Help, JB+ with limp mod
08-24-2009, 04:43 AM | #1 |
Rep 71
I have 07 E92 6AT with catless downpipe and BMS DCI. I just bought the JB+ from the other member in the forum. It's brand new, never install. So I install the JB+ and set it at 100% after I drove it for about 20 miles, it went to the limp mod. I took it out and set to 75%. It still go to limp mod. I'm not even drive fast and it went to limp mod at below 4000rpm. What's wrong with my car? Should I take it out and set at 50%? Or should I just disconnect the battery? Anyone Thanks
08-24-2009, 06:15 AM | #2 |
Rep 7,377
maybe your car is not 100% and cannot handle the added boost. Try to get hold of a BT cable to see what codes you got.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
08-24-2009, 06:59 AM | #3 |
Rep 28
The limp mode is caused by the boost level not being reached. Go to burgertuning.com and look at the jb2 install guide, find the part where it shows you how to perform the "free" bypass. Once you perform the bypass you will no longer throw that code.
Also, something to note is that the install guide guide for the jb+ states that the bypass might need to be performed for any setting 75% and above. |
08-24-2009, 07:00 AM | #4 |
Rep 28
08-24-2009, 08:14 AM | #5 |
812
Rep 3,974
I would drive it hard without the JB+ again to see if you can get the limp mode to occur.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
08-24-2009, 10:59 AM | #8 |
Rep 2,014
Possibly one of the connecting pins in the JB+ is loose or not connected causing an interruption (like the TMAP is not plugged in), when this occurs a limp is thrown and the car runs a little trashy. Check the pins and verify if they are completely pushed in.
If your in so cal and would like a little assistance shoot me a PM. This had happened to me previously. |
08-24-2009, 11:12 AM | #9 | |
Joint Chiefs of Staff
4918
Rep 115,980
Inspect the pins to be sure they are all okay. Mike |
08-24-2009, 05:54 PM | #10 | |||||
Rep 71
08-24-2009, 06:18 PM | #13 | |
Rep 3,032
Either way, you should take the JB+ out like hotrod said and drive your car hard. That way you'll know if it's the JB+ at fault. |
08-24-2009, 06:31 PM | #14 | |
Rep 71
If the wire is broken, I shouldn't feel the power gain at all right? But feel a lot more power whenever I step on it. Or maybe it something else, nothing to do with JB+. I will try to set at 50% and see what happen. Should I do the bypass at 50%? Thanks |
08-24-2009, 06:42 PM | #15 |
Rep 15,818
Try to drive it without the JB+
if your problem still occurs, it's dealer time if the problem goes away, it's the JB+'s fault If you still have problem(s) running at 50% with the JB+, then PM me |
08-24-2009, 06:45 PM | #16 |
Rep 2,014
http://burgertuning.com/contact.html
Contact the man himself.. You are local to his area. I went up there to see him when mine did this, it was a simple 2 second fix.. If it is what I think it is, you might want to also get those TMAP disconnected codes cleared as well. |
08-24-2009, 06:57 PM | #17 |
Rep 60
I feel bad because I sold the JB+ to you. I can swear that the unit was brand new and never installed.
I hope you can get a hold of Terry to help you out. Hopefully it is an issue that can be easily fixed. |
