E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Going to put a 3'' turbo back exhaust on my 335
      12-04-2006, 09:56 PM   #1
jgannonloans
FOR SALE
jgannonloans's Avatar
15
Drives: jet black 335i
thats right all exhausts so far ar 2.5", we're gonna custom up a 3'' turbo back exhaust, going to use the stock cats if possible too
      12-04-2006, 11:32 PM   #2
NaViT
NaViT's Avatar
Drives: 04 M3/E92 335i
go for it..
      12-04-2006, 11:58 PM   #3
Ray
Member
Ray's Avatar
306
Drives: three series
Sounds fun. Are you keeping the stock muffler?
I'm sure the cat restricts a lot of flow. Especially if they remain at 2.5in.
      12-05-2006, 12:22 AM   #4
jgannonloans
FOR SALE
15
no getting rid of everything probably freeing up a couple 100 pounds too.....if you look under the car the stock cats are about 3'' or so and we're gonna just modify the new exhaust right into the stock cats, im sure that they are just as good as after market high flow cats
      12-05-2006, 12:24 AM   #5
mr2guy
N54 FTW
mr2guy's Avatar
Drives: 2008 BMW 535xi Wagon
So I'm guessing you'll be using a 3" turbo-back for each turbo (meaning two separate pipes) or are you going to merge them into one 3" pipe? Any specific muffler(s)?
2008 BMW 535XI WAGON
Sapphire Schwarz on Schwarz
      12-05-2006, 12:34 AM   #6
jgannonloans
FOR SALE
15
yeah two 3'' downpipes from the turbos, i forget the name of the muffler but its good shit stainless and weigh like 8lbs each
      12-05-2006, 07:28 AM   #7
TheAcAvenger
TheAcAvenger's Avatar
Drives: 2018 R35 GTR / 2007 E92 335i
Jgannon,
I'm looking into a custom setup as well. I was going to go with Apexi N1s because they offer an exhaust control valve that can be controlled from the drivers seat. (VA has ridiculous exhaust laws, so I could really use the ability to be stealth or speed with the press of a button).
I figure you can help me out on this question. They offer two types. NA with a 2.36inch "inlet" and a a 3.54inch "tip" and a Turbo with a 3inch "inlet" and a 4.53inch "tip"
When they use the words "inlet" and "tip", does "inlet" refer to the diameter of the opening, with "tip" referring to the length of the tail of the muffler?
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
      12-05-2006, 09:00 AM   #8
herbz
hi
Drives: '86 325e
finally. wanna see what this car is REALLY capable of sounding like
      12-06-2006, 01:34 AM   #9
jgannonloans
FOR SALE
15
not really sure about that particluar brand, but you can customize any setup just as long as it fits....they way i see it is why not go 3'' if it will fit, faster!!!
      12-08-2006, 06:59 PM   #10
jgannonloans
FOR SALE
15
burns stainless steal exhuast all custom made 3" turbo back utilizing the stock cats!!!! the mufflers weigh 2lbs a piece!!!
      12-08-2006, 08:23 PM   #11
SayBBye
SayBBye's Avatar
Drives: Soon to Be
Originally Posted by TheAcAvenger
Jgannon,
The inlet is the portion of the canister in which the piping ill be connected to. So if something has a 2.5 inlet then that is the width of the inlet, meaning you would probably want to run 2.5" piping. The tip is what will be sticking outside of your rear bumper So the bigger the size of the tip then the bigger the two holes in the back.
2007 BMW 335i - On The Way
2007 Toyota Yaris - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla Hatchback - Sold
      12-08-2006, 08:28 PM   #12
SayBBye
SayBBye's Avatar
Drives: Soon to Be
Glad to see someone is finally going to test out something bigger then a 2.5" system for this car. I'm curious to see if maybe 3" is going to rob some low end power due to the size of those turbos and the amount of exhaust air traveling through the piping. If it does rob power on stock boost levels then maybe a 70mm system would work best.
Have you thought of maybe also trying going from two 3" systems from the cats then joining then into one 3" pipe till the end? This could posile help better the overall flow pressure and show better results if the other system shows losses.
either way top end increase is going to jump very high.
      12-09-2006, 12:35 PM   #13
jgannonloans
FOR SALE
15
i really don't think that it will loose anything, just my assumption...those S4 guys put 3'' all day long. i thought of doing 2 pipes out of the turbos and joining into one, but i think that 2 separate pipes will flow better. If anyone is interested check out my thread http://www.e90post.com/forums/showthread.php?t=39164 this will be a bad ass system
      12-14-2006, 03:54 PM   #14
denverlicious
Drives: 05 evo
us evo guys only use 2.75 or 3" anything less would be uncivilized.
but when i get my 335i i'll have to research more on this 2.5 vs 3" thing.
e90post
