E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - E90 Xenon lights retrofit (official BMW instructions)
      09-29-2006, 04:25 PM   #1
Jason
Jason's Avatar
Drives: F80 M3
Thanks darkcloud!
Xenon Lights Retrofit (for E90) HERE
Check on the Latest BMW News
      12-15-2006, 04:17 PM   #2
SE3P_to_E90
Drives: E90 Msport + E83 Msport
Whats the price on this?
      12-15-2006, 04:21 PM   #3
txusa03
Drives: TS330iPPSP6MT
5.5 hours that would equates to $550-600 for labor alone.
under construction!
      12-15-2006, 05:18 PM   #4
SE3P_to_E90
yeaa.. and i'm sure the kit itself costs an arm and a leg.
      12-09-2007, 08:28 AM   #5
FstAzzWhip
Drives: E93 335i
where did this DIY go
Does anyone still have this .pdf file i need it to do a retrofit.
      12-09-2007, 10:09 AM   #6
darkcloud
darkcloud's Avatar
Drives: 09 VW JSW
2006 325i  [0.00]
PM Jason, he prolly still has it. I may have it on another computer still but won't be able to look till tomorrow.
retired 06 E90 325i
New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter
      12-09-2007, 10:27 AM   #7
jetblk328i
jetblk328i's Avatar
307
Drives: X3 M40i
i have the BMW OEM pdf for non adaptive....now if someone would just teach me how to upload this on, or just pm me you email and ill send it to you.
      12-09-2007, 10:40 AM   #8
jetblk328i
jetblk328i's Avatar
307
Drives: X3 M40i
E90_NONadaptive_ENG.PDF
here it is hopefully it works!
      12-09-2007, 10:41 AM   #9
jetblk328i
jetblk328i's Avatar
307
Drives: X3 M40i
yay it works at least for me!
      12-09-2007, 01:29 PM   #10
Excellence
G-STAR
Excellence's Avatar
200
Drives: E90 to A5
Damn thats complicated!
      12-09-2007, 03:24 PM   #11
FstAzzWhip
Drives: E93 335i
thank you guys
      03-24-2008, 09:29 AM   #12
fesp
Drives: e90 bmw
the first link doesn't work
      04-04-2008, 12:23 PM   #13
rambalu80
rambalu80's Avatar
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
Yep, the first link does not work!
      02-26-2009, 01:48 PM   #14
benb
Drives: 335d (Sep 2008)
did anyone try this? its hard work.
      09-30-2009, 12:34 PM   #15
waelmik
Drives: bmw e90 320i
Guys cant i directly place the original xenon headlights on my e90 and tap with the on board computer?
because where i live its much simpler than that no wiring kits is needed
      06-28-2010, 02:05 AM   #16
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
Seems like the PDF listed here is for adaptive lights from what it reads.
      06-28-2010, 08:44 PM   #17
mikekilpatrick
Has anyone completed the retrofit with the factory harness and turned them on through the computer?
      11-18-2010, 04:24 PM   #18
Sidnito
Sidnito's Avatar
Drives: 11 space 335i
bump
      11-18-2010, 04:50 PM   #19
mikekilpatrick
For now, I just ended up Professionally wiring a set of Xenons for my own car using Butt connectors and tying directly into the factory harness connectors (Helps being a network engineer with an electrical degree). Can't even tell that it was converted by looking at it! Tested em out with no errors and doing the permanent install this weekend. I will make sure to document whole procedure for anyone interested.
I WILL attempt the FULL OEM retrofit when the weather gets warmer, I have a lead on a guy that sells the wiring kit from BMW, but then you have to find the foot control unit and the headlight switch used as if you buy them new it is like 400-600 dollars just for those parts.
      11-29-2010, 09:21 PM   #20
328xihalogen
Drives: 328xi
Please upload your results! After reading all the xenon convertion threads, I just get more confused than ever! If someone gets ALL OEM PARTS(housing, bulbs, ballast...), and just replace the halegon, would that be error freee, or what else you need to do to get them working and stable(I do not need the adaptive function, just need them light up and no error).Thanks.
      12-02-2010, 02:13 PM   #21
DMC1068
DMC1068's Avatar
Drives: 2007 328i
I did not realize you have to take off the bumper and all the other issues. I was going to buy these http://www.carid.com/2007-bmw-3-seri...ml#fullInfoTab and do a plug and play. I guess not.
      12-06-2010, 05:40 PM   #22
orangedawg
Drives: 328xi
I've got a set of bi-xenon adaptive headlights with the factory ballasts and factory modules that I want to convert/use in my halogen car. I don't care about the adaptive part (ride height and that they turn into the direction car pointed). I just want them to work in my car. I've read the threads on this type of conversion, but was wondering if you could use the factory harness you used and whether it would cause any errors if I don't get a new footwell module.
Mike, do you have pictures of the work you did to tie into factory harness? I'd prefer not to have to cut wires if possible. My car is a e90 build date 02/07. What is your build date (I note that it seems to matter if the car is 02/07 and earlier vs. 03/07 and later. The 02/07 builds are KCAN or something like that and the 03/07 builds are DCAN.
e90post
