E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Extended Warranty; really extended
      09-01-2009, 01:39 PM   #1
shanecarmaster1
shanecarmaster1's Avatar
Drives: e90 325i, F01 750Li, e38 740i
Can you buy a BMW extended warranty at any time, or just within a certain amount of miles 'till they say "NO"?
      09-01-2009, 01:44 PM   #2
Joeb427
BMW CCA Member #420698
Joeb427's Avatar
Drives: '09 335i
anytime before the 4/50.
      09-01-2009, 01:46 PM   #3
JohnyRangr
Drives: 2010 E90 M3
You can purchase it up until 3 years, 364.9 days/49,999.99 miles. After that you are toast.
      09-01-2009, 01:46 PM   #4
rambalu80
rambalu80's Avatar
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
I think you will also have to be the original owner of the car to be able to buy the BMW extended warranty.
      09-01-2009, 01:48 PM   #5
Joeb427
Joeb427's Avatar
Drives: '09 335i
That I believe to be true also.
      09-01-2009, 01:55 PM   #6
Roowah
Roowah's Avatar
Drives: 2006 E90 330i 6MT
What everyone said above is true. The only way to have the extended warranty without being the original owner is to purchase it as a CPO. If you are the original owner, then you can purchase the extended mechanical (and/or maintenance) warranty as long as the original warranty is still in force and effect.
2006 E90 330i 6MT: TiAg|Black Leather|Poplar Trim|Premium Package|Cold Weather Package
2003 E46 325i 5MT: Retired - The beginning of my BMW obsession!
      09-01-2009, 09:46 PM   #7
bumere90
Grozniy
Drives: Carless
does anyone know how much it costs to purchase an extended warranty?
-fatman
      09-01-2009, 09:58 PM   #8
joyride08
Joyride
Drives: 2007 335i | Black/Black/Alum
Mine shows $1595
2007 335i Coupe | MT | Black/Black/Alum | Sprt + Cold + Prem pkgs
      09-01-2009, 10:03 PM   #9
jimk
jimk's Avatar
104
Drives: 2018 M550i
This is what I got from a dealer:
BMW EXTENDED WARRANTY starts from your car's in service date, and does not cover the nav/idrive/cd player/ stereo components.
these are only marked up $100 dollars.
6 years or 100,000 miles $2825
7 years or 100,000 miles $3275
      09-01-2009, 10:06 PM   #10
gqmd
Chemo Doc
Drives: e92 335i 6MT
1495 for me
jet black 335i, 6MT manual, black interior with silver aluminum trim, PP, SP.
      09-01-2009, 10:56 PM   #11
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
Originally Posted by gqmd View Post
1495 for me
is that for extended maintenance? Ive never seen a extended bmw warrant for anywhere near that low.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      09-02-2009, 12:45 AM   #12
jimk
jimk's Avatar
104
Drives: 2018 M550i
For non-BMW warranties, the best price and piece of mind is through Ford ESP, yes Ford. They now warrant non Ford vehicles. I would trust Ford more than any other warranty outfits, excluding BMW of course. Their price is very reasonable and their premiumcare is an exclusionary warranty which is what you want. That means that everything is covered except the components listed as exempted. They will also cover high tech items such as NAV systems whereas BMW wont.
http://www.fordespwarranty.com/
      09-15-2009, 07:58 PM   #13
poldim
Vroom Vrrooooom
poldim's Avatar
Russian Federation
300
Drives: 330i
2006 330i Sedan  [0.00]
2003 GSX-R 600  [0.00]
According to their website, NAV is NOT COVERED, so I dont know where you got your info.
Engine
  • All internal lubricated parts
  • Cylinder block
  • Cylinder heads
  • Diesel injectors and lines
  • Diesel injector pump
  • Diesel lift pump
  • Engine mounts
  • Flywheel
  • Flywheel ring gear
  • Gas fuel injectors and lines
  • Harmonic balancer and bolt
  • Manifold, exhaust
  • Manifold, intake
  • Oil pan
  • Oil pump
  • Radiator and radiator fan
  • Radiator fan clutch or motor
  • Seals and gaskets
  • Thermostat
  • Thermostat housing
  • Timing chain cover
  • Timing chain, gears or belt
  • Turbocharger/Supercharger unit, factory-installed
  • Valve covers
  • Water pump
Transmission
  • All internal parts
  • Governor assembly
  • Seals and gaskets
  • Torque converter
  • Transfer case, including internal parts
  • Transmission case
  • Transmission module, external
  • Transmission mounts
  • Vacuum module
Front-Wheel Drive
  • Axle shafts
  • Bearings, front-wheel
  • Bearings, rear-wheel
  • Constant velocity and universal joints
  • Final-drive housing and all internal parts
  • Hubs, automatic front-locking (four-wheel drive)
  • Locking rings (four-wheel drive)
  • Seals and gaskets
Rear-Wheel Drive
  • Axle shafts
  • Drive-axle housing and all internal parts
  • Drive shaft
  • Retainers
  • Seals and gaskets
  • Universal and constant velocity joints
Air Conditioning & Heating*
  • A/C clutch
  • A/C accumulator
  • A/C clutch bearings
  • A/C compressor
  • A/C compressor head
  • A/C compressor seals
  • A/C compressor/clutch switch
  • Automatic temperature control
  • Condenser
  • Evaporator
  • Field coil
  • Heater blower motor
  • Heater core assembly
  • Pulley
* If system has R-12 refrigerant, R-12 will be used for replacement, while supplies last. If R-12 is not available, the system will be converted to use R-132 a refrigerant or equivalent. If replacement is due to a covered component, ExtraCARE will cover it. If it's due to a non-covered component, customer is responsible. Brakes
  • Anti-lock brake module and sensor
  • Backing plates
  • Brake booster, power
  • Calipers
  • Combination valve
  • Lines and fittings
  • Master cylinder
  • Parking brake linkage and cables
  • Retainers and clips
  • Self-adjusters
  • Shaft brake pedal
  • Springs
  • Wheel cylinders
Electrical
  • Alternator
  • Backglass, heated (Electrical only - not glass damage or breakage)
  • Distributor assembly
  • Distributor cap and rotor
  • Distributor housing and shaft
  • Fuel pump
  • Ignition module, electronic
  • Ignition switch
  • Radiator fan relay
  • Starter motor
  • Starter motor solenoid
  • Switches, manually operated Electrical
  • Voltage regulator
  • Wiper motors
  • Wiring harnesses (excluding spark plug wires)
Front Suspension
  • Ball joints, upper and lower
  • Control arms, upper and lower
  • Control arm shafts and bushings
  • King pins and bushings
  • Linkage and bushings
  • Spindle and spindle supports
  • Stabilizer bar
  • MacPherson struts (front and rear)
  • Tie rods
Steering
  • Column lock (tilt wheel)
  • Cooler and lines
  • Control valve
  • Cylinder
  • Idler arm
  • Linkages and couplings
  • Power Steering pump
  • Pulley assembly, power Steering pump
  • Seals and gaskets
  • Steering gear housing, manual and power (includes all internal parts)
High-Tech
  • Air suspension, electronic (selected components)
  • Compass and thermometer readout displays
  • Instrument cluster, electronic (excluding dash pad, clock radio and graphic equalizer)
  • Keyless entry system (excluding door handles)
  • Power antenna
  • Power door locks and retainer clips (excluding door handles)
  • Power seat motors
  • Power window motors/regulators
  • Speed control
  • Windshield, Insta-ClearŪ (Electrical only - not glass damage or breaking)
-Dmitriy
06' BMW 330i & 03' Suzuki GSX-R600
SG | Beige Dakota | Poplar || iDrive w/MP3 | PP | SP | CWP | PDC | Comfort | Shades || 40% Tint
| Black Line Tail Lights | Hardwired V1
      09-15-2009, 08:01 PM   #14
3Aims
Drives: 535i
I paid $3k for the 6/100 extended warranty. I drive 20k per year so it seems worth it.
      09-15-2009, 08:06 PM   #15
Scimitar335i
Drives: 2007 335i
great deal i may just sign up for that before my warranty is over!
2007 TiAg e90 335i sport. Yes, The e90 "Mustache" is cool!
      09-15-2009, 08:10 PM   #16
Xipher
Drives: 2016 X5 35i
I think I remember hearing that the price of the extended warranty increases the longer you wait to buy it. So for example if you buy it as you buy the car it's a lot cheaper than if you were to buy it the day before the original warranty expires, the the price is adjusted accordingly between those dates..
      09-15-2009, 08:39 PM   #17
335fourdoor
Drives: 335 e90
should of gotten a 5 year only to save some money.
      09-15-2009, 09:13 PM   #18
DESI4life10
DESI4life10's Avatar
Drives: Coding: Desi4life10@gmail.com
I wonder if they honor this for Canadian residents. Sent em an email
      09-15-2009, 10:23 PM   #19
bsp8181
bsp8181's Avatar
Drives: 2007 e90 335i Monaco Blue 6MT
2007 e90 335i  [0.00]
The dealer probably told you that because he/she wanted to sell you a warranty. I work in the industry and can tell you that most warranty companies do not discriminate between whether the car is brand new or has one day left before the warranty period expires.
      09-15-2009, 10:28 PM   #20
jimk
jimk's Avatar
104
Drives: 2018 M550i
Were you looking at Extracare vs. Premiumcare. You need to click the tab on the middle/top. Premiumcare is an exclusionary option that covers everything except items listed as not covered. Although NAV is not listed in the examples of what is covered, you should always confirm by looking at the contract of what is excluded. If NAV is not specifically listed, it is covered.
HomeFAQComparePlans and PricingHelpContactLinks
Select a plan to view more information, check pricing and apply online.
RECOMMENDED FOR THE
MOST HIGH-TECH VEHICLES
READY FOR PREMIUMCARE PRICING?
Ford ESP PremiumCare provides the ultimate coverage. This plan is so complete that we generally only discuss what's not covered! It's for those who want the advantages of a Ford ESP with maximum component protection and high-tech coverage.
YOU SHOULD CONSIDER THIS PLAN IF YOU
• Buy well-equipped vehicles with extensive high-tech components • Are a high mileage driver
• Plan to keep your vehicle beyond the original factory warranty period
• Can't afford or don't want to deal with unexpected repair bills • Like and can afford premium programs
FORD ESP PREMIUMCARE INFORMATION
FEATURES & BENEFITS
• Covered Components 500
• Standard Deductible $100 ($50 deductible option available)
• Towing* Up to $100
• Rental** 10 days / up to $28/day
• Transfer Fee*** $50
• Service Locations Any Licensed Repair Facility
• Cancelable Yes
* Available only on the Standard Deductible Plan.
** Not available in Hawaii.
*** Transfer fees may vary according to state.
REASONS TO BUY
• May increase resale value.
• Ultimate value for pennies a day.
• Vehicles too complex for do-it-yourself owners.
• Could pay for itself in the cost savings of just one Ford ESP-covered repair.
• Avoid unexpected repair bills.
TIMES & MILEAGE CHOICES†
Miles 4 yrs. 5 yrs. 6 yrs. † Ford ESP rental reimbursement coverage begins on the date and mileage of contract purchase.
Coverage beings with the original in-service date (warranty start date) & zero mileage. Coverage expires upon reaching your selected time or mileage, whichever occurs first. Some eligibility limitations may apply.
60,000 X X X
75,000 X X X
100,000 X X X
Below are Examples of the Extensive Component Coverage of the Ford ESP PREMIUMCARE Plan
Engine
* All internal lubricated parts
* Cylinder block
* Cylinder heads
* Diesel injectors and lines
* Diesel injector pump
* Diesel lift pump
* Engine mounts
* Flywheel
* Flywheel ring gear
* Gas fuel injectors and lines
* Harmonic balancer and bolt
* Manifold, exhaust
* Manifold, intake
* Oil pan
* Oil pump
* Radiator and radiator fan
* Radiator fan clutch or motor
* Seals and gaskets
* Thermostat
* Thermostat housing
* Timing chain cover
* Timing chain, gears or belt
* Turbocharger/Supercharger unit, factory-installed
* Valve covers
* Water pump
* Transmission
* All internal parts
* Governor assembly
* Kickdown linkage
* Release hubs and bearings
* Seals and gaskets
* Torque converter
* Transfer case, including internal parts
* Transmission case
* Transmission linkage
* Transmission module, external
* Transmission mounts
* Vacuum module
Front-Wheel Drive
* Axle shafts
* Bearings, front-wheel
* Bearings, rear-wheel
* Constant velocity and universal joints
* Final-drive housing and all internal parts
* Hubs, automatic front-locking (four-wheel drive)
* Locking rings (four-wheel drive)
* Seals and gaskets
Rear-Wheel Drive
* Axle shafts
* Drive-axle housing and all internal parts
* Drive shaft
* Retainers
* Seals and gaskets
* Universal and constant velocity joints
Steering
* Column lock (tilt wheel)
* Cooler and lines
* Control valve
* Idler arm
* Linkages and couplings
* Power steering pump
* Pulley assembly, power steering pump
* Seals and gaskets
* Steering gear housing, manual and power (includes all internal parts)
Brakes
* Anti-lock brake module and sensor
* Backing plates
* Brake booster, power
* Calipers
* Combination valve
* Lines and fittings
* Master cylinder
* Parking brake linkage and cables
* Retainers and clips
* Self-adjusters
* Shaft, brake pedal
* Springs
* Wheel cylinders
* A/C clutch
* A/C accumulator
* A/C clutch bearings
* A/C compressor
* A/C compressor head
* A/C compressor seals
* A/C compressor/clutch switch
* Automatic temperature control
* Condenser
* Evaporator
* Field coil
* Heater blower motor
* Heater control cables
* Heater core assembly
* Instrument panel registers and air ducts
* Pulley
* If system has R-12 refrigerant, R-12 will be used for replacement, while supplies last. If R-12 is not available, the system will be converted to use R-132 a refrigerant or equivalent. If replacement is due to a covered component, PremiumCARE will cover it. If it's due to a non-covered component, customer is responsible. Emissions
* AIR control valve
* AIR idle vacuum valve
* AIR supply valve, hose, and tube
* AIR check valve assembly
* Barometric pressure sensor
* ECC relay assembly
* EGR control valve
* EGR pressure sensor
* EGR regulator assembly
* EGR valve adapter
* EVAP vapor storage canister
* Idler air control valve
* Knock sensor
* PCV hose assembly
* PCV valve
* PCV vapor filter
* Temperature sensor, Engine coolant
* Vacuum restrictor
* VAF sensor
High-Tech
* Air suspension, electronic (selected components)
* Anti-theft alarm, factory-installed
* Compass and thermometer readout displays
* Instrument cluster, electronic (excluding dash pad)
* Keyless entry system (excluding door handles)
* Power antenna
* Power door locks and retainer clips (excluding door handles)
* Power seat motors
* Power window motors/regulators
* Speed control
* Windshield, Insta-ClearŪ (Electrical only - not glass damage or breaking)
Audio
* Antenna, radio (base assembly)
* Brackets, cables, and wiring
* Cassette player
* Controls, rear seat
* Digital CD player
* Graphic sound equalizer
* Cellular phone, receiver, handset, speaker assembly, and antenna, factory-installed
* Premium sound amplifier, factory-installed
* Radio, AM, AM/FM
* Speakers
Safety
* Air bag module assembly
* Door ajar warning switch assembly
* Guides, bezels, brackets, and supports (safety belts/shoulder straps)
* Head restraint retainers and sleeves, seat belt
* Lock cylinder, door
* Lock lever assembly, door
* Lock lever assembly, tailgate
* Lock lever retainers, clips, and brackets
* Module, passive restraint
* Diagnostic module assembly, air bag
* Safety belt buckle (front and rear)
* Safety belt restraint carrier
* Safety belt track assembly
* Safety belt warning chime assembly
* Safety belt retractors
* Sensors, air bag
* Shoulder strap track assembly
* Wiring assembly, air bag
Front Suspension
* Ball joints, upper and lower
* Control arms, upper and lower
* Control arm shafts and bushings
* King pins and bushings
* Linkage and bushings
* Load leveler suspension system
* Spindle and spindle supports
* Springs (front and rear)
* Stabilizer bar
* MacPherson struts (front and rear)
* Tie rods
Electrical
* Alternator
* Backglass, heated (Electrical only - not glass damage or breakage)
* Charge & volt gauges
* Clock, electric
* Coil, ignition
* Distributor assembly
* Distributor cap and rotor
* Distributor housing and shaft
* Fuel pump
* Ignition lock
* Ignition module, electronic
* Mirrors, motorized (Electrical only - not glass/housing damage or breakage)
* Radiator fan relay
* Starter motor
* Starter motor solenoid
* Switches, manually operated Electrical
* Temperature gauge
* Voltage regulator
* Wiper motors
* Wiring harnesses (excluding spark plug wires)
PHP Code:
Components Not Covered by Ford ESP PremiumCare Mechanical:
Service adjustments/cleaningbattery/cablesbeltshosesBrakes (front hubdrumsshoesliningdisc rotors and pads); coolantexhaust system (including catalytic converter); lights (bulbssealed beam and lenses); filtersfluidslubricantsmanual clutch discshock absorbersspark plugs/wiressqueaks and rattlestirestune-upswheel balancingwheel alignmentwheel studswiper blades.
Exterior
Service adjustments
(glass and body parts); bright metalbumpersdoor handlesglassmoldingsornamentationpaintrustsheet metalsideview mirrors (glasshousing); water leaksweatherstripwheel covers/ornamentswind noise.
Interior
Buttons
carpetdash paddoor and window handlesknobsrearview mirror (glasshousing); trimupholstery
      09-16-2009, 12:11 AM   #21
poldim
Vroom Vrrooooom
poldim's Avatar
Russian Federation
300
Drives: 330i
You are correct. My mistake.
I contacted my local dealership for their warranty, thread is here. Their warranty does not exclude NAV as well, but I will request a contract from ford to see specifically what it states as the process for claiming and some of the exclusions. The warranty from the dealer states you have to call their 1-800 number prior to going to the dealership to get it approved or else its not covered.
-Dmitriy
      09-16-2009, 05:50 AM   #22
Rice&Pumkin
LionLungz
Rice&Pumkin's Avatar
Guyana
17
Drives: 335i E92 & 450H
Hassell just quoted me $2000 for extended warranty not extended maintenance if I want both it would be $4000 and that is the 6 year or 100,000 miles.
e90post
