Question about brake pedal...??
03-24-2010, 08:26 PM | #1 |
Rep 919
when i start my car i need to press on the brrake pedal to start it. but lately when i press down onto it its stiff and i need to press down on it pretty hard in order to start it?
has anyone had this problem before? thanks in advance Darin
03-24-2010, 08:41 PM | #5 |
Rep 975
that happens when you have the engine off and you pump the brake pedal, it gets stiffer and stiffer and then loosens once you start the engine again.
If that's not the reason its happening to you, then i dont know what it is. Maybe get it checked
2009 BMW E90 328i | Xenons | MT | Space Gray | Beige-ette | CF Fabric Trim | iPod/USB | 20% Tints | Euro-Plate | Rear Fog Switch Lego Mod | Painted Reflectors | Performance Short-shift Kit | Style 197 Wheels | OEM Sport Suspension |
03-24-2010, 08:53 PM | #6 |
Rep 5,046
There is a valve in the system that is defective. There is a bulletin out on fixing it/replacing it under warranty for that problem. I believe it has something to do with leaking fluid back into the system and causing the pedal to become hard while the car is turned off. Take it to the dealer if it bothers you or just wait till your next service and mention it.
03-24-2010, 10:02 PM | #7 | |
Rep 919
03-24-2010, 10:08 PM | #8 |
Rep 1,754
There is a check valve in the brake boost system that is supposed to retain vacuum after the engine is shut off, so you won't have a hard brake pedal. If this valve starts leaking, your symptom is the result.
A lot of people just ignore it, but you can get the valve and/or brake booster (sometimes the problem, too) repaired under warranty if it bothers you. |
03-24-2010, 10:40 PM | #10 |
Rep 919
so next year when i take it into service i should mention it to them? and i have another question i got an AFE intake, Borla exhaust a coilovers should i take then out when i go in for service?
03-25-2010, 12:43 AM | #11 |
Rep 1,754
Intake, yes -- but how are you going to take off the exhaust and coilovers everytime it needs to go in for service? Just isn't practical, I wouldn't think.
03-25-2010, 12:58 PM | #12 |
Rep 253
I didn't take off my DCI when I went in for service last year, they were gonna change my intake filter, but told me that I have two "cannons" in there already, so they just gave me the filter itself. Nothing happened, maybe it's just for this dealer.
03-25-2010, 01:04 PM | #13 |
Rep 410
nothing that u saw happened...usually they take pics of the engine bay and keep it on the records to decline any kind of warrannty that is directly related with that part
03-25-2010, 01:07 PM | #14 |
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
This is a brake booster problem. BMW has to replace the vacuum pump assembly. Let me find the TSB.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
03-25-2010, 01:14 PM | #15 |
Rep 21,747
Here is the SIB:
http://www.bmwtis.com/tsb/bulletins/...p/B340607g.htm I printed this out last week and brought it into the dealer. The interesting thing is that they replaced the part again (my 2nd time) and still found noticeable issues. They compared with another car and mine seemed different. So they replaced it with another new vacuum pump and now it seems fine.
