Procede in dash boost display suggestion...
08-19-2009, 05:09 PM | #1 | |
Rep 978
I know you've said you prefer to see boost via a needle/analog type ideally. So how about something visual in the dash, like having a bunch of vertical bars (all same height) light up from left to right to indicate increasing boost? Let's say 8 bars, and each would equal 2 PSI. Would that be possible? Are there enough pixels in the dash? Sort of like the "flow" bars on this gauge, that I've outlined in the red box. PS You can leave out the S and B, though you could leave them in to indicate Safe and Boom! . . . |
08-19-2009, 11:24 PM | #2 |
Rep 36
i can speak for myself and probably many others, when driving, a needle display or digital numeric readout is ideal. Makes it easier to read the gauge.
With what you are talking about, it would be more time consuming to decode how many bars are lit and compute to a psi. I had a wms wideband o2 sensor on my truck with a numeric display readout. It literally took a quick glance (< .5 sec) to read the gauge. Clever thinking, but dont see it being an improvement. What would be nice is, to incorporate a bright light into a gauge that would brightly illuminate when you have a overboost (boostcreep) condition or an abnormal lean condition to let you know when to let off the throttle. Having the value be user adjustable is even a plus. |
08-20-2009, 09:49 AM | #3 |
The Stig
31
Rep 1,232
Guys, I can't speak for Shiv but having played around with some of this stuff myself, I think what you're expecting is out of the realm of possibilities. It will be amazing enough to hijack one of the signals to the instrument cluster and display boost instead of, say, MPG. To expect a custom-designed graphic display in the cluster is probably pretty unrealistic, however. That would require flashing new software for the cluster itself, which is probably not worth the effort it would take to figure out how to do that.
08-20-2009, 03:58 PM | #4 |
Rep 2,661
08-20-2009, 04:35 PM | #5 |
Rep 1,137
+2, what ever happened to all the iphone app ideas?
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
08-20-2009, 05:21 PM | #6 |
The Stig
31
Rep 1,232
ahhh you guys are killing me. what happened was i didn't have time to get into objective-c and things took off at work, we're just starting to chill out with it now. still haven't heard back from my vendor after a couple calls on the hardware, so it may be time to talk to someone else.
clearly you guys are interested, so i'll get back on it there aren't enough hours in a day!
