Tyre Pressure Warnings
10-20-2009, 06:08 AM | #1 |
Rep 1,733
3 days running, i've had the tyre pressure warning come up.
First time i took it to a garage and they found that some crazy fool at quik-fit had put 42 in my front left! (i was getting nitro done) but no problems otherwise. 2nd time i just reset it now its happened again on my way to work. I've checked the tyres and there is no obvious leak or deflation. I know they are RFT's but i'm guessing with the weight of the car it would be clear to see if there was a puncture. Anybody else had a faulty sensor or this issue with barely legal tyres? |
10-20-2009, 06:19 AM | #2 |
Rep 384
Drives: It's a Mini Adventure
I would check all your tyre pressures.
Make sure they are inflated to the correct pressures and then reset the tyre pressure monitor. If it happens again, check all tyres and find out if one is down. If one is then inflate and get yourself to a garage and have the tyre checked for punctures. This happend to me. The monitor works of the ABS sensor to detect a change in rolling radius and not a pressure loss btw. |
10-20-2009, 06:31 AM | #3 | |
Rep 1,733
None of the tyres look or feel down. Confused.com I realise it worse off ABS, could it be that hitting a pothole is causing an issue. I ask because there is a narrow country road i come along and you have to drive through potholes to avoid hitting the car coming the other way. Ta for your reply Last edited by misterS3; 10-20-2009 at 06:33 AM.. Reason: To say "ta" (where's my manners) |
10-20-2009, 06:32 AM | #4 |
Rep 1,733
I'll check the tyre pressures again tonight though....although saying that (see my other thread) i'm due new front tyres (just coming up on 20k) so i might just get that done sooner rather than later.
10-20-2009, 06:46 AM | #5 | |
Rep 8,972
An RFT with ZERO psi in looks exactly like one with 35psi in. The sidewalls just don't move at all!! Like skid says, get all your pressures right then reset the system and see what happens then. |
10-20-2009, 06:49 AM | #6 | |
Rep 1,733
Will get on the case tonight!! Thing is the car didn't feel any different to drive, saying that, i wasn't pushing hard. Ta again |
10-20-2009, 06:59 AM | #7 |
Old enough to know better!
20
Rep 409
Drives: 320d M Sport, Le Mans Blue
Mine came on when one of my fronts was down to below 20 psi due to a puncture. Couldn't tell visually and there was no difference in the feel of the car (moderately pushing it).
Jon Steele
320d M Sport (E90) Le Mans Blue/18" Alloys/Bi Xenons/Climate Screen/Black, Heated Dakota Leather/6 CD Changer with Dension 500/Power Mirrors/M3 Lip Spoiler/Gloss Black Grills/Through Load, Storage pack, Lumbar Support, Smokers Deletion |
10-20-2009, 07:03 AM | #8 | |
Rep 8,972
10-20-2009, 12:56 PM | #11 |
Rep 108
So the tyre senor's effectively part of the ABS system?
I just had a new valve put on my passenger side rear at Kwik Fit yesterday - they told me I needed to go to BMW otherwise it would cause the tyre pressure sensor to malfunction, however, I've not had any problems today. We're Kwik Fit talking b*ll*cks? |
10-20-2009, 01:08 PM | #12 |
Rep 1,733
Yeh i think i have.
Will get the electric pump out in the morning so i can get to work and put it in the boot so i can get home again. Tyres ordered, should be here tomorrow, if not first thing Thursday. Last edited by misterS3; 10-20-2009 at 02:14 PM.. |
10-21-2009, 02:51 AM | #14 | |
Rep 8,972
BUT if kwik fit changed a regular rubber valve for another regular rubber valve then you must have the ABS TPMS system, and yes KF are then talking shite. |
10-21-2009, 02:58 AM | #15 |
20
Rep 409
Surely not, they're such a professional outfit
Jon Steele
10-21-2009, 01:05 PM | #16 |
Rep 1,135
Sounds like you have a slow puncture. if it is a result of hitting a pothole you should get the alignment checked. Take a deep breath though it ain't cheap to get the full BMW KDS alignment check. If you leave it though you run the risk of the new tyres wearing prematurely.
10-22-2009, 02:57 AM | #19 |
Rep 8,972
It's a system designed for BMW requiremnts and is a fantastically accurate piece of kit.
If you've ever seen a results printout for a KDS then you'll know how much and how accurately it checks the car. http://www.pro-align.co.uk/products/...mwaligners.htm Pricey, but worth it after a knock IMO. I had it done after i clobbered a speed bump at about 50mph when it was 2 weeks old!. All 4 wheels were out of factory tolerance, one front by about 2 degrees. Also the front wheels must have deformed slightly (minute amount) as they were noticeably out of balance too and needed re-balancing on a tyre machine. They charged me £300 for a 1/2 hour damage inspection (2 minutes more like) and KDS. I got this done so the car has a clean slate for warranty purposes and they have confirmed NO DAMAGE in writing. |
07-06-2010, 11:09 AM | #20 | |
Rep 221
Just check a few sites and an 07 is'nt listed! Had a TPS warning but it has pressure in around 34psi on all wheels so took it to an independant.They sent me packing as they only have rubber valves. I tried ATS and they were the same. As it happens theres part of the screw thread snapped off proably due to corrosion and they gave me a coupler to extend the valve so I could get an accurate reading as air was just passing previously. I reset the TPS and no more warnings but struggling to source a valve unless from the stealer! Anyone came across this? |
07-06-2010, 11:31 AM | #21 |
Rep 1,301
Drives: 2011 320d e92
07-06-2010, 12:11 PM | #22 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
Bit off topic, who can recommend a very good KDS garage around London or surrounding counties?
