Vibration at High Speeds
03-27-2010, 12:18 PM | #1 |
Rep 15,818
I installed 20mm spacers about a week or so ago
and lately (past 2-3 days) whenever I go over 80 mph, I feel a slight shaking.. I can easily notice it since my V1 shakes to a point where it has never done in any of my previous cars (plus the steering shaking) Now, I was wondering if it's the spacers... they are the only variable I can think of The bolts are tight.... i don't know the brand of the spacers Thanks for any input.
03-27-2010, 12:26 PM | #3 |
Rep 7,089
Drives: '06 AW 330xi
Maybe you need an alignment but just adding spacers shouldn't put them that out of spec.
03-27-2010, 04:22 PM | #7 |
Where my bitches
743
Rep 1,924
Drives: Cadillac coupe deville
yeh the shop that installed my v714's on my e90 put the spacers on the front instead of back like idiots and it would shake like crazy at 70 mph, took it to another shop and they put them on the rear /problem
03-27-2010, 08:59 PM | #8 |
Rep 37
03-29-2010, 05:06 PM | #9 |
Rep 15,818
they're in the rear, not the front
would I need to realign the car cause of the spacers? if so, I'll just take them off.. I am going to put my stocks back on and test it out to see if that is the problem if the problem persists, then I'll take it to the dealer if it goes away, well, I'll know what the problem was.
03-29-2010, 05:39 PM | #10 |
just another bmw douche bag
195
Rep 3,640
take off the spacers and see if it goes away. Also be sure to clean the hub surfaces very well with a wire brush or scotch bright pad before you install spacers. You need to be sure there isn't any debris getting in between the hub and spacer. even a tiny piece of rust stuck between the hub and spacer can cause an imbalance issue at speed.
03-29-2010, 08:24 PM | #11 |
Rep 445
Also, make sure the spacers do not have burrs and/or nicks. If yes, carefully file them off with a fine file. I have been using 10-12 mm spacers on the rear wheels on my two last cars and never experienced any disbalance. |
03-30-2010, 12:21 PM | #12 |
Rep 15,818
Thank you everyone
I'll take them off tonight and clean them up and install them again :P
04-01-2010, 12:04 PM | #13 |
Rep 22
Just wondering the outcome of this. I have the exact same problem with my 135i with the stock 18" rims (i.e. no spacers). With the wheels recently balanced, could the problem be an irregularity on the wheel where it meets the hub?
04-01-2010, 12:32 PM | #15 |
Rep 22
Bought it used and experienced the problem driving it home from the lot. IF my rims are bent, they were bent when they sold me the car... Of course since you said beautiful rims I'm assuming you are referring to the OP
04-01-2010, 12:36 PM | #16 |
Rep 3,807
Drives: Retired 2017 F87 M2
maybe the spacers aren't hubcentric?
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue| |
04-01-2010, 04:29 PM | #17 |
Black Mamba
66
Rep 1,326
rebalance your wheels
04-01-2010, 05:28 PM | #18 |
aka Mike
106
Rep 1,395
I had the same problem with my spacers. Its seemed that they would accentuate any slight off balance in my wheels.
1. Professionally re-balance your wheels (after you clean them). 2. Clean all the metal to metal surfaces that the spacers touch with a wire brush and use some light auto grease or WD40 before re-installation. If the spacers are off brand then you may look into the possibility of them being warped. |
04-22-2010, 03:29 AM | #19 |
Rep 3,868
Drives: E93 335i
Your wheels weren't balanced properly. If possible try to find a shop that have wheel on the car balancer. Be aware when wheels get balanced on the car if at any time they're taken off and put back on they'll need to be re-balanced.
And/or the wheels you've purchased were used... might be bent.
12.770 @ 112.81 mph||slip||JB4|FMIC|DPs|DCI|N54 DVs|ER CP|Koni FSD|Eibach-Pro|F Strut-bar|R Sway-bar|Hankooks V12|DPE SP16|BBK|15%Tint|CF Front Lip|CF Diffuser|M3 Spoiler|SmartTop|LUX AE|Debadged |
04-22-2010, 10:09 AM | #20 |
Rep 15,818
Well the rims didn't cause a problem before.
Drove the car at speeds well over 100 I actually haven't gone past 80 yet. Been out of commision due to surgery I do think it's prly the spacers. But my friend had no problem with them
04-22-2010, 10:44 AM | #21 | |
Rep 3,868
Drives: E93 335i
Do get your tire balance checked at good tire shop. I had a similar problem that you've described when I was running spacers and it turned out to be my wheel balance was slightly off when I bought wheels originally. GL
04-22-2010, 11:11 AM | #22 | |
Rep 1,381
i had the same problem i thought it was the spacers but it turned out to be the rotors dont know if its the same in your case |
