by some local folks, not sure what to think of it?
TIA. |
07-06-2010, 02:56 PM | #16 |
LCI'd
257
Rep 819
Guys, I sort of have a problem... I just checked my dad's car, and I can tell the Sonax Xtreme is noticeably better in terms of water spots and dirt than the Nattys... what do I do?
