06-16-2009, 02:13 AM | #1 |
Rep 2,339
Blackstone oil analysis
Looks like I'll be doing oil changes myself in between the dealer services until the results improve.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
06-16-2009, 09:30 AM | #3 |
Rep 409
Thanks for posting your results. Mine are below for reference. Your lead numbers would make me nervous too.
It would be nice to get more data from other folks collected. As you mentioned, doing the minimum oil changes is not a good idea at all.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
06-16-2009, 11:22 AM | #4 |
Rep 5,012
That first lead number looks sky high, especially compared to the 2nd sample.
What moving parts have lead inside our engines? Just the 5 crank bearings? Curious. Thx. |
06-16-2009, 01:28 PM | #6 |
Rep 409
Jon Maddux
06-16-2009, 02:21 PM | #7 |
Rep 3,522
Ok, I just remembered the Blackstone postings before on E90post.
No sweat. Thx. The analysis is a great idea. The factory change frequency is rubbish to say the least. |
06-16-2009, 05:33 PM | #8 |
Rep 2,339
I'm starting to wonder what the oil sensors are looking for when it gives a recommended change interval. Is it testing for some kind of foriegn content or just viscosity?
06-16-2009, 05:49 PM | #9 | |
Rep 409
I think the interval it suggests is based on fuel burn. That is the parameter that the pre-E9X cars used. Burn a lot of gas or do a lot of city driving, and you get shorter intervals. The GM way had something to do with measuring the capacitance of the oil, but I don't think the BMW system works like that.
Jon Maddux
06-16-2009, 07:49 PM | #10 |
Rep 5,012
No current car has any kind of oil 'sensor'; it's just an algorithm; that's why you have to reset them . Each manufacturer uses different criteria: ignition cycles, fuel usage, along with average speed, duration, mileage, etc. But all are just a guesstimation at best.
AFAIK, only some big trucks have oil sensors, but even those can only measure viscosity, not contamination, additives, etc. To me, changing oil every 5 to 7.5K miles on a high-performance engine is cheap insurance. Also worth noting is BMW used to recommend changing oil every 3K miles, but when they started paying for oil changes, that was conveniently raised to 15K miles . Good day. |
06-16-2009, 08:22 PM | #11 | |
Rep 2,339
06-16-2009, 08:30 PM | #12 |
I love my beautiful wife!
22
Rep 628
These results are consistent with others I have seen posted here and over on Bimmerfest. If anything, this reinforces the fact that the recommended oil change intervals are too long.
06-17-2009, 04:27 AM | #13 |
yodog
196
Rep 5,026
What are the negative effects of running the car for another 7.5k miles (to the 15k mi mark) with that much iron/lead in it? Would it reduce the life of the engine?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
06-17-2009, 04:42 PM | #14 |
Rep 319
I'm wonderin this as well. I went with the recommended interval for my second oil change - after the 1200 mile service, I did not change the oil until the car told me it was due at 15000 miles. Hope the potential long term damage is not too bad. I'm definitely doing an oil change every 7500 miles from now on.
06-19-2009, 05:33 PM | #15 |
Rep 311
I paid for my oil change at 7K miles. Contamination in the oil causes extra wear on the cylinder walls so loss of power would be an eventual consequence. I'm not an expert so I can't say by how much or how long it would take for the particulates to wear down the cylinder walls, if ever. I just feel better with clean oil. Cheap insurance is right if you're keeping it for 10 yrs. Low viscosity oil should sneak in to the combustion chamber and cause more oil burn, possibly fouled plugs and loss of power. This is a high compression engine so I don't like the sound of low viscosity oil as it can be pushed up to the chamber. Just change the oil yourself. Not a big deal.
06-19-2009, 07:42 PM | #16 | |
Rep 2,339
