Bigger Brakes on 335i Sedan?
10-09-2006, 10:40 PM | #4 | |
Rep 29,202
10-09-2006, 11:21 PM | #8 | |
Rep 2,453
10-09-2006, 11:59 PM | #10 | |
Rep 2,453
10-10-2006, 12:11 AM | #11 | |
Member
306
Rep 22,825
But auto manufacturers associate power with speed. And the more speed you can potentially gain, the more stopping power you may need. I.e. Honda offers excellent brakes on the the S2000, but the Civic DX has an inferior system. They both can eventually reach 70mph, or 100mph even, but the Civic will probably need twice as much room to slow down from the same speed. I agree that every car needs to have a good braking system, but manufacturers will factor the cars potential. Last edited by Ray; 10-10-2006 at 01:30 AM.. |
10-10-2006, 12:34 AM | #12 |
your average JAMF
3102
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
The brakes on the 330i are already incredible, these new ones must be just awesome.
Generally accepted automotive principle that more power = more braking power required. If that weren't the case, you wouldn't see these aftermarket brake guys selling so many megadollar upgrades for cars that already have great brakes right out of the box. Interesting that the calipers are different.. wonder who the manufacturer is and if it's different for each?
'21 M2 Comp
'19 Golf R |
10-10-2006, 01:02 AM | #13 | |
Rep 2,453
10-10-2006, 02:59 AM | #14 | |
S0THPAW
8719
Rep 7,846
On trackdays: The E46 M3 pulls like an idiot and you 've been traveling a far more distance out of a corner to the next in the M3(335i) than in the 330i, with a higher speed. THUS You approach a bend faster(higher speed) than with the slower cars. Shortly: You need better(bigger)brakes to stop/brake the more mph going faster car. It's easy as that. I cannot explain it any better sorry |
10-10-2006, 03:10 AM | #15 |
Rep 10,185
335i disks are Front 348mm x 30mm, Rear 336mm x 22mm
330i disks are Front 330mm x 24mm, Rear 336mm x 22mm
BMW if you are reading, I need a job, Please. |
10-10-2006, 03:14 AM | #16 |
Rep 6,874
Drives: 330i E90 C55 AMG
Garage List 2006 BMW 330i E90 [0.00]
2006 BMW 330i E90 [0.00] 2005 Mercedes Benz ... [0.00] 2002 Z3 2.2 USA Spo ... [0.00] 2002 Toyota MR-S Co ... [0.00] |
I thought you all knew that from my posts?
BMW 2006 330i E90 Jet Black/Black Leathers/Aluminium, Steptronic Active Steering; MTech Aero Kit Carbon Fibre Splitters/Diffuser. Bilstein PSS9 Coilover, Rays VOLK Racing RE30 Formula Limited Edition 18" Pirelli Rosso; Project Mu 355mm Forged 4pot Caliper. HID:Osram D1S 6000K, PIAA 6500K White Ring, Philips Diamond Vision HB4 5000K, PIAA H490/H491 Super Bright 6500K LED Interior Lights. Chrome S.Wheel Cover, Rear Windows Sunshades.
10-10-2006, 11:20 AM | #17 |
Clutch pedal >> Dead pedal
18
Rep 709
Drives: '11 e92 335is 6MT
As has been said, more power = higher speed in a shorter distance. So that some dweeb who does a hail-mary lane change and cuts you off can brake harder before slamming into the car in front of him, whereas he may not even have tried the same move in a less powerful car.
In my garage: '11 e92 335is 6MT (05/10) SpGrey/CoralRed/GlacSlvr ExecPkg/NavPkg/19" 225M
Retired: '07 e92 335i 6MT (12/06) SpklgGrpht/CoralRed/GreyPoplar Retired: '04 330Ci M-Sport 6MT SilverGrey/NaturalTan/MyrtleWood Retired: '00 328Ci 5MT SteelGrey/Grey/MyrtleWood Retired: '87 Pontiac Grand-Am 3AT White/Grey |
10-10-2006, 11:38 AM | #19 | |
Rep 11,667
The larger the mass of the car, the more energy that needs to be absorbed & dissipated by the brakes. Also the larger brake mass (caliper & rotor) give it better fade resistance. |
10-10-2006, 11:44 AM | #20 | |
18
Rep 709
328i (6MT) - 1520 kg - 300mm brakes 328xi (6MT) - 1625 kg - 300mm brakes 335i (6MT) - 1620kg - 348/336 mm brakes (f/r)
10-10-2006, 12:22 PM | #21 | |
Rep 11,667
335 hauls large mass to a shorter distance |
10-10-2006, 12:39 PM | #22 |
Rep 37
Big calipers and rotor have almost NOTHING to do with stopping distance.
Brakes transfer kinetic energy into thermal energy. With aggressive driving, it's easy to overheat small brakes and boil the brake fluid giving a "spongy" brake feel. Big calipers and rotors serve as a heat sink. It's that simple. I more than doubled the size of the calipers on my track car. The stopping distance is unchanged, but my brakes never overheat and get spongy. If the 335i has a shorter stopping distance, it is most likely due to a bigger tire and thus, a bigger contact patch. |
