Differences in how the 6AT and 6MT perform
02-03-2010, 06:27 PM | #1 |
Rep 1,162
Drives: E90 328i 6MT
The purpose of this thread is NOT to start another 6AT vs 6MT war. There are plenty of threads on that already. There is no right or wrong choice. They are both great trannies, especially in the 335i.
The purpose of this thread is to understand the differences in how these two transmissions perform in an E90 335i. I've posed these questions on other threads but they were off-topic. 1a. If both cars had the same gearing and we punched them in 2nd gear at 3000 rpm (high enough for lock-up), would they feel and perform identically since the 6AT is locked up? 1b. Same as 1a given the 6AT's gearing advantage. 2. Does the 6AT lock up at 2500 RPM in all gears? 3. If both cars had the same gearing, which car would come off the line better if they were driven by a professional (the Stig)? 4. The 6AT has ~12% shorter gearing than the 6MT (3.46 vs 3.08 diff and similar gearing in 1st and 2nd gear), yet the 6MT is a little quicker 0-60. Why? 5. Are there any other important differences? Here are the specs: http://www.bmwusa.com/Standard/Conte...fications.aspx. If the 6MT comes off the line faster, it would explain the better 0-60 time. Since most of us spend little or no time racing or doing 0-60 runs, the answers to 1a and 1b are important because they shed some light on how these cars feel in normal driving. Thanks. |
02-03-2010, 06:49 PM | #2 | |
All your 1 are belong to us!!!
20
Rep 658
1a. I would expect so, the 6M car might pull slightly since it may have slightly lower parasitic losses. 1b. I doubt it, the Step has significantly shorter overall gearing in the lower gears and I expect would pull the 6M car from a roll at that RPM. 2. AFAIK yes. 3. Hypothetically a 6M car in expert hands with the Step transmission and rear end gearing should pull the Step car with an identically skilled driver. That's the benefit a drop-clutch launch and a major reason why 0-60 times are better for manual trans cars. 4. Having spent some time with 1 and 3-series cars with both transmissions I'm not convinced the 6M is faster. The only thing that shows that is the .1 second difference in BMW's published numbers, which of course don't reflect reality anyway. Car and Driver's best recorded 0-60 in a 335 test was a Step car by a similarly close margin. I think a 335 6M vs. a 335 Step identically specced out and prepped in identical conditions is absolutely a pure driver's race. 5. Not IMHO, once you get past all of the fanatacism for both setups you're left with 2 cars that are similarly capable and rewarding to own in their own different ways. For reference, I have a 135 Step and have no regrets about going auto for the first time in 19 years of driving in 7 different cars. I had planned on buying a manual, but I was floored by the competence of the auto box and N54. The car just pulls like a mofo in the lower gears and is a blast around town. M mode is a ton of fun, and being able to putter along in D in Charlotte's ever worsening traffic is nice. That said it can't emulate the driver involvement of the 6M, and if I wasn't using the car for DD duty I might have gone that route. Since I am the Step was a perfect fit. When it comes to the 6M or 6A debate there's just not a winner or loser IMO. Others may not agree. Last edited by Angry3; 02-03-2010 at 06:59 PM.. |
02-03-2010, 07:43 PM | #3 |
Rep 1,162
Thanks Angry3.
Since the 6AT has significant shorter overall gearing in 1st-4th and the 6MT is probably better off the line, the 6AT might feel stronger in normal driving once the TC is locked up, right? That might explain why so many people love it. |
02-03-2010, 08:01 PM | #4 | |
Rep 5,046
There are plenty of #'s for both and its been shown that generally ATs are faster and it takes one hell of a driver, which 99% of the people on this forum arent, to be able to shift as quick or quicker than the steptronic transmission. MTs can drop the clutch, ATs can brake boost. The first questions are a moot point considering they dont have the same gearing. Its been discussed a thousand times. Theres even a thread discussing the physics of the transmissions down to theoretical physics based calculations. Also, arent the ATs different between 335s and 328s? The AT will perform better on the 335 than it will on the 328. |
02-03-2010, 08:51 PM | #5 |
Rep 1,162
Most threads that talk about the 6AT and the 6MT turn into wars about which one is better or which one a "real enthusiast" would buy or which one shifts faster.
I've never seen a thread that talks about what's most important to most of us - which one responds better in everyday driving with light, medium and heavy throttle in a given gear? For example, when the 6AT is locked up, does it really respond like a manual (no slippage, no lag, you can feel the direct connection between the engine and drive wheels)? If so, given it's gearing advantage, the 6AT would feel faster than a stick in normal driving. That's news to some folks. You certainly wouldn't expect it looking at BMW's published 0-60 times. Last edited by demosthenes; 02-03-2010 at 09:04 PM.. |
02-03-2010, 10:51 PM | #6 | |
Rep 5,046
The thing is with how the 335 is programmed is that when the 6AT shifts it doesn't let out all its boost while the 6MT will dump all the boost while shifting. I know that Shiv addressed this in his latest versions of his tune where the car will now hold almost full boost while shifting. They're both great. I dont think you can go wrong with either one. It just comes down to preference IMHO. Also, I think all the companies rate the 6MTs faster. Like was said before, they launch the sticks while just stepping on the gas on the AT. |
11-07-2010, 10:23 PM | #7 |
Rep 176
ive been driving manuel all my life.. when i bought my 05 e46 m3 i decided to go SMG.. wow did i love it.. very responsive when upshifting felt faster when upshifting and rev matching is on point!.. ideal track car..
BUT.. when the 335i came out.. i just had to have TURBO once again.. i first hoped they would come out with SMG again.. but didnt.. soo i drove both manuel and steptronic.. steptronic first: im sorry to say that coming from SMG m3.. this felt cheap and straight auto like feeling w. tiptronic like any other car.. i even launched from a dig and redlined.. wow upshifting was sluggish!.. IMO wasn't fun to drive.. unpredictable.. i can imagine auto X the car would not work out.. and i didnt feel the torque.. 6 MT: it pulls A LOT harder i felt way more control of the car.. and all i have to say is it felt more of a sports car that it is.. clutch was firm and very responsive (grabs low).. rev matching is effortless!!.. even driving my M3 SMG for 3 years. i admit i missed a manuel 6 speed.. well i bought a 6 speed 335i in late 07 bought an 08. and wow i never get bored of driving it at all.. i have a v3 tune.AA IC.Injen DCI.Agency Power catless DP's. Greddy Type-s bov.. and i'll tell you its running hard.. i just like the fact i can release the gear w. a press of the clutch.. and most of all im happy that i was able to find a 6speed locally w/o the wait!. for those that have steptronic.. if you think that's great.. drive an SMG m3.. no comparison.. soo reason why i didnt buy one!.. thats all.. |
11-07-2010, 10:43 PM | #9 | |
Rep 5,046
11-07-2010, 10:47 PM | #10 | |
Rep 176
i actually own both e46 m3 and 335i 6 speed.. and the m3 is my daily nowadays.. feels better on a day to day drive..when im lazy i just put it on auto and just let it do all the shifting haha.. and driving my 335i is pure enjoyment since its 6 speed w. all my mods.. |
11-07-2010, 10:57 PM | #11 |
台北 台灣
43
Rep 619
Drives: 2004 MazdaSpeed Miata
Sorry if it sounds stupid...
But what does the AT locked up mean? I dont know a lot about transmission...
2006 E90 325i AT TiAG...Sold!
2000 E39 M5 "The Beast"...Sold! 2004 Mazda Speed Miata... Bone Stock... 2000 Ford Explorer... Beater all the way |
11-07-2010, 11:17 PM | #12 |
Rep 13,108
Instead of straight line performance
What about the control of torque in the corners that effects control, and how it
effects steering control and cornering ability. Any comments ? |
11-07-2010, 11:34 PM | #13 |
Rep 4,771
11-08-2010, 07:16 AM | #14 |
Rep 328
I have the AT and I love it for everyday driving (the convenience was the deal breaker for me) but I do at times wish I got the MT. For some reason, to me a turbocharged car doesn't feel right with the AT, this applies to any turbo auto car, not just our step. At times, the auto is a bit jerky and hiccups in certain gears, in an MT, this would be fully controlled by me and I could rev as freely as I wanted to. In the case of the paddles with the AT, my personal opinion is that they are useless, they are always unpredictable in when the car will shift and I could see them confusing a driver on a track. Yes, in a drag race the AT would always be quicker, 99% of people will not be able to shift as quickly in an MT. I would be willing to bet that the opposite would be true on normal roads with traffic and plenty of turns.
11-08-2010, 07:50 AM | #15 | |
Rep 1,292
Think of two fans facing one another. On the left the fan is connected to the engine and spinning around. The fan on the right is connected to the wheels of the car through the transmission and driveshaft. If the left fan spins fast enough it will cause the right fan to begin spinning. Get the idea? So now take those two fans and enclose them in a housing filled with oil and you have a torque convertor that sits at the front of an auto trans. When the engine spins the front part of the convertor fast enough, the rear part of the convertor will begin to spin also... moving the car. Older cars had only the simple torque convertor process I described and going back to my fan analogy you can see how when applying more force to the powered fan there would be a little delay before all the force is applied to the drivetrain side of the fan. This sort of rubber band effect and slippage is overcome on modern cars by using a cog or clutch plate to lock the two sides of the convertor fans together after a certain RPM is reached. Once this lock occurs, there is a direct connection between the engine and transmission much like a manual shift car when the clutch is released. The 335i AT for example locks up the torque convertor at 1,200 RPM, causing there to be very little difference in acceleration times between an auto trans vs. manual trans car. |
11-08-2010, 10:09 AM | #16 | |
Rep 715
Is it due to slippage in the torque converter? If so, when? During launch? During shifts? During hard acceleration while in 1st or 2nd? Last edited by driverman; 11-08-2010 at 10:15 AM.. |
11-08-2010, 12:09 PM | #17 |
Rep 331
There is also a weight difference although in 335 it is very small, for a 328 the GM transmission weighs a ton compared to manual transmission.
PS fast shifting a manual transmission car for 0-60 or any kind of upshift is not that hard and I am sure much more than 1% of people on this board can get it right, down shifting and heel toeing is another matter of course. Personally I am still working on my heel toeing technique and fortunately the pedals in BMW are perfectly designed for this unlike in my Mazda3 where the gas pedal was too low for effective heel toeing. |
11-08-2010, 01:21 PM | #18 | |
Rep 1,292
The torque convertor locks up at 1200 RPM and stays locked up, there would be no slippage from the torque convertor after the first few feet of acceleration in first gear. |
11-08-2010, 02:19 PM | #19 |
台北 台灣
43
Rep 619
Weaselboy thank you for the easy to understand explanation there!! So basically after the lock up the AT will transfer power just like a MT..... Got ya.
11-08-2010, 04:53 PM | #20 |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
A few weeks ago I attended the BMW M-Power tour where we got to drive various M Cars, all with the DCT. During the presentation before we drove someone asked how the SMG compared to the DCT. The response of the BMW rep was "The SMG was Crap".
I concur. I drove an E46 M3 with the SMG and a Maserati GT with the Cabriocorsa, which was an SMG. I was not impressed. CA
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England Last edited by captainaudio; 11-08-2010 at 05:04 PM.. |
11-08-2010, 05:02 PM | #21 | |
1181
Rep 4,535
You can't speak for just about anyone on the forum. I ordered my car with a Steptronic because I wanted a Steptronic and there are a lot of other people who did the same. I am very experienced with manual transmissions and have a conventional 4 speed in my track car. I also have a lot of experience in open wheel race cars with Sequential racing transmissions with manual clutches. When I bought the 335i I decided that after years of manual tranmissions I wanted to try an automatic. I do not remotely regret making that choice. There is nothing old technology about the ZF Steptronic that is used in the 335i. It is a state of the art transmission. ZF intends to keep developing it and have stated that the feel that future Steprtonics will perform as well as DCTs. The next generation ZF Automatic, which is just beconing available will have a version that does not use a torque converter and will be equipped with a multi-plate clutch. CA
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England |
11-08-2010, 06:01 PM | #22 | |
Rep 5,627
When the 135i came out in 2008, BMW quoted a 5.1" 0~60 time for both MT and auto. Most magazine tests had the auto fractionally quicker at 4.6~4.7 and the stick at 4.8~4.9. But BMW generally quotes the 6 MT as at least 1/2" faster to 60 for the 328i & 128i so apparently, the higher torque of the turbo helps mitigate the auto's slippage. Tom |
