what would u do first..?
08-17-2009, 02:28 AM | #1 |
Rep 3,588
ok so i got some parts laying around
Stett FMIC ARDesigns 3" Catless DP's BMS Meth Kit *Question Is* im a complete track junkie and i love comparing parts to see how big a diff it makes on the track i only want to do one at a time to get the best possible number from that one part understand? (BTW) I only run pump gas 93 baby! so if u were in my puma's what would u do first.... to get the best numbers.? lol |
08-17-2009, 02:59 AM | #2 |
Rep 2,325
FMIC makes an impact in both performance as well as cooling, Id lean towards that first personally.
| Andrew | M Technik | BMW Performance | BBS | Forge | V1 | LUX | Bilstein | Precision-Sport |
08-17-2009, 03:05 AM | #3 |
Rep 206
You'll notice the biggest difference from the DPs for sure but I would start with the FMIC.
So yeah go FMIC, then DP's and then go with the meth kit.
08-17-2009, 04:05 AM | #4 |
Rep 7,377
FMIC definetely first mod.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
08-17-2009, 04:35 AM | #6 |
Rep 989
fmic and then a quaife or wavetrack diff....
EURO E92 M3 2008 6MT Interlagos ///Fully Loaded! Evolve-R ECU Flash/Gintani Sport Exhaust/MS Stg2 Intake Kit/H&R Springs/MS 18/15 mm spacers/Bmw Perf. Grills/Gloss Black side gills/LCI Tails/LUX V3's/RD license plate leds |
08-17-2009, 06:07 AM | #8 |
Joint Chiefs of Staff
4918
Rep 115,980
I would get the DPs and intercooler together
DPs = more raw power FMIC = more consistent power and prevents loss of power due to heat soak Mike |
08-17-2009, 06:08 AM | #9 |
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
FMIS 1st.
08-17-2009, 08:45 AM | #10 |
Rep 4,632
Consistent results - FMIC
Bang for the power- DP Together, best of both worlds. Meth kit- can actually in a way be best of both worlds aswell, cooler and more hp. |
08-17-2009, 04:32 PM | #11 |
Rep 4,936
+1 d
[SIGPIC][/SIGPIC]
08-17-2009, 06:33 PM | #12 |
Rep 3,334
Meth kit you get the benefits of cooling and octane boost. Then dps, then fmic.
Mods list got too long, lets just say more than enough.
08-17-2009, 06:44 PM | #13 |
Rep 8,745
If you intend to track regularly, it would be good to keep the engine happy aka upgraded oil cooler. You do not want to get limp modes for temperature being too high...... I'd do this and the intercooler before the go fast mods (tune and downpipe).
Unless by track you meant drag strip!
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
08-17-2009, 07:48 PM | #16 | |
aka Trevorsd
Rep 244
Or do what Mike suggested and get the DPs/FMIC at the same time... that's what I ended up doing.
JB3 2.0 Beta 18 ohm| BMS DCI | BT Tool | BMS Tuning Guage | BMS o2 Fix | BMS Stage 3 Chip Burner AR Design CL DPs |Helix FMIC | KDW2s | H&R Sport Springs | 3M 35% Tint Coolingmist CMGS Progressive/Fail Safe Meth Kit w/Flow Sensor |
08-17-2009, 11:46 PM | #17 |
Rep 3,588
i would like to do all of them at one time but also wanna help my fellow e9x's at the same time to let them know which made the biggest 1/4 diffrence so one at a time..
08-18-2009, 01:18 PM | #19 |
Rep 1,410
I think by "track" he means the drag strip (or just "strip) so nevermind the cooling issues for the most part.
FMIC DP's Meth FMIC is the worst part of a stock 335i |
