2010 E92 Owners: Do you have that cloth thing under your hood?
05-17-2010, 10:02 PM | #1 |
Rep 1,830
Okay. So I got my new 2010 335i coupe today and I'm ecstatic about having such an amazing car!
Since it's my first night with the car, I'm going downstairs and getting in the hot garage staring at it every 5 minutes. 10 minutes ago, I opened the hood. I noticed that it didn't have that cloth thing (sorry for not knowing the technical name) under the hood. Does anyone else have that? Is it something they removed from 2010? Do I even need it? Oh, and before someone posts that THIS THREAD IS WORTHLESS WITHOUT PICS emoticon group, here you go: |
05-17-2010, 10:13 PM | #2 |
Rep 261
I had always assumed it was for noise dampening. Maybe they put it inside the hood? Maybe they thought it wasn't necessary? Or maybe you just got screwed. You're car definitely isn't going to blow up with out it.
///2007 335i Coupe Space Metal Gray///Sports///Premium///6AT///Piano Black Forgestar 18" F14 8.5" front 10" rear///JB3///Cooling Mist CMGS Methanol Kit///aFe DCI///Stett Chargepipe///Tial BOV///BSH Oil Catch Can
05-17-2010, 10:21 PM | #3 |
Rep 1,938
Congratulation on your car. In case you wanted to trace when the under hood pad disappeared, I have 335i MY209, and the pad you are concerned about is absent. There was at least one thread you can search for where people raved about the pad, most of them assuming that the pad was there as heat insulation and was removed as an economy measure. Another possibility, which I share, is that the pad was deleted to give the car a more sporty voice. It is known that BMW tests their cars in an acoustic chamber to optimize the sound the cars produce. If you wanted to make the car quieter, you can order the pad from a BMW dealer and install it.
05-17-2010, 10:23 PM | #4 |
Where'd my VTEC go?
481
Rep 6,067
Removed as of March 2009 production, along with the smoker package and other little things.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-18-2010, 05:58 PM | #6 | |
Rep 1,292
I just traded in a 2007 335i coupe that had the pad for a 2011 335i coupe that does not have the pad and I can't notice any difference in engine noise when driving. |
05-18-2010, 06:00 PM | #7 |
Where my bitches
743
Rep 1,924
Drives: Cadillac coupe deville
that cloth was if the motor caught fire it would melt the pins holding it up and fall on the motor to put the fire out
05-18-2010, 06:39 PM | #8 |
Rep 2,982
05-18-2010, 06:55 PM | #9 |
Rep 1,179
05-18-2010, 06:57 PM | #10 |
Where my bitches
743
Rep 1,924
that was actually common knowledge, im full of useless knowledge, that becomes useful every once in awile
05-18-2010, 09:20 PM | #11 | |
Rep 1,465
So for the first 3 years, they didn't know whether or not the engine could possibly catch fire? |
05-18-2010, 09:24 PM | #12 |
Where my bitches
743
Rep 1,924
they probably realized that if the motor catches fire it would be to expensive to repair and the car would be totaled on insurance anyways, so it became pointless
05-18-2010, 09:51 PM | #14 |
Where my bitches
743
Rep 1,924
not this particular instance, that cloth cost them $50 probably. They just realized there wasnt any point to save the engine, if it catchs at all it will be to expensive to repair and might as well just total the car. They also probably did it to make the motor louder to give it a more aggressive tone.
05-18-2010, 10:02 PM | #15 |
Rep 23
I think it saves the paint on the hood.
I noticed a circle in the paint on my Tundra's hood which did not have the pad. The circle in the paint started to appear after 2 years and it was right in the middle of the hood. You could really see the change looking at an angle when the truck was in the garage with over head lights on. |
05-18-2010, 10:18 PM | #16 |
Rep 4,494
it was deleted as a cost-cutting measure, along with other things.
on a sidenote, glad to see you got a 335i over a 328i (saw your other thread)
05-18-2010, 10:24 PM | #17 |
Rep 2,982
They probably decided that they don't need to waste money on this since an engine fire is going to ruin things anyways but the lack of this lining probably didn't do that much to affect the overall safety of the situation or the damage. Hence I'm sure they just ditched it and decided to save $. It probably has the smallest affect on sound dampening after cost cutting and fire containment.
05-18-2010, 10:52 PM | #19 |
Rep 3,556
parking in the sun will get the paint way hotter than heat from the engine bay.....
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
05-19-2010, 02:19 AM | #20 | |
Rep 1,830
05-19-2010, 06:47 PM | #22 |
Rep 1,830
