service soon
08-21-2009, 01:48 AM | #1 |
Rep 89
service soon
I was wondering if any scaner can delete codes and also i have a jb3 tune but have a friend who has the same car if i plug in the scanner to his car and then delete my codes and drive for a while we should have identical codes and if that does not work cant i just disconnect my battery touch the negitive to the positve let it sit and everything will be reset can anyone help me in this matter and tell me if any scanner can delete my codes and help me match it to a stock 335
08-21-2009, 03:20 AM | #2 | |
Rep 1,617
Not sure if I understood all your questions, but I'll say that a BT scanner can delete any codes in your car. Disconnecting the battery will not clear codes stored in the ECU. And what do you mean with "touch the negative to the positive"? Want to short-circuit the car??
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
08-21-2009, 08:02 AM | #4 | |
Rep 5,175
08-21-2009, 09:41 AM | #7 |
Rep 89
service
Will any scanner work besides a bt scanner they have different scaners to delete codes. And yes when you touch the negitive to the positive on the battery it resets everthing.
08-21-2009, 12:34 PM | #8 |
Rep 192
2013550Xi msport white
335xi-JB3, UR DPs, code-3 fmic, BMS filter,borla catback,11.96@116 |
08-21-2009, 12:38 PM | #9 |
Rep 277
08-21-2009, 02:35 PM | #10 |
Rep 76
If you touch the negative to the positive, you're gonna get a reset for sure! Hope you have alternative transportation standing by...or at least a bus pass.
