DIY - Removing / Replace Roundel (roundel removal)
11-16-2006, 01:28 PM | #1 |
Rep 21,240
One easy way to improve the apperance of your BMW is to replace a worn or faded Roundel. In this tech article we will discuss replacement of the roundel, and should take less than 10 minutes to perform. What you will need is a new Roundel and two plastic grommets, (available from Pelican) - shown in Figure 1 and Figure 2.
The first step is to remove the existing Roundel. As you can see in Figure 3, the existing Roundel is worn and fading. The method of removal varies, but the end result is the same, you must gently pry the old Roundel off. In this case we simply used a credit card as a fulcrum point, then inserted a flat-head screwdriver between the Roundel and the hood. Remember to use caution when prying off the old Roundel. Go slowly and using light force, and it should come right off. (Figure 4) Step two is to remove the two grommets left behind sitting in the hood as shown in Figure 5. If your grommets came off with the Roundel, you can skip this step. Simply remove them with a pair of pliers, they should pop right out. This is also a good time to clean the base for the Roundel, for as you can see it is covered with dirt. Next, simply push the new grommets onto the new Roundel as seen in Figure 6. You may have to use a little force to get them on there, but use caution as it is possible to break the studs they slide on. Finally, simply line up the studs with the corresponding holes in the hood, and press down with the palm of your hand, til the Roundel goes no futher (Figure 7). That's it, you're done! From : http://www.pelicanparts.com/bmw/tech...30-Roundel.htm
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
11-16-2006, 01:41 PM | #2 |
From Russia With Boost
37
Rep 1,076
I will try to remove the rear roundtell on my trunk this evening, but i assume there will be two holes left...any way to cover them up?
2007 BMW 335i - Delivered 9/8/06
Sparkling Grpahite with Black Leather/Aluminum Trim Premium Package, Sports Package, Comfort Access. |
11-16-2006, 03:20 PM | #3 | |
Rep 3,011
not only will you have two holes, but you'll also have a circular divot in the trunk lid where the roundel fits. Put on a new one ..... see this thread:http://www.e90post.com/forums/showth...lacing+roundel
"Teach the ignorant. Ignore the stupid."
01-12-2007, 11:33 PM | #4 |
Rep 726
I tried this on a E92 coupe and I don't know if I simply didn't apply enough elbow grease or what, but the roundels seemed like they did not want to budge at all and I was worried about damaging them. What am I doing wrong? Has anyone done this on an E92 coupe?
2007 E92 335i--SG, Fully loaded, minus the dead weight..err..iDrive and Active Steering. |
01-13-2007, 12:01 AM | #5 |
Rep 3,011
careful... check out Picus's thread on "problem with e92 roundels". In summary, the replacements might not fit correctly on the coupe
01-13-2007, 02:18 AM | #6 | |
Rep 8,338
Damn those roundels are worn, i had a 5 year olf 328ci, i know not that old, but the roundels were in perfect shape, do they relaly wear that fast?
02-01-2007, 06:08 PM | #7 |
Rep 4,172
The front was a breeze for me, the rear was a huge pain in the ass. Of course there are no replacements for it yet either. A 72mm one might work, but it won't fit perfectly.
02-05-2007, 08:35 PM | #8 |
Rep 1,928
Drives: had e90, 330i mystic blue
does anyone knows how to remove the Roundel of the steering wheel? mine is all mess up but I'm scare of trying to remove it I don't want to set off the airbag or something like that
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
02-05-2007, 08:39 PM | #9 |
Rep 3,011
i just stuck my replacement on top of the original. Looks fine to me. Ksfrogman says that there are clips on the side of it.
02-05-2007, 09:22 PM | #10 |
Rep 1,928
men I'm so fucking stupid !!! there are NOT clips on the inside of the roundel of the steering wheel I bend it and I had to remove it aI'm clad I had a ACS one but now I don't like it that much it dosent look like BMW I don't think I can buy one at the dealer so I guess I have to get it on ebay
so guys DO NOT remove the one on your steering wheel just put a new one in top of it.
02-05-2007, 09:42 PM | #11 |
United States Marine
318
Rep 2,748
The steering wheel emblem is NOT replaceable, according to BMW. I've replaced many complete airbag's for a damn cracking emblem. It's DUMB.
02-05-2007, 09:48 PM | #12 | |
Rep 1,928
I'm SOOOOOOOO STUPID !!! I f up my original emblem !
I guess now I will have get one on ebay or get another airbag matt can you hook me up with an airbag ?
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML Last edited by calvino; 02-05-2007 at 10:16 PM.. |
02-05-2007, 09:54 PM | #13 |
E60
39
Rep 587
why replace them... the bimmian cover ups look great, most cant even tell theyr stuck on there. for 15$ you cant go wrong
02-06-2007, 07:41 AM | #14 |
pull my finger to get your kinder® surprise
148
Rep 10,455
that sucks man, calvino, it'll be easier for you to get hte Ebay ones, instead of replacing your airbag, that'll cost you $$$$$$
02-06-2007, 09:23 AM | #15 | |
Rep 1,928
howeverr look the emblem that I found I love it
02-06-2007, 10:01 AM | #16 |
Rep 4,095
Drives: F30 328i
WOW!! i would NEVER use a screwdriver to remove the roundels!! Holy shit u guys are nuts!!! just use dental floss guys much easier and guarannetted NO scratches or dents
02-06-2007, 10:49 AM | #17 |
Rep 6,750
There are clips on the steering wheel emblem. Just don't plan on reusing your existing roundel. I replaced mine with a new one that was black/white.
Like any other item you attempt to remove, don't force anything and take your time. If you use a screwdriver, see where the plastic is pulling up, and redirect your prying using those spots as fulcrum points. |
02-14-2007, 03:40 AM | #18 |
Always Lurking
Rep 28
Drives: E60 M5
A friend at the dealership offered me a great suggestion. When I went in to get a new roundel, he asked if I would like to borrow their high-tech tool to remove the old roundel. j/k
He went in the back and cut a piece of nylon strapping that they use to band pallets. It worked great because it was thin enough to get behind the roundel and strong enough not to break.
2007 M5 - Black Saphire | Black
2007 K1200R Sport - White-Aluminium Metallic 2007 335i - Sparkling Graphite | Terra (Retired) |
02-14-2007, 11:46 AM | #19 |
Rep 4,095
Drives: F30 328i
^^^^^ thats exactly how i use the dental floss!!!! great pic bud
02-14-2007, 02:29 PM | #21 | |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
03-30-2007, 03:09 AM | #22 |
Rep 1,683
i just installed my hood roundel...
used dental floss to lift, slid the credit card in and went to the screwdriver... i didnt attemp to do the trunk, as the roundel seemed diff., the top and bottom lip were thiner than the side edges... can someone please post a pick or share their experiences... picture wouldnt upload...ill try again later thx
Life is Good
