E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > HERTZ ES300 Subwoofer & EP2 2 Channel Amplifier FOR SALE!!!
Closed Thread
      05-26-2009, 07:07 PM   #1
nelsonlin87
nelsonlin87's Avatar
Drives: 2006 Bmw 330i Sedan
None
Hi, I need to sell my Hertz ES300 Subwoofer and my EP2 2 Channel Amplifier. Both of these items were used less than 3 months and were taken very good care of. This set up is perfect for anyone who wants to put a subwoofer their car. It sounds and hits very clean.
I am looking for $225.00 OBO for the Hertz ES300 Subwoofer + Sealed Subwoofer Box & $200.00 OBO for the Hertz EP2 2 Channel Amplifier. $400.00 OBO for both of them together.
Local pickup is preferred and cash is the best form of payment. If you need this shipped out, PM me, and I will try to get you a shipping price. Thanks.
In a E90 Sedan Trunk:
Hertz ES300 Subwoofer Specs:
Energy ES subwoofers were designed to work best when used in small enclosures. However, their electro-acoustic parameters are optimised for use in many different enclosure types; both in terms of typology (sealed box, reflex, bandpass, etc.) and in size, insuring extraordinary versatility and performance. The use of a long excursion mobile voice coil and high flux density double magnet have created subwoofers that can stand very high power with outstanding musicality and bursting dynamics. The special anti-scratch finish and butyl rubber rings offer protection and an aggressive look.
Product Features
* 12" inch Hertz ENERGY LINE ES300.3 - 700W max power subwoofer
* SPECIFICATION:
* High thermal dissipation and magnetic permeability plates, providing constant, even flux.
* Large double magnet, for perfect control under high power, high excursion conditions.
* Copper voice coil, wound on aluminium former, for startling thermal and mechanical capacity.
* Back plate vent holes, for very good thermal dissipation.
* Back Vented Spider support, for perfect symmetry under high excursion and thermal dissipation.
* Butyl rubber gasket provides ideal coupling to the mounting surface, damping basket resonance.
* Butyl rubber magnet ring provides protection against abrasions.
* Internally reinforced basket, protected from abrasions by high resistance paint.
* High current, tin-plated terminals.
* Silver plated silicone shielded lead wires for maximum reliability and conductivity.
* Basket and motor coupled and damped through special epoxy glue.
* Wide-wave, resin-bonded fibre spider for mechanical reliability and consistent parameters.
* High density Foam surround, for linear movement even under high excursion conditions.
* Water-repellent pressed paper cone.
* Max Power handling: 700W
* RMS Power handling: 350W
* Impedence: 4-ohm, single voice coil
* Frequency response: 25-250Hz
* Sensitivity: 91.6dB
* Outer diameter: 312mm
* Mounting diameter: 276mm
* Mounting depth: 128mm
Hertz EP2 2 Channel Amplifier Specs:
2 Channel, 190Watt RMS
Output Power RMS 14.4 VDC.
* 2 x 60W 4 ohm
* 2 x 95W 2 ohm
* 1 x 190W 1 ohm
Energy-Power: Instinct, Desire, Demand
EP, Energy-Power, the new amplifier line, is the perfect balance between original design, high performance and market competitiveness: the result is a product with the highest quality / value ratio available in the entry-level segment of the car audio electronics market. The know-how acquired with the development of the reference HP, Hi-Power line, as well as the continued research carried out by the Elettromedia R&D Division made the creation of the Energy-Power line possible; boasting care for accurate design, build quality and performance superior to traditional products. With the new Energy-Power amplifiers, you can now enjoy the pleasure of listening to hi-fidelity music in your car, with an entry-level product offering solutions usually reserved for reference products costing much more. Energy-Power: quenching the desire for engaging, dynamic sound in your own car now becomes instinctive.
Energy-Power series features special pseudo-balanced dual input circuitry to reject electromagnetic disturbances detected on the RCA or Speaker level inputs. ARTTM, Automatic Remote Turn-On/Off circuitry eliminates the need for a remote signal when using Speaker-In input automatically turning on and off the amplifier when the source is turned on and off. ARTTM provides also a Remote Out signal at the Remote In terminal to turn on/off other components installed in the system. EP series offers the possibility to be interfaced with traditional pre-amplified sources or speaker level OEM sources. A small size cabled connector is provided to wire in comfort and safety the Speaker-In input. On EP 1 D a pre-amplified signal is available from Speaker-In input at the Pre-Out RCAs to be sent to the rest of the amplifiers in the system.
Closed Thread
e90post
