End all be all explanation of the 335i's turbos?
12-06-2006, 12:00 PM | #1 |
Rep 22
Hey all, I have just finished searching through this forum for a thread related to exactly how the turbos on the 335i are set up and how they can produce no significant turbo lag, but to no avail.
Is there a thread or a website with an explanation somewhere that goes in to excrutiating detail on how these turbos on this particular vehicle are set up and what makes them so....juicy? I'm an engineer by schoolin'(although electrical), so this kind of stuff gets me excited. I've wikipedia'd turbos in general, but it doesn't address specifically how these 335i turbos produce no lag... Much appreciated. Chad |
12-06-2006, 12:26 PM | #2 |
Shadow Warrior
139
Rep 2,095
This thread might help, some info scattered throughout:
Official: N54 engine with Bi-Turbo 306HP, 400Nm ...
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods: PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar Installing soon: Rear Power Outlets (Happy Robot mod!) |
12-06-2006, 12:37 PM | #3 |
From Russia With Boost
36
Rep 1,076
They are small, and they are set up to only "power" 3 cyliners at once.
It does not require much flow to speed up the smaller turbine, thus turbo lag is reduced. I dont really know what else there is to say.
2007 BMW 335i - Delivered 9/8/06
Sparkling Grpahite with Black Leather/Aluminum Trim Premium Package, Sports Package, Comfort Access. |
12-06-2006, 12:49 PM | #4 |
Rep 6,750
The link Ninjaneer gave is good. I just posted the N54 tech info in one place:
http://www.e90post.com/forums/showthread.php?t=38856 There are many factors that improve the throttle response and help to eliminate turbo lag. Perhaps the most important one is BMW's use of two small turbochargers in parallel. The smaller the turbocharger, the less energy it takes to spin the turbine. So it takes less time to spin and achieve the desired boost pressure. As a result of high rotational speed, the turbochargers get very hot. So BMW uses not only engine oil, but engine coolant to cool them down. Another interesting technology is the use of direct injection, which helps cool down the cylinders during air/fuel induction, which allows the use of relatively higher compression ratios in a turbocharged car because of the increase in available oxygen. Said another way, the fuel is evaporated and atomized in the combustion chamber. This "cooling effect" allows an increase in air density; hence, more oxygen, which improves efficiency and engine power. It also means that there would be no condensation of fuel in the intake manifold, which would lead to inefficiency. The throttle body assembly now uses a lighter plastic valve instead of an aluminum one with a much more sensitive actuator sensor to give the car's computer better input, and to improve responsiveness. Throttle valve position in addition to intake-air temp, engine speed, ambient pressure, intake-manifold pressure, and pressure before the throttle valve influence the N54's control over the engine's boost pressure. |
12-06-2006, 01:05 PM | #5 | |
Falling in Love with German Boost
22
Rep 298
Drives: 335i, E350, Accord EX, GSXR750
Garage List 2007 BMW E92 335i [0.00]
2007 Mercedes E350 [0.00] 1994 Honda Accord E ... [3.60] 2006 Suzuki GSX-R 750 [0.00] |
I found this interesting about the 335d
http://www.caranddriver.com/features...-update-1.html Quote:
12-06-2006, 01:16 PM | #6 | |
Rep 6,750
12-06-2006, 01:37 PM | #7 | |
Rep 22
BTW, thanks for the info, that's exactly what I'm looking for. |
12-06-2006, 01:42 PM | #8 | |
Rep 12
Actually, they dont each power 3 cylinders, they are each powered by 3 cylinders, and then boosted gas is combined before it goes into the intake manifold. |
12-06-2006, 01:49 PM | #9 | |
Rep 1,826
Drives: E92 335i
12-06-2006, 01:55 PM | #10 | |
271
Rep 6,510
12-06-2006, 01:56 PM | #11 | |
Rep 6,750
12-06-2006, 02:13 PM | #12 | |
22
Rep 298
12-06-2006, 02:18 PM | #13 |
Rep 5,501
Wonder what the exact stock boost pressure is...[/QUOTE]
I believe its 8psi.
2007 E92 Montego Blue 335i
12-06-2006, 02:21 PM | #14 | |
22
Rep 298
I believe its 8psi.[/QUOTE] Are you referring to the 335i or 335d? |
12-06-2006, 02:21 PM | #15 | |
Rep 6,750
12-06-2006, 02:29 PM | #16 |
Rep 20
I read somewhere that the turbo’s are VGT’s, variable geometry turbos. What this means is that the pitch of the vanes changes through out the rpm band. This allows them to spool faster, as well as, also being method to control boost.
12-06-2006, 04:29 PM | #17 | |
Rep 6,750
12-06-2006, 07:31 PM | #18 | |
Rep 29
12-06-2006, 08:16 PM | #19 | ||
Rep 6,750
Check out this "E92 Official Press Release" thread: http://www.e90post.com/forums/showth...iable+geometry Now there was talk about a diesel engine and variable turbine geometry here: Quote:
12-06-2006, 10:09 PM | #20 |
N54 FTW
Rep 76
Lets set the story straight:
Porsche 997 Turbo is the first GASOLINE production engine to use VTG turbos. High exhaust temperatures from the combustion of gasoline have in the past made the implementation of this technology troublesome but the use of higher quality materials in the turbos allow it to be used. VTGs are not used on the N54 gasoline engine. They may very well be used on the diesel engine in the 335d though as most all modern turbo diesel use them; even the VW TDI engine uses them. |
12-06-2006, 10:19 PM | #21 | |
Rep 1,084
http://en.wikipedia.org/wiki/Variabl...y_turbocharger |
12-07-2006, 10:59 AM | #22 | |
Rep 213
Which makes me wonder how exactly the turbos are balanced flow-wise, and what happens if one compressor is weaker than the other? |
