05-14-2010, 08:15 AM | #1 |
Certified Adrenaline Junkie
42
Rep 1,325
Share Your Alignment Specs
I just got my alignment done last night and wanted to share the info. I've seen that other people posted their alignment info in other threads but thought it might be handy to consolidate it into one. Here are my setup, specs and impressions.
Stock Suspension Impressions: Haven't driven the car much since I got it done but turn in feels stronger. I will report back after a run through the twisties. Last edited by Blind32; 05-14-2010 at 11:50 AM.. |
05-14-2010, 10:53 AM | #2 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Mine with H&R lowering springs:
Front Camber: -1.7(-1.6 on right)Pins pulled Caster: 6.2(6.3 on right) Toe: -1/16" Rear Camber: -1.5 Toe- 1/8" Note: This is a setup for these springs.
[URL=http://imageshack.us/photo/my-images/153/071jt.jpg/]
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
05-15-2010, 01:54 AM | #3 |
Custom User Title
141
Rep 661
KW V3 Coilvers, 15mm drop, stock wheels, 225s front, 265 rears. 95% street driving.
Front Camber: -2.6 L, -2.6 R Front Caster: 6.0 L, 6.2 R Front Toe: 0.05 degrees inwards, both sides Front camber was achieved without plates by using the Turner camber bolt kit mentioned on another thread here. Rear Camber: -1.6 L, -1.6 R Rear Toe: 0.04 L, 0.03 R Car turns in smartly and holds the road freakin' great. Just a hint of understeer left at the limit. Corner balancing coming next week ; ) Last edited by blender; 05-15-2010 at 02:05 AM.. |
05-19-2010, 11:30 AM | #5 |
Skull Squadron Leader
304
Rep 2,031
Ground Control Coilovers on 245/35/19 F and 275/30/19 R tires.
Alignment set to street driving: Front L&R: Camber = -2.1 Caster = 7.7 Toe = 0.00 Rear L&R: Camber = -1.8 Toe: in 0.15 |
05-19-2010, 01:08 PM | #6 |
Rep 1,224
Rick, how's your inside tire wear with these settings?
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
05-20-2010, 12:19 AM | #7 |
304
Rep 2,031
So far so good. I unfortunately don't take her out as much as I once did, so there's not enough miles since the alignment to really give a good answer. I DID want a more aggressive street setup though, and it's definitely noticeable (handling). I still figure the tires will expire before they wear out.
BTW... only have done about 1000miles since alignment (2 months ago), to put it in perspective. |
