11-12-2009, 03:33 PM | #1 |
Rep 1,090
Camber
Just a quick question.
Is it better to have the rears whith less neg camber than the fronts, even if the fronts have low neg camber. ie my car was just aligned and they could only get -1.13 out of the fronts (pins pulled). The rear they maxed to -3 which is way too much i think for the street. Im going to go to a different shop, should i have them drop the rear neg camber to be the same as the fronts? Or should i just change the rear to somehting like -2?
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
11-12-2009, 05:51 PM | #2 |
Rep 385
-3 is way too much camber in the rear if the fronts are only -1.13. Rear camber on these cars should never be more than the front, in fact they turn better with slightly less camber in the rear than the front.
Also, you should be able to get more than -1.13 up front with the pins pulled. I have -1.65 up front with my pins pulled (stock otherwise).
11-12-2009, 06:23 PM | #3 |
Rep 1,090
^ Thanks for that mate. Yeh i'm going to a different shop, ill have the rear turned to match the fronts.
135i N54 manual
11-16-2009, 10:48 AM | #4 |
Rep 1,660
Each car is a little different. I was barely able to get -1 in the front when I pulled the pins. I ended up adding washers to the strut to get to about -1.6
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
11-16-2009, 03:24 PM | #5 |
Rep 1,090
I went to a dedicated suspension shop and they managed to get -1.5 for the fronts and they lowered the rear camber down as well. So now everything is much better.
So lesson learnt, dont go to non-suspension specialists for alignments.
135i N54 manual
11-21-2009, 07:46 AM | #6 |
Rep 47
What you can also try is swap left to right, it's common use @ CSL and makes it possible to go to 2,4 negative (pins out).
My setups: - with pins in place max 1,00 - without pins max 1,15/1,2 - after swap left/right max 2,4 |
03-03-2010, 10:19 AM | #7 |
Custom User Title
141
Rep 661
There is an inexpensive bolt and washer "shim" kit for the E36M3 that adds neg camber to the front knuckles in ~0.5 degree increments per washer. Turner motorosports has them. Kit allows stock setup to achieve nearly -3 neg camber. Fast and simple, does not require removing struts. More info in other threads here. They fit the Z4M just fine. good luck!
04-25-2010, 04:52 PM | #8 | |
Rep 42
the left and right struts? |
