Future Turbo Systems
08-26-2009, 02:47 PM | #1 |
Rep 685
Drives: 91 300ZX Twin-Turbo, 2010 135i
Just curious to see what you guys are expecting/hoping to see in future turbo related products for the N54. Maybe we could make a list and if there is enough intrest a company such as AMS or Boost Logic will pick up on it and begin developing products for our cars if they aren't already. I know AMS and a few other companys are producing upgraded twins but I personally would like to see a single turbo manifold with a medium-sized billet turbo, external wastegate with seperate dump tube (aka screamer pipe) and non-reduced exhaust piping from the turbine to the muffler.
What do you guys think? Sure it would be slightly laggy, maybe full spool by 3000-3500 rpm, but high rpm power would be phenomenal! Also I don't see why controlling the wastegate with a boost controller either standalone or intergrated with the JB3 would be so hard. Also about the fuel issue, if we can run 18psi with stock turbos why would we need to upgrade the injectors/fuel pump to run 18psi with a larger turbo? I know the cfm will be greater on the larger turbo but as long as we have a target A/F ratio and our pressure sensor is working I don't see why it wouldn't work. Any info would be greatly appreciated. |
08-26-2009, 03:11 PM | #2 |
Rep 3,012
Because my understanding is more air is being pushed into the cylinders at 18PSI with a bigger turbo. Your A/F ratio only matters inside the cylinders. And if more air is getting in there, even more fuel is needed to maintain stoic. Someone correct me if i'm wrong here.
08-26-2009, 03:18 PM | #3 |
Rep 5,501
Boostlogic and other companies won't do anything for this vehicle until someone comes up with a solution to the fuel issue and a method for putting a bigger snail on. It'll be years before they touch this car. AMS is one of the few being proactive about this engine when it comes to attempting to put a single on.
2007 E92 Montego Blue 335i
08-26-2009, 03:31 PM | #4 | |
Just some guy
49
Rep 1,531
whoever does come up with with a fuel system upgrade will make a killing. they can sell it for a high mark up and people will pay.
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
08-26-2009, 04:42 PM | #6 | |
Î canŧ főcus mŷ attėntĭon
72
Rep 1,406
(Don't let me down, Eric )
2011 M3 Coupe - Individual Fire Orange/Black Novillo Extended Leather, 6MT, Mode Carbon, Eisenmann Race, BBS CH-R, BC Coil-overs (Sold)
1995 M3 Coupe - Avus/Hurricane, AEM EMS, Precision Turbo, Boostlogic, H&R, Fikse FM/5, MaxVelocity, Maximum PSI, 20% Tint, etc etc..(Sold) 2009 M3 Coupe - AW/Fox Red, 6MT, Carbon Roof, Shadow Trim, etc (Sold) |
08-26-2009, 05:08 PM | #7 | |
Rep 10,587
08-26-2009, 05:24 PM | #8 |
Rep 4,311
Drives: Supercharged E90 M3
A GT35R kit for the N54 would be awesome!
I hope they figure out the fuel problem. Maybe after my warranty is up in 4 years a turbo kit will be out.
08-26-2009, 05:27 PM | #9 | |
Rep 10,587
HTA = quicker spooling and more power than regular 35r, doesnt get better than that!!! OR maybe a new Precision 6262.....also a very good turbo Borg Warner has recently stepped up their game too I hear.
08-26-2009, 08:17 PM | #10 |
Rep 1,154
Yep, a few turbo upgrade kits out there. They also have 3 different aftermarket fuel pumps. I think Audi came out with a revised fuel pump too.
08-26-2009, 09:52 PM | #12 | |
Rep 3,736
08-27-2009, 08:54 AM | #13 |
72
Rep 1,406
Yep. Only a few out there..it's what ICS was running on their bumble bee. Wanted a manifold that I wouldn't have to upgrade when I went built engine + meth..
08-31-2009, 02:22 AM | #15 |
Rep 7,377
Think Andrew from AR design has a single turbo.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
08-31-2009, 10:48 AM | #17 |
Rep 1,467
+1
New headers off the shelf single turbo (35r would be nice...) ball bearing all connections (water and oil) shorty intake DPs, 2-part with swappable end piece that can adapt to sock exhaust I'm not worried about the fuel system. If we can support 550 whp with stock fuel system + meth (like ASR), then that's plenty. -scheherazade |
08-31-2009, 04:48 PM | #18 |
Rep 1,629
+1 I spent quite a bit of time looking under my hood last week. It appears that using a liquid to air intercooler would make life easier. It would allow shorter charge pipes (better throttle response) and a less restrictive intake design (air intake could be routed to the lower front left of the bumper as you look at the car). With regards to the fuel system, with such a high CR, I think methanol should be mandatory for anything over 400whp. |
09-01-2009, 08:01 AM | #19 |
only in it for the torque - awuleth'umshini wami
50
Rep 425
Drives: sapphire black 335i
Found these turbo systems
http://gtpro.com/shop/
http://www.gmpperformance.com/index....parts&CID=5687 http://www.asrengineeringinc.com/
09-01-2009, 08:57 AM | #20 |
Rep 2,559
C'mon Andrew, let's have some more details.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
09-01-2009, 09:11 AM | #21 | |
274
Rep 6,510
Saw these over on the "other" forum, from RBTurbos, Rob Beck...
Don't ask me about them, I know nothing!!! just linking to their photos... Quote:
