Catted or Catless???I have not Idea??
08-24-2009, 09:33 PM | #1 |
Rep 148
Help!!! Not sure on what is the difference? Can you help or point in the right direction.
Thanks! |
08-24-2009, 09:38 PM | #2 | |
Joint Chiefs of Staff
4918
Rep 115,980
In terms of performance this is what you are looking at from best to worst 1) catless downpipes (most free flowing) 2) performance catted downpipes (better then stock but more restrictive then catless 3) stock catter downpipes (most restrictive) Hope that helps Mike |
08-24-2009, 09:41 PM | #3 |
Rep 1,741
Drives: e92 335 space gray/coral red
On a basic level compared to catless the catted is a little bit more restrictive and produces less power increase but it is better for the environment, will not produce the smell of gas, will probably not trigger an O2 sensor code and will probably pass your emissons test.
The catless is non-restrictive and produces a little bit more power, will produce the smell of gas, will trigger an o2 sensor code unless you install an O2 simulator and you will probably fail your emissions test. With that being said I chose catted for a modest power and none of the issues associated with going catless. Catless will also be a little bit louder than catted. Catted is also more expensive.
GIAC S2 | Brembo GT BBK 355/345 | BBS CH-R | Michelin Pilot Super Sports | AR Design: DP, S1 Oil Cooler, OCC | AMS FMIC | Bastuck Quad Exhaust | Borla MP | KW V1 | Stett: CAI, CP | Forge DV | P3 Boost Gauge | Arkym: Front Lip, Rear Quad Diffuser | Vorsteiner CSL Trunk | LUX H8 | ModMyNav | MFD M3 Sideskirts | BMW M-Tech Front/Rear Bumpers, Edition Grills |
08-25-2009, 12:28 AM | #4 |
Rep 1,193
If your keeping the secondary cats go catless. If you have or planning on going with the catback I'd go catted. I went with catted dps and a catback. 40 pound weight savings for the catback, no smell and added power. It's a win win and I love the setup.
08-25-2009, 09:04 AM | #5 | |
Rep 1,549
08-25-2009, 09:16 AM | #6 |
Rep 7,377
get catless, waste of money to get catted. The point is to remove the worse restriction of the system and keep temp low.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
08-25-2009, 02:31 PM | #7 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
I would go catless for better flow. But if you have a sensitivity to the smell of fuel (you will slightly smell it while the car is stopped) then you might want to stick with a catted downpipe.
08-25-2009, 09:53 PM | #8 |
Rep 148
Thanks !!
Cool! Thanks guys for all the help! Cant wait to get purchasing. best place ...best price?????
08-26-2009, 03:59 AM | #9 |
Rep 919
AR Design Group Buy ... 599+shipping+o2 sims
Current:Bmw 325D E90 LCI Edition Sport | BSM | M-Tech | Comfort-Pkg | 6MT | OEM 18" 193M | Alcantara Seats | ESS Tuning Custom Stage 2 | OEM Performance Grill | FK Street Coilovers | CF Emblems |
Sold: Bmw 335i E92 - Fully Loaded - Stage 3+ |
08-26-2009, 10:14 AM | #11 |
Rep 318
Operating a vehicle in the US without a catalytic converter is illegal.
That said, I have done it in a few of my cars and never once had any trouble with my state inspection. But someone should point that out to the original poster. |
08-26-2009, 11:33 AM | #13 |
Rep 7,377
dont have a dyno sheet but my car picked up 25 whp with AR catless dps and Helix intercooler on stock boost.
08-26-2009, 03:16 PM | #14 |
Rep 3,012
Thats not true in all of the United states. In Oregon everyone drives straight pipes and there is no emissions test to pass. At least when I used to live there. Registration is extremely cheap and no CARB laws.
08-26-2009, 03:32 PM | #15 | |
Rep 318
http://www.catalyticconverter.org/law/ Kansas does not smog check either, lots of people go catless without a problem. But that doesn't it isn't illegal. |
