RHD P3 integrated gauge installed
08-19-2009, 05:38 PM | #1 |
Rep 565
The pic speaks for itself. Excellent product.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
08-19-2009, 05:44 PM | #2 |
Rep 565
09 C63 |
08-19-2009, 08:12 PM | #4 |
Rep 522
Looks nice George! I'm quite pleased with it myself!
I installed mine Monday/Tuesday. Few pics on this thread: http://www.e90post.com/forums/showthread.php?t=293384 Which route did you take for the boost line? |
08-19-2009, 08:59 PM | #5 |
Rep 10,855
I see this as a must for anyone with a tune/flash. Been waiting forever for Shiv to have boost, H20 temp etc. with procede.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
08-20-2009, 02:40 PM | #7 | |
Rep 565
Have you got concerns that the shock hood might flatten the boost pipe when closed?
09 C63 |
08-20-2009, 03:58 PM | #9 |
Rep 565
There are fitment instructions at www.p3cars.com . I reckon it was pretty easy to install. Hard part was taking of the OEM trim.
09 C63 |
08-20-2009, 04:23 PM | #10 |
Rep 1,993
George,
Ours are still sitting in customs Did you think about running the tubing from the DV's through the firewall on the passenger side and then behind the dash on the inside of the car? That was how I thought to run it when i did some measurements for Rick when I first sent him a RHD vent to get the project running. Keeps the tubing pretty well hidden that way too. Cheers, Stuart |
08-21-2009, 07:54 AM | #11 |
274
Rep 6,510
Thanks guys! Glad the install worked out good!! Future kits will have a longer boost tube to give you more slack, but it looks like the current length just barely worked!
Time to officially add the RHD version to the store Thanks to WOPALX for getting this project started for us!!! (your RHD vent is in the box being returned to you, pre-assembled) -Rick |
08-23-2009, 02:34 PM | #12 | ||
Rep 522
I have looked at the boost pipe and the only place where it's getting squeezed a tiny bit is coming out from under the brake cover, but everywhere else it looks okay. I ran the boost pipe under the wiring where the gas pressurized spring comes down so it wouldn't be flatten when closed. Is this the area you are concerned with? Quote:
I had a look from the engine bay to see if it was possible to run the tubing on the passenge side, but I couldn't see any way to do it. However it sounds like I should have a look at taking the lower panel on the passenger side off and see if there is a rubber grommet on this side as well. I agree this would be a nicer route to take. Did you already check this? |
08-23-2009, 03:19 PM | #13 | |
Rep 565
I am going to try go the route you suggested, seems like there will be less bends. Thanks for the idea.
09 C63 |
08-23-2009, 04:48 PM | #14 | |
Rep 1,993
That's where I ran the cable for my DEFI gauge, hence the suggestion. |
08-23-2009, 05:21 PM | #15 | |
Rep 565
09 C63 |
08-23-2009, 05:43 PM | #16 | |
Rep 522
Thanks, I'll give it a go. |
