      02-12-2010, 09:18 AM   #1
Evice
Evice's Avatar
194
Drives: E92M3
Differential Ratio
Hello fellas.
Does anyone know the differential ratio for 128i ? I wasn't able to find this info.
I appriciate it if you could help
Thanks!
      02-12-2010, 10:13 AM   #2
wnta135
wnta135's Avatar
Drives: 2008 Sedona Red 135i
The 128A is 3.73 while the 128M is 3.23 from the data I found.
      02-12-2010, 10:36 PM   #3
Evice
Evice's Avatar
194
Drives: E92M3
awesome. thanks.
      02-13-2010, 10:38 AM   #4
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
The BMWUSA website has all the gearing info:
http://www.bmwusa.com/Standard/Conte...fications.aspx
(128i Coupe & Cabrio gearing are the same)
Tom
      02-13-2010, 08:05 PM   #5
Evice
Evice's Avatar
194
Drives: E92M3
Is Final Drive ratio = ratio on the differential ? I didn't know this.
      02-14-2010, 11:16 AM   #6
JimD
JimD's Avatar
368
Drives: 128i convertible
I believe you need to multiply the ratio of the transmission times the rear end to get the final drive ratio - the ratio between engine rotation and wheel rotation.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      02-14-2010, 03:23 PM   #7
Tom K.
Tom K.'s Avatar
The "Final Drive" ratios quote by BMW are the differential or "rear end" ratios. Multiplying that by each gearbox ratio will give you the "Overall Gear ratio" for each gear. (To further confuse matters, on most motorcycles, you must also multiply by the "Primary" ratio!).
So if you are comparing ratios between the MT & Steptronic, you need to do the multiplication for each gear to get the Overall Ratios - otherwise its apples to oranges.
Hope that helps.
Tom
      02-15-2010, 12:45 PM   #8
Evice
Evice's Avatar
194
Drives: E92M3
Thanks for all the explanations. The reason I asked this was, I am trying to calculate the optimum engine rpm for a good launch for a 128i. Basic rule of thumb I follow is that; tyres cannot respond with a forward force much greater than the weight that is on them, so they simply will spin if you stomp on the throttle..Well of then you are adding the weight trasfer to the back wheels, the distance from the ground to the center of wheel etc etc etc.. this calculation goes on )
1addicts
