2007 Engine Tech: How the N54 works (must read!!!)
12-06-2006, 12:30 PM | #1 |
Rep 6,750
Interesting reading:
PDF Files: 2007 Engine Introduction (right-click-save-as) 2007 Engine Management (right-click-save-as) 2007 Engine Mechanical (right-click-save-as) 2007 Engine Technology (right-click-save-as) ENGINE INTRODUCTION Last edited by ksfrogman; 12-08-2006 at 09:46 AM.. |
12-06-2006, 01:01 PM | #6 |
Shadow Warrior
139
Rep 2,095
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods: PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar Installing soon: Rear Power Outlets (Happy Robot mod!) |
12-06-2006, 04:32 PM | #7 |
Rep 246
I would love to see something on the intercooler efficiency rating. Anybody seen it???????
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
12-07-2006, 05:24 AM | #10 |
Rep 29,202
Great find, thanks
12-08-2006, 09:41 AM | #11 |
From Russia With Boost
36
Rep 1,076
Anyway we can get a PDF?
2007 BMW 335i - Delivered 9/8/06
Sparkling Grpahite with Black Leather/Aluminum Trim Premium Package, Sports Package, Comfort Access. |
12-08-2006, 09:45 AM | #12 | |
Rep 6,750
12-12-2006, 11:13 PM | #13 |
The 3 Day Diet!
19
Rep 630
Drives: Space Gray e92, 88 911 Cab
Much obliged Mr Frogman
12-14-2006, 03:38 PM | #14 |
Model
23
Rep 283
Drives: Fast and Loud
Garage List 1999 M3 [0.00]
2001 ML55 AMG Desig ... [0.00] 2001 BMW X5 4.4 (SOLD) [0.00] 2003 VW Jetta 1.8T ... [0.00] 2007 335i (SOLD) [0.00] 1966 Pontiac GTO [0.00] |
Sweet.:rocks:
“No man has the right to be an amateur in the matter of physical training. It is a shame for a man to grow old without seeing the beauty and strength of which his body is capable.” ~ Socrates
12-15-2006, 02:41 PM | #15 |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Awesome info.
12-27-2006, 07:21 AM | #16 |
Rep 1,575
There is also a BMW 3D-video presenting all of these things in an impressive way. Displays in 3D enviroment the fuel that travels through the pipes to the cylinders ,the "explosion" inside them and then the way to turbines ,and out to exhaust.
I'm trying to convice my friend who works on BMW to give it to me. Then you know what will happens ,don't you?
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE Last edited by Panoz; 12-27-2006 at 07:40 AM.. |
12-27-2006, 03:57 PM | #17 |
Falling in Love with German Boost
22
Rep 298
Drives: 335i, E350, Accord EX, GSXR750
Garage List 2007 BMW E92 335i [0.00]
2007 Mercedes E350 [0.00] 1994 Honda Accord E ... [3.60] 2006 Suzuki GSX-R 750 [0.00] |
Thanks for posting ksfrogman, especially with the downloaded PDFs.
01-10-2007, 05:30 PM | #19 |
Rep 173
Personally and a number of forum members have experienced High Pressure fuel pump failures. There is a BMW SIB (SI B 12 55 06) that deals with symptoms and warranty work procedures. The Engine management PDF file has a great section and schematic of the pump as well as a great explanation of the role of the high pressure fuel system that makes the second generation DI system possible with precise fuel metering and up to 200 bar rail fuel pressure. It really helps to understand the role of the HPP and it's complexity that obviously caused the early pumps (N54's manufactured between 6/06 to 9/06) to be prone to failure.
Before my car's HPP was replaced, I experienced two episodes that were very different from each other. The first incident at 3500 miles was a case of RPM dropping briefly below 600 at idle and engine running very very rough. Since I was at a light when it happened, I pulled over, rebooted (stop engine, restart) and the problem went away. The second incident happened around 3800 miles. I was coming up a long incline (6% grade over four miles) and the engine felt like a Honda's. It wasn't rough, just no turbo boost. Again a reboot made the problem go away. Limp home mode is discussed on page 28 of engine management system which includes complete deactivation of the turbochargers via wastegate valves. I believe I experienced this up that incline. Around page 8 of the Engine Management PDF file, the explanation of Bank 1 & Bank 2blow off valves give a great insight to another major reason for lack of turbo lag beside the bi turbos and because of the DI. The main purpose of the blow off valves are to prevent pumping action and fluid dynamic problems downstream of the throttle body when driver lets go of the gas pedal suddenly, but engine management also uses them for another purpose. When the engine is idling, engine management spools up the turbos but the additional boost is relieved through the blow off valves. When power is demanded, the blow off valves are closed and the boost is already there. Viola, reduced turbo lag. This would not be possible without DI. The intake manifold downstream of the throttle body has only air in it and no gasoline, hence the blow off of compressed air back to the intake system. There is an ongoing discussion, which I don't know of the resolution about one or two oil coolers in manual vs. auto cars. Picus in Canada is especially ticked. It is interesting that the PDF files make no distinction between oil coolers in manual vs. auto cars. However, they do talk about two gear box oil coolers for the auto as well as a heat exchanger between the radiator and primary gear box oil cooler in auto cars. Shawn Phoenix |
02-25-2007, 06:47 AM | #20 |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
Thanks for posting the PDF files. This give me an opportunity to learn the engine before trying to bolt on things like a BOV.
03-11-2007, 10:55 PM | #21 |
Rep 1,217
Good info. One question I have is how is the current 335/N54 engine related to the 328 and older 330 engine? Is the 335 simple a tuned, turbocharged version of the others, or a completely new engine altogether?
