Does my car suck or what? Someone talk me down!
08-25-2009, 11:42 PM | #1 |
Rep 1,029
I dyno'd my car last week and was happy with my numbers until I SEARCHED this forum and saw the numbers other people are getting! If our cars are rated at 300 HP/300 TQ stock at the engine and I'm told there is a "generally accepted" 25% loss through the drive train - specifically an automatic transmission - wouldn't a stock baseline of 240 HP/240 TQ be expected on a dyno? My 335 has automatic trans with only mod being SSTT and I'm running 91 octane. I pulled 293.89 HP / 300.23 TQ. I quickly broke out my calculator, multiplied the results by 1.25 and came up with 367 HP/375 TQ and thought - "NICE!" But, having seen stock 335's dyno on this forum at 275 HP...was my SSTT only good for about 18 HP? What is more incredible are the JB3 guys with cold air intakes and a few other goodies making 375+ HP / 420+ TQ because wouldn't that convert to 468 HP / 525 TQ at the engine? Is the 1.25 a good rule of thumb when converting dyno runs to actual HP & TQ? This was done on a Dynojet dyno at 83 degrees F. Thoughts on this?
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
08-25-2009, 11:50 PM | #2 |
Rep 3,132
It's nowhere near 25%. 15% is the conservative guess.
Your best bet is to go back and dyno without the SSTT and see what you get. I dynoed 279whp, 288wtq stock and 338whp,350wtq with v3 and a dci (similar temp, sea level, 93 octane, same dyno). My results seem to be the norm, but all dynos are different. You'll only really know what the SSTT is doing with a delta. Sidenote, IIRC, most SSTT cars were dynoing in the 305-315 range a year or so ago when they were at their peak popularity.
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
08-26-2009, 12:02 AM | #3 |
Joyride
Rep 71
Drives: 2007 335i | Black/Black/Alum
Most people dyno on dynojet dynos, they're a bit cheaper. Your numbers look like they were done on a mustang dyno, which have about an -18% drivetrain loss average. One of my good friends own's a AWD mustang dyno, and he's always stating the -18% loss on average.
So at the end of the day, the type of dyno is always a factor when comparing numbers.
2007 335i Coupe | MT | Black/Black/Alum | Sprt + Cold + Prem pkgs
08-26-2009, 02:41 AM | #4 |
Rep 428
Yeah, I think 15% is more accurate on drivetrain loss...
08-26-2009, 03:09 AM | #5 |
Rep 7,377
my AT car dynoed Stock 250 whp on a mustang like dyno with -15% drive train loss and 310 with JB3 map 3.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
08-26-2009, 03:13 AM | #6 |
xbox gamertag: HuGeBluEmOnKeY
257
Rep 3,758
Did you break in the SSTT?
Like, did you punch it a couple times so the car would get used to it?
E92 335i alpine white | black dokota | auto | zpp | zsp | heated | iPod - ltbmw : vorsteiner : linea corsa : h&r : k&n : e92-lighting : expectalot-vinyl - --GONE-- |
08-26-2009, 10:04 AM | #7 |
Rep 1,029
Definately a Dynojet dyno and SSTT was fully adapted at the time of the run. I wish I would have done numerous pulls with and without the SSTT, but as you can imagine removing it after the run would have required quite a wait for the engine to cool down enough! I'm starting to realize the dyno thing is an apples and oranges kind of thing where it may not be totally realistic to compare different cars, different conditions, different dynos! I'll have to do it again with a baseline stock pull. Here's the actual data. Thanks!
08-26-2009, 10:48 AM | #8 |
Rep 2,014
You need to do your own baseline to see what YOU gained. Using a standard baseline from random stock cars off of this site is not going to be very accurate.
08-26-2009, 10:52 AM | #9 |
Rep 104
Dynos should be used for tuning, not for bragging rights. They are absolutely useless as a comparative tool unless used against other tests on the same car and same dyno.
I'm absolutely amazed at how much money must be wasted on these forums on dyno runs with absolutely no tuning being performed. If you want to know how much faster your car is, take it to the track. The numbers from a dyno don't mean anything. At all. |
08-26-2009, 11:12 AM | #10 |
Rep 10,587
yup don't jump
without dyno'ing your car there 100% stock you have no idea what power you have gained
08-26-2009, 11:20 AM | #11 |
Rep 1,883
Also, check your math. Multiplying your whp by (1+percentage loss you think you have) is not equal to multiplying your engine hp by the percentage loss you think you have.
case in point: 294 *1.25 = 367.5 but does not equal 367.5 * (0.75) = 275.6 You need to divide the whp by (1-percentage loss you think you have) 294 / (0.75) = 392 hp And the drivetrain loss is much closer to 15%. I think Dinan or Alpina (or someone) had came to that conclusion a long time ago.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
08-26-2009, 11:22 AM | #12 |
Rep 5,450
It could be a million things, Dyno isn't calibrated correctly, temperature is too high, poor quality gas, doing the dyno run in the wrong gear etc etc.
Like every says, so a run without the SSTT and then do a run with it and see how much gain you get, same day, same dyno, same temp!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
08-26-2009, 06:04 PM | #13 |
Rep 1,029
GeorgiaTech335coupe,
Oh my God. You're totally right! I hate math. New plan: Remove SSTT & dyno the car stock...then reinstall, beat it a bit and re-dyno same day. Plus I'll have them do more than 1 run with each set up. Thanks guys, I was just looking to backup my butt dyno and happened to be in OKC OK where they had a dyno ready to go. I appreciate the input.
08-26-2009, 07:13 PM | #14 | |
Rep 3,032
I was always under the assumption mustang gave higher numbers than dynojet. Someone please correct me if I'm wrong. |
08-26-2009, 07:20 PM | #15 |
Rep 10,587
mustang's often read a lot lower than dynojets.
08-26-2009, 07:35 PM | #16 | |
Rep 104
08-27-2009, 12:50 PM | #17 | |
Member
Rep 47
