E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Are there tuner codes rev2 can't read?
      08-30-2009, 12:43 PM   #1
e320m3
Drives: 335i
As far as anyone knows, are there hidden/shadow tuner codes that do not appear through the rev2 code reading feature?
I read a fuel pump related code from the rev2 canbus and want to take the car into the dealer for a replacement (proceed uninstalled of course), but don't want to do the code clearing, to preserve the fuel pump code. Just want to make sure I won't encounter any warranty denial surprises.
Thanks!
      08-30-2009, 12:59 PM   #2
OpenFlash
Drives: A Lot
Thanks!
The Rev.2 will read and display all the hidden/shadow codes that are currently in your DME. So if all you have is a fuel pump code, that's all you have.
Shiv
      08-30-2009, 01:54 PM   #3
e320m3
Drives: 335i
Thank you Shiv.
      08-30-2009, 02:48 PM   #4
dyong
Enthusiast
dyong's Avatar
Drives: 2009 BMW 135i Coupe
Shiv,
I read the codes 11313, 11372 from the DME. Did not find these codes on your list. Do you know what are these?
Thanks.
      08-30-2009, 05:35 PM   #5
OpenFlash
Drives: A Lot
Originally Posted by dyong View Post
Shiv,
Thanks.
If they aren't on the list, you can just do a search on this forum. But first you need to concert the code from decimal (as displayed in the PROcede software) to hexadecimal form (as in BMW speak). You can do that easily by going to a site like this:
http://www.permadi.com/tutorial/numConvJs/index.html
So 11313 converts to 2C31
And 11372 converts to 2C6C
A forum search reveals...
2C31 is a front o2 sensor code. Sounds like a bad or flaky sensor. Not too uncommon on cars that downpipes installed recently. Often the o2 sensor is over-torqued and ends up getting damaged. Or it could be a wiring issue from a wire-in o2 sim (although unlikely given your rev.2 software-based o2 sim).
I couldn't find 2C6C on this forum. Are you sure you got that number right?
Shiv
      08-30-2009, 06:40 PM   #6
dyong
Enthusiast
dyong's Avatar
Shiv
Thanks for the info. Not sure about the second code. Have to see it if appears again. I clear all the codes 2 days ago. So far it has not appear.
      08-30-2009, 07:42 PM   #7
OpenFlash
Drives: A Lot
The second code is numerically pretty close to the first so it's likely that they are related (front o2 sensor).
Shiv
e90post
