Washing applicator between applications?
08-30-2005, 07:12 AM | #1 |
Rep 84
I received my Zaino kit today and am planning on applying 3 coats of Z2/ZFX and Z6 over a 2 day period.
How do you guy's clean the applicator between coats or do you use 3 separate applicators. (6 if also applying Z6 between each coat of Z2) Thanks
2006 330i, Alpine White, Black Dakota Leather/Aluminium Trim, Manual, SP, PP, Nav, PDC
08-30-2005, 11:30 PM | #2 |
Custom User Title
17
Rep 215
I used the same applicator to put on two coats in the same day. Then waited a couple weeks and put on another coat using a new applicator. I suggest a cotton cloth or towel for the Z6 (actually two - one for applying the other for buffing), not the Z2 applicator.
These terry covered sponges can be cleaned up and re-used a few times - I've run 'em through the washer before. The zaino is good stuff - have fun polishing your car! . |
08-31-2005, 05:47 PM | #3 |
17980
Rep 9,377
I used one applicator for the Z2/ZFX, then washed it (and the little bottle) with a Dawn solution, then applied the Z6. No need to wash between Z6 and Z2/ZFX, since they reccomend you apply either water or Z6 to applicator before Z2/ZFX.
I've put 3 coats of Z2 on my car, plus numerous Z6 coats, and have worn one applicator out. It torn along the seams. |
09-02-2005, 01:51 AM | #4 |
Rep 524
I did my first Dawn/clay bar/Z2/Z6 and noticed I missed a couple of (water?) spots on the hood. Any way to get rid of these without starting completely over? Thanks in advance.
Realtor Mobile: 6spd / Sport / Prem / Navi / ED 3-30-06 73 3.0s/84 528e/90 525i/97 M3 4dr/99 M3 Conv/2001 330i/2004 545i ED/2006 330i ED June 05 You're in control...is there anywhere you want to go ? ------------------------- |
09-05-2005, 02:29 AM | #6 |
Rep 524
Thanks Wede...I'll try that. I've also noticed some small micro scratches in the clearcoat on one panel....looks like someone brushed up against the car with a metallic object.....barely noticeable but what will take those out....clay? Or do I need another product like 3M Imperial Glaze? I've tried a search but I'm a lazy bum. Thanks again.
By the way...after about 5 days with the first coat of Z2/Z6 my car seems to not only look great but I think that it STAYS cleaner now....especially the hood. Does Zaino repel the dust??
09-05-2005, 03:07 AM | #7 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
