Help: Debadge residue or paint issues
04-26-2010, 02:35 PM | #1 |
Rep 144
I just debadged my car yesterday and i got all the residue off but it looks like i messed up the paint or something. It does not have a polished glossy look anymore, it looks sort or swirly matte. Any ideas? I used rubbing compound and then waxed it...
04-26-2010, 02:41 PM | #2 |
Rep 268
Rubbing alcohol ruins paint, goo gone and a hairdryer/heatgun works as well. As for the paint you might be able to salvage it with a detailing and good buffing but I can't tell you for sure since i can not see the damage done.
04-26-2010, 02:43 PM | #3 |
Rep 7,433
Do you happen to have a picture of it so we can see?
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
04-26-2010, 02:58 PM | #4 | |
just another bmw douche bag
195
Rep 3,640
A good detailer should know how to fix it though, so you might want to give that a try. |
04-26-2010, 03:32 PM | #6 | |
Rep 293
Goo gone or quik detail work great. |
04-26-2010, 03:36 PM | #7 |
Rep 210
Try using a light cut polish, hoping that you did not actually already rub your way through the clear coat and then re-wax. Maybe something like McGuire's Scratch X. If you have a small orbital you can apply with that as doing in by hand will not give nice even results unless you work at it for a while and most polishes I have used in the past needed some heat via vigorous motion to activate the polishing compounds in the polish you are using - thus an orbital is the way to go (it also randomizes polishing motion to prevent you from adding additional imperfections to the paint while trying to remove existing ones by using a repetitive motion in one direction).
If you don't have an orbital take it to a reputable detail shop and have them polish it. Then don't use the rubbing compound again - not typically the best thing to use on clear coat in my opinion - to abrasive/aggressive and more likely to get you into the type of trouble you have wandered into. You may also want to post this question in the Detailing forum - I am not a professional but there are pro's in that forum that may be able to offer better advice.... |
04-26-2010, 04:15 PM | #8 |
Rep 489
I have never heard of the rubbing alcohol taking away the clear coat - with that said, the wax layer is probably stripped down to the clear-coat.
Like others have suggested, check a detailer forum for a product to fix it. GL PS I don't know how much you really worked the alcohol into the paint, but reasonable amounts won't hurt the car* |
04-26-2010, 06:40 PM | #10 |
Special Forces - Discretion is superior
31
Rep 1,011
Drives: 335i Coupe Sapphire Black
He said he used rubbing compound, not rubbing alcohol. Rubbing alcohol in my experience does not harm paint.
M3 + trailer hitch = oxymoron
