E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 335i dual exhaust - performance or style?
      10-10-2006, 12:50 PM   #1
martieg
Texas
Drives: 330i Black Sph PP/SP/NV/MTk
2006 330i  [0.00]
Most brands are now releasing new models with flashier exhausts, I guess responding to consumer demand.
BMW has taken the exhaust as a differentiator: 330i vs 325i - difference was on the chrome; the M3 has four. New 335i has dual exhaust but now is split.
I recall several threads dealing with people spending a fortune to install split exhausts in the 330i.
I have some questions:
1. Is this only about style, or also performance?
2. Are the new split dual exhaust in the 335i better (performance-wise) that in the 330i?
3. Is the 328i also split, or will it be the same as in the 325i?
4. Why a cheap Nissan Maxima can come with quads and a 335i only dual?
      10-10-2006, 12:54 PM   #2
jadeddjay
jadeddjay's Avatar
Drives: e92 335i, f10 m5 comp
2007 e92 335i  [0.00]
correct me if i am wrong but each turbo feeds 3 cylinders right? makes sense to have two.
http://www.e90post.com/forums/showthread.php?t=14884
the 328 just has a splitter at the end.
http://www.e90post.com/forums/showthread.php?t=18241
      10-10-2006, 12:57 PM   #3
KL2DC
KL2DC's Avatar
Drives: F36 428i,E90 328i, E85 Z4 3.0i
2015 F36 428i  [0.00]
2011 E90 328i  [0.00]
2006 E85 Z4 3.0i  [0.00]
1. Its a true dual exhaust
2. Dunno... I'd think more exhaust gas is expelled through the dual exhaust.
3. 328i is as per 325i
4. You can change your 335 tips to quads. Some Y-pipes and cutting/welding ought to do it.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call!
      10-10-2006, 01:06 PM   #4
E90Fleet
South Africa
1311
1) 1 for each turbo
2) better for the 335i, wouldnt help a 330i
3) same as 325i
4) Because its just for looks
BMW if you are reading, I need a job, Please.
      10-10-2006, 01:06 PM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
... Exhaust 101
      10-10-2006, 01:11 PM   #6
radgator1
radgator1's Avatar
50
Drives: e90 335i
2007 e90 335i  [0.00]
This reminds me, I wrote a couple of threads a while back looking for a pic of the stock 335i exhaust and never got any replies. Usually you can find a pic or schematic of the exhaust from the manufacturer but I haven't seen one for this car. Does anyone have a pic of the exhaust or if not could someone snap one when their car is on a lift.
Thanks
      10-10-2006, 01:39 PM   #7
vantage
vantage's Avatar
Drives: None
the reason for the dual exhaust is to help the engine breathe easier. The main reason the 335i has a dual however is because of the turbo. Each turbo feeds of a seperate exhaust.
(ps. no idea why the hell the maxima has 4 )
      10-10-2006, 01:51 PM   #8
goldminer
Drives: 2011 SG E92 M3, 6MT
This is wrong. Each turbo is fed BY 3 cylinders. They do not feed 3 cylinders. The output pipes of the 2 turbos merge immediately ahead of the front turbo. You can see this in the photos you linked to. The merged pipe goes to a single intercooler and single intake plenum so each turbo feeds all six cylinders.
I suspect that this engine, under boost, flows a lot more gas than the NA engine and the N54 engine benefited from the increased ability to flow gas offered by a true dual exhaust.
      10-10-2006, 01:55 PM   #9
PiperD
Clutch pedal >> Dead pedal
Drives: '11 e92 335is 6MT
So the 335i has two completely seperate systems? From the brief looks I've had at the underside of my e46, there appear to be two headers and two downpipes into a single cat, then two intermediates into a single muffler, then two tips. Never understood why it was like that, but whatever.
In my garage: '11 e92 335is 6MT (05/10) SpGrey/CoralRed/GlacSlvr ExecPkg/NavPkg/19" 225M
Retired: '07 e92 335i 6MT (12/06) SpklgGrpht/CoralRed/GreyPoplar
Retired: '04 330Ci M-Sport 6MT SilverGrey/NaturalTan/MyrtleWood
Retired: '00 328Ci 5MT SteelGrey/Grey/MyrtleWood
Retired: '87 Pontiac Grand-Am 3AT White/Grey
      10-10-2006, 02:00 PM   #10
Dante
Enthusiast
Dante's Avatar
Germany
468
Drives: F87 M2 / F31 330d
Thanks
I already posted this one in one of your threads:
http://www.e90post.com/forums/showthread.php?t=32061
      10-10-2006, 08:54 PM   #11
martieg
Texas
2006 330i  [0.00]
The muffler and exhaust pipes also determine the classical pitch note that the BMW is known for. Too much moding around might screw those sacred notes up.
      10-10-2006, 09:14 PM   #12
John 070
Drives: 335i cpe
The H pipe? that joins the two mufflers is interesting. I never quite got the true dual concept down, because it can be a true dual where the exhaust is mixed and separated again.
In the case of the Maxima, Acura, Kias of the world, they have a Y-pipe after the cat which does nothing more than have two outlets at the back. It's for looks.
Actually, I was a bit disappointed when I first saw the two pipes on the 335, but I had faith that BMW would never just put something phoney on the car for looks. But I do wish that my 335 would have led brake and turn lamps, not that ribbon parking lamp thing a ma jig.....
      10-10-2006, 09:18 PM   #13
JVFan
JVFan's Avatar
36
Drives: Very Well
lol
Can't you get a Vette with 8 now? Looks like the Millenium Falcon.
2012 328i White Luxury/ Saddle Brown
      10-10-2006, 10:28 PM   #14
climkt
Bimmer Manual all the way
climkt's Avatar
Singapore
66
Drives: e90 320i manual
the stock 335i pipes and bumper does not look very sporty, despite it being a fast car. guess they want to be really discreet.
in contrast stock is250 pipes and rear look more sporty and aggresive. any comments?
      10-10-2006, 10:35 PM   #15
Darklighter
Drives: e92 328i Sparkling Graphite
The IS ones look more aggressive because they're closer to the corners. Maybe if the stock 335 ones were a little bigger to fill out the cutout on the bumper it would help.
      10-10-2006, 11:02 PM   #16
climkt
climkt's Avatar
Singapore
66
yah. agree with u. the position of the pipes does make a diff.
quads near the centre is the exception but quads look cool anyway.
      10-11-2006, 12:25 AM   #17
number9
Drives: E90 330i
how tough would it be to fit the 335's dual exhaust on a 2006 330?
      10-11-2006, 12:38 AM   #18
BMW F22
BMW F22's Avatar
Drives: ///M235i
it "looks" fast
      10-11-2006, 12:45 AM   #19
crashoverride
Drives: na
A bit bothered by your incorrect correction of someone else than I read this article here are a couple of quotes that were of interest.
Built to BMW specifications, the two small low-inertia Mitsubishi turbochargers provide air to three cylinders and operate together rather than sequentially.
BMW specified that it wanted its turbines to tolerate high-heat operating conditions of up to 1050 degrees, more than 100 degrees higher than other turbos with durability equivalent to the life of the car. It claims the special heat-resistant steel used in their construction is better than a ceramic turbine.
Why has BMW returned to turbocharging? "Direct injection has helped us return to turbos," he said. "We can increase the compression ratio and also help reduce fuel consumption and increase engine efficiency.
"The 335i has the fuel economy of a six and performance of a V8.
http://www.editorial.discountnewcars...2571A00080FE09
      10-11-2006, 01:14 AM   #20
radgator1
radgator1's Avatar
50
Drives: e90 335i
Opps (where's that embasrrassed smilie when you need it) I guess I forgot to keep checking back. Thanks bro, that true dual system looks pretty sweet. I was hoping for some pics of everything from the cats back to see if there are any superfilous resonators that could possibly be removed.
      10-11-2006, 01:23 AM   #21
radgator1
radgator1's Avatar
50
Drives: e90 335i
Close to impossible I would assume since there are sure to be parts in the way on the undercarriage. Since the car wasn't designed to have 2 mufflers and such there is no way it is going to fit. Why not just go for the new Eisenhaus with the quad tips?
      10-11-2006, 11:51 AM   #22
goldminer
I also have repeatedly read in magazines that each turbo feeds three cylinders but this is definitely wrong. Look at the red circled area in the attached photo of the 335i's induction, exhaust and fuel injection systems. You can see that the outlet pipes from the 2 turbos merge immediately and enter a single pipe leading to the intercooler (the box-shaped thing on the lower right of the photo). The two turbos have to each be feeding all six cylinders as their compressed gases have mixed. This can be clearly seen in the photo. The magazines are wrong.
By the way this photo also shows that this system is a fully dual exhaust from the engine back as the are two cats (or resonators?) and two pipes, one each, behind each turbo (lower left of photo).
e90post
