Take 5: Vishnu 335i - Finally tested the Vishnu Stg 1 "kit"
11-18-2006, 11:15 PM | #1 |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Until now, we've done all our tuning work on my personal 335i. It was one of the earliest cars to the dealer. It never had its ECU updated with the programming update. And it saw a lot of the trial and error process during the tuning adventure. Everything from the boost control solenoid we used to how the Xede was installed as all custom one-off.
Today we finally had the opportunity to install the "kit" version of the Xede on a customer's car (imsambeen). This means that the Xede was installed right next to the ECU, under the ECU cover, away from prying eyes. There was absolutely no wire cutting, drilling or anything nonreversible involved. The Xede installation process itself took about 15 minutes. Yesterday, Sam drove up from LA. The poor guy left LA at 2AM and meet up with me at the dyno shop in the morning. Having recently taken his car to the dealership for the ECU update, we were very curious as to how it would fair, in stock form, to my non-updated 335i (when it was stock, of course). The results varied between 264-270whp and 283-285lbft. This was 7-10whp and 5-6lbft less than my personal car. The differences are reasonably small and could possibly be accounted for by statistical variance. Or the ecu update is just a bit more conservative. Regardless of lower numbers or now, we're here to tune it! Not to pout over low baseline numbers After the baseline dyno result, the work began. One of our fabricators built a full dual 2.5" exhaust. Just like the one on my car except that it had a X-pipe integrated in it (customer requested it). Sounded and looked nice. The next morning, the Xede "kit" was installed. Then the tuning began. Running the same very Xede map that I run in my car, Sam's 335i put down 325whp and 350lb-ft of torque. Real close to what my car did. After some custom tuning, we got it to 330whp and 357lb-ft of torque. Just 3-4whp lower than mine. I suspect this is attributal to the X-pipe which does introduce some exhaust backpressure/turbulence compared to a fully divorced exhaust set-up. But for a car that started off making only 265whp and 283lb-ft of torque, I"m really happy with the results. Here the are: Sam's 335i Stock Vs. Stg 1 (Xede and exhaust) [pls note that hp and torque axis are scaled differently] One thing we found out during the testing is that non-Sport packaged cars wont rev out all the way to 7000rpm in 4th gear due to the lower max speed limiter. This is why the dyno graph only goes up to 6300rpm. Just gotta take my word for it since the bottom of the page got truncated by the printer Just in case you want to compare Sam's Stg 1 car to my personal Stg 1 car (with sport package and higher speed limiter), check it out... Sam's Stg 1 Vs. Shiv's Stg 1 Like mentioned earlier the only hardware difference between the two cars is that Sam's car had an X-pipe joining both exhaust pipes together whereas my exhaust is completely divorced all the way from turbo to tip. I suspect this is why Sam's car makes slightly less top end power. Although it's really hard to notice on the road We have two more customer cars to tune this upcoming week (Xede only, no exhaust) and will report the results as they come in. Cheers, shiv www.vishnutuning.com Last edited by OpenFlash; 11-19-2006 at 12:48 AM.. |
11-18-2006, 11:21 PM | #2 |
Rep 133
Excellent work! What does the new kit look like installed, and will it void the factory warranty? (will the black box know what's going on?).
11-18-2006, 11:52 PM | #4 |
Rep 4,163
thats amazing..... i really want a 335i now!
how much does it cost for the exhaust and xede?
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 |
11-19-2006, 12:15 AM | #6 | |
1736
Rep 17,960
Drives: A Lot
335e90-- We didn't not install the switch in Sam's car. That'll come sometime in Jan or Feb, along with the ship-able production version of our exhaust. We still have to mold an insert for the ash tray to house the switch and remote LED. uhaulball-- Until the next of the year, we're offering free installation and tuning. So the full turn-key price for the Stg 1 kit (Xede and Exhaust) is $3000. Likewise, the Stg 0 kit (Xede only) is $1300. Install and tuning will add another $500 starting Jan. 1st. Cheers shiv |
11-19-2006, 12:32 AM | #7 |
Rep 7,076
ok so, if i get the xede only right? and letting u guys tune the car, and there is sth wrong with the car all of the sudden and i am going to send the car back to the dealer, so i need to remove the xede but the problem is here, for the xede after remove do i need to tune it back to normal mode?
and how about this, after the fix from the dealer i wanna install the xede again....do i need to get it tune it again? |
11-19-2006, 12:48 AM | #8 |
Rep 122
hey shiv, i noticed that sam's car's horsepower starts to drop as it approaches redline a little more than yours. is that a result of the lower redline or something else entirely? one of the great things about your intial tune was that it didnt seem to lose horsepower quite as much as stock as it approached redline.
__________________________________________________
Future ED Car: E92 335i Montego Blue w/ Black leatherette and Grey Poplar Sport Package, Navigation, Bluetooth, Sunshade, Heated Seats, 6 mt BBS RG-Rs |
11-19-2006, 12:52 AM | #9 | |
Rep 133
Getting better all the time...
11-19-2006, 01:10 AM | #10 |
Rep 963
Q#1: Defer to Shiv Q#2: The switch allows you to change what map you want to use(think e60 M5) Q#3: The dyno shown above is with exede AND exhaust. I don't think he has had a chance to test the exhaust by itself. Q#4: He doesn't go to the track, he will have numbers as soon as one of his customers reports back to him. |
11-19-2006, 01:10 AM | #11 | |
Rep 7,076
I believe the answer for the 0-100km is 4.1-4.3 secs with Xede and exhaust |
11-19-2006, 01:17 AM | #12 | ||
Borti
Rep 114
Very good looking curve. Lots of useable power. I cannot wait until my 335 gets in. Thanks for all of the hard work from all of you guys!
11-19-2006, 05:02 AM | #15 |
Rep 774
Drives: E90 335i & E60 550i
Was Sam's car a stick or auto?
Also, what are the chance's that you will release an exhaust for the E90 335i? |
11-19-2006, 05:27 AM | #16 |
missing two turbos.
577
Rep 4,859
Drives: fast around corners.
I also want to whether sam's car was Auto or stick.
As far as upcoming customers go, any of those cars auto? btw, graph looks great. gains look promising. I really want to see the result without the exhaust(stg 0). If I do get my hands on the 335i, I really don't want exhaust...
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
11-19-2006, 10:20 AM | #18 |
From Russia With Boost
36
Rep 1,076
Yeah, he mentioned that an aftermarket exahsut just by itself, is not very productive in term of power gains.
2007 BMW 335i - Delivered 9/8/06
Sparkling Grpahite with Black Leather/Aluminum Trim Premium Package, Sports Package, Comfort Access. |
11-19-2006, 10:21 AM | #19 |
36
Rep 1,076
P.S.
imsambeen, where are you!!!!!
11-19-2006, 10:24 AM | #20 |
Rep 1,600
Drives: e90 335i
Nice work again Shiv
Concerning this: One thing we found out during the testing is that non-Sport packaged cars wont rev out all the way to 7000rpm in 4th gear due to the lower max speed limiter. This is why the dyno graph only goes up to 6300rpm. Is there a reason why you wern't able to correct this and make the non-sport car the same as Sport by allowing it to rev to redline in 4th through 6th and get the speed limiter to 155. I recall you said you wouldn't remove the 155 limit but I can't see why you wouldn't tune the non-sp to match the Sp unless it adds a deal of complexity. Can you comment please. Thanks, Kevin |
11-19-2006, 10:36 AM | #21 | |
Rep 1,600
Drives: e90 335i
