08-25-2009, 07:18 PM | #1 |
BimmerPost Supporting Vendor
8115
Rep 18,814
▀▄ eas - Macht Schnell Ashtray gauge Panels for e9x M3 now available
Monitor your engine’s vitals and race with confidence while adding some style points with our ashtray gauge panel for your M3.
The Macht Schnell gauge panel is an exact component replacement for your stock BMWs ashtray, comfortable housing three of your favorite 52mm gauges within and angled for easy viewing. The textured finish allows an OEM feel as if this were offered from your local BMW parts counter. Injection molded from ABS plastic, this panel will resist warping or bending in high-heat applications. The smooth textured finish is a perfect match for your BMWs interior, giving the OEM-like appearance you expect. The Macht Schnell ashtray gauge panel mounts using the factory ashtray mounting holes with no cutting, drilling or gluing necessary. Ashtray can be replaced at any time if the vehicle is turned in or sold. Gauges not included, packages are offered fully loaded with Stri gauges if desired. Features: - Gauge panel houses three 52mm gauges - Injection molded ABS plastic construction - Textured finish to match interior design - Mounts utilizing factory ashtray mounting locations, no drilling necessary Macht Schnell - e9x 3-series Ashtray Gauge Panel http://www.europeanautosource.com/pr...oducts_id=2383 Models Supported: 2008+ e9x 3-Series, including M3
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
08-25-2009, 07:20 PM | #2 |
8115
Rep 18,814
Stri 52mm Digital Stepper Drive (DSD) Series, Black Dial/White LED
Stri DSD warning gauges offer full function, features, and extreme accuracy.Driven by rugged stepper motor, control by advance microprocessor, DSD is the latest technology in precise monitoring device. DSD gauge series is equipped with laboratory grade sending units.
Click the accompanying images above to be brought to its specific page on our site. Available Gauges: - Digital Stepper Drive (DSD) Series, Boost Pressure (30psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Boost Pressure (45psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Water Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Pressure (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Exhaust Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Voltmeter (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Fuel Pressure (Imperial Measurement) DSD gauge series are equipped with laboratory grade sending units. All electrical pressure sensors are temperature compensated for highest accuracy. Features: - Glass domed lens to eliminate glare - Warning - User Preset - Peak Recall - Automatic Self Calibration - Short Circuit Auto Detect - Racing Spec Sensors - Extreme Accuracy - 270 Degree Full Sweep - High Resolution - Sequential Open/Closing Mode - LED Backlighting - Titanium Finish Casing
08-25-2009, 07:21 PM | #3 |
8115
Rep 18,814
Stri 52mm Digital Stepper Drive (DSD) Series, White Dial/Amber LED
08-25-2009, 07:21 PM | #4 |
8115
Rep 18,814
Stri 52mm Digital Stepper Drive (DSD-SLM II) Smoked Series, Black Dial/White LED
Unlike the standard DSD Series, the DSD-SLMII turn completely black when unlit for a "stealth" appearance. Click the accompanying images above to be brought to its specific page on our site. Available Gauges: - Digital Stepper Drive (DSD) Series, Boost Pressure (30psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Boost Pressure (45psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Water Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Pressure (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Exhaust Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Voltmeter (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Fuel Pressure (Imperial Measurement) DSD gauge series are equipped with laboratory grade sending units. All electrical pressure sensors are temperature compensated for highest accuracy. Features: - Glass domed lens to eliminate glare - Warning - User Preset - Peak Recall - Automatic Self Calibration - Short Circuit Auto Detect - Racing Spec Sensors - Extreme Accuracy - 270 Degree Full Sweep - High Resolution - Sequential Open/Closing Mode - LED Backlighting - Titanium Finish Casing
08-25-2009, 07:22 PM | #5 |
8115
Rep 18,814
Stri 52mm Digital Stepper Drive (DSD-SLM II) Smoked Series, Black Dial/Amber LED
08-25-2009, 07:22 PM | #6 |
8115
Rep 18,814
reserved
08-25-2009, 07:23 PM | #7 |
8115
Rep 18,814
reserved 2
08-26-2009, 09:56 PM | #9 |
Rep 473
any pictures with the guages in the car? Also with the leds do they mimic the amber lighting in the car? (m3 e 92). Also are the gauge install easy or do i have to go into my wiring and start splicing a lot of wires? Thanks
08-26-2009, 10:43 PM | #10 | |
8115
Rep 18,814
Gauges are intended to be a DIY job with the only splicing being required for power and backlight illumination.
08-28-2009, 01:19 PM | #11 |
8115
Rep 18,814
All inquiries replied and orders shipped.
Looking forward to seeing your pictures soon.
09-03-2009, 02:29 AM | #12 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
I love mine!
Thanks you guys.
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
09-03-2009, 12:23 PM | #13 |
Rep 1,920
Pretty cool! Good job!!
Do you have any pics of the gauges installed in the car? eg: view from drivers seat?
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
09-03-2009, 01:00 PM | #14 |
8115
Rep 18,814
We're finishing our install over the holiday weekend and will be posting soon.
09-10-2009, 12:38 PM | #15 |
8115
Rep 18,814
More shipping out today, thanks for the orders.
09-10-2009, 04:57 PM | #16 |
8115
Rep 18,814
Installed in our Project M3:
10-02-2009, 04:22 PM | #17 |
8115
Rep 18,814
Installed in our Project 135 w/ Stri DSD White backlit gauges:
10-06-2009, 09:17 PM | #20 |
8115
Rep 18,814
Or pockets.
